      06-14-2019, 12:17 PM   #1
suspenceful
suspenceful's Avatar
Drives: 2015 M3, 2008 135i, 2009 335i
Found & Installed the Perfect 2-Post Lift in my Home Garage!
As I continue to work on my BMWs, I find myself constantly adding things to the garage to optimize my work space. Since buying the house four years ago, I transformed the 750 sq/ft garage into my ultimate hangout space. In my mind, the only thing missing was a lift. Until I found out about the MaxJax lift system. I have no affiliation with MaxJax, but everything about this lift as been great so far and I want to share my experience.
I had a tough time finding a 2-post lift that would fit in my garage with 8 ft. 7 in. (105″) garage ceilings. All of the 2-post options I found had a minimum column height of 9 ft. or 10 ft., which wouldn’t fit without modifying the ceiling. I didn’t want a scissor lift or a 4-post lift. Then I found the the MaxJax, which has short, portable columns.
In its highest position, the hydraulic cylinders rise up to 89″ with a lift height of 45″ (or 48″ with 3″ adapters)! This allows plenty of clearance between the columns and the ceiling, while offering 4 ft. of working space under the car. The only limitation is the height of whatever vehicle goes on the lift.
I also have a more detailed write-up on my blog that explains the most efficient installation process, with links to all of the tools and accessories that you'll need. Read it here: https://my1series.com/2019/06/13/how...e-review-mods/
Standard MaxJax Features
  • Low ceiling height friendly
  • Regular 110v electrical plug (no 220v required)
  • 6,000 lb. lifting capacity
  • Semi-portable lift columns
  • Adjustable base-plate width
  • 4″ minimum concrete required
Installation Guide & Video
The included installation guide is pretty comprehensive, but I made an in-depth video showing you how to install the lift in your home garage. I also demonstrate how to route the hoses off the ground to keep the mobile power cart out of the way.
4″ of good concrete is required to install this lift. I used the standard anchors that are included with the kit, but some people prefer the epoxy anchors instead. I mounted the columns 125″ apart from each other, measured from the inside edge. This width has allowed me to lift multiple vehicles with various jacking points.
This adjustable creeper is perfect for working under the MaxJax, since it doesn’t lift high enough for you to stand under it. This short oil drain tank comes in very handy when changing oil or other fluids. I’ve used these short tripod stands when doing suspension work or to help support the car. It is the perfect lift for the at-home DIYer.
I would love to hear your thoughts and comments!
750whp 135i Build | Budget 335i Build | F80 M3 Build
🎬 YouTube channel (35K+ subs): youtube.com/jakespence135
📷 Follow me on Instagram: instagram.com/jakespence
🏁 Shop BMW merchandise: bimmerstreet.com
3798j11410.50
Nkc1600.50
msan402.50
      06-14-2019, 12:26 PM   #2
Thunderguts
Thunderguts's Avatar
785
Drives: 2009 128i Sport MT
Great write-up.
I'm trying to justify the price of a lift to myself (and the wife). I have a high-lift jack that will do 24" of lift. I can drop a differential by putting the car on 12" risers or tall jack stands. I don't know if I could fully drop the transmission or not, but I think I could.
My main issue is a very narrow garage that would require me to move the posts when not in use. I'm guessing it would take nearly an hour to set it up and bolt everything down once I had it installed. I just wonder how often I'm going to want to do that. If I could leave it in place, it would be a no-brainer.
      06-14-2019, 12:31 PM   #3
BayE30
Drives: 2011.75 E90 M3 ZCP
NICE GARAGE!
looks like it allows a good amount of space underneath the car to work. To me anything is better than laying on your back straining your neck to work on a car!
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V]
      06-14-2019, 01:35 PM   #4
suspenceful
Originally Posted by Thunderguts View Post
Great write-up.
Nice! Having a 24" lift jack is better than nothing.
I was also concerned about how much area it would take up because I have a 2 car garage, and still want to use the other stall. With the 90* fittings installed at the base of the posts and a narrow install, you'll be fine. But if you want to take them down and store them away everytime, it should only take 15 minutes to roll them out, tighten 5 bolts each, and slide on the quick-disconnect fittings. The most time consuming part of it was assembling everything, drilling the holes and setting the anchors. After that, it goes really fast.
Originally Posted by SFCM3 View Post
NICE GARAGE!
Thanks! And that's exactly my thoughts. Some people online say it must suck because you can't stand. But honestly, the rolling sitting creeper is great and anything is better than getting on my knees, jacking it up, and then rolling around. I love it so far!
      06-14-2019, 01:37 PM   #5
rice_rocket88
Drives: E60 F48 F39
That looks awesome.. as does your ceiling! I had this in mind when I first moved into the new house, but was lucky enough to talk to the builder and found out that at BEST there was 4" of concrete under there, but most likely somewhere around 3 ish. I know there have been some debates about other ways to get it done right, but I honestly just didn't want to A) take the risk B) use the alternative methods and definitely not C) jackhammer and fill more.
I ended up with the quickjack which gets you pretty good height, and I can push them together and just drive over them during 99% of the time that they aren't in use which might work for thunderguts. The quickjack I think on some sale was literally like 1K for me.. which I just justified in my mind that my biggest jack was failing/leaking.. and some of the cars didn't have great lift points so I had to jack up each corner to put on jack stands. Either way it was a good splurge that has paid off multiple times. Heck, I get free beers/lunch/gifts for friends and family that use it to change winter tires over to summer and vice versa !
      06-14-2019, 03:37 PM   #6
suspenceful
For sure! Totally understandable. I debated those, but didn't want to spend the cash unless I got significant lifting room (not be on my back). I pulled the trigger on the MaxJax when it was on sale for $1675 shipped with residential delivery, liftgate, and tax included. I didn't measure my concrete beforehand, just prayed when I drilled my first hole that it'd be deep enough.
I look forward to family and friends pestering me to use it, which I think will be okay as long as they bring beer
      06-15-2019, 10:43 PM   #7
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
Good write up! Thanks for sharing.
      06-16-2019, 12:54 AM   #8
roastbeef
roastbeef's Avatar
Drives: E92 M3
tell me about that adjustable creeper.
Instagram; @roastbeefmike
      06-17-2019, 09:36 AM   #9
suspenceful
I love this thing already: https://amzn.to/2Wxwump
The butt and back cushion are both adjustable. Many different locking positions for both, depending on how much angle you want. Very sturdy piece, rolls very nicely too. Extremely happy with the purchase.
roastbeef11586.00
      06-17-2019, 10:18 AM   #10
to_riffic
to_riffic's Avatar
Drives: rwd
That looks like a legit shop garage! Jealous!
~loud noises~
      06-17-2019, 10:35 AM   #11
tdott
Drives: M3
Pretty sick garage! Wouldn't trade my lift in the garage for anything.
Efthreeoh17309.00
      06-17-2019, 11:41 AM   #12
chassis
chassis's Avatar
6550
Drives: 9Y0 Cayenne S
Putting in more concrete in the case of a thin floor is no big deal. Saw cut a pad big enough for a sonotube then electric jackhammer the small amount of concrete to be removed. Dig as deep as you like, insert sonotube, pour, insert anchor, allow to cure, and Bob’s your uncle.
4 hours of work not including concrete cure time.
Efthreeoh17309.00
      06-18-2019, 05:00 PM   #13
suspenceful
Thanks man! I can't take all of the credit because the previous owner did a lot. But I put my own touch on it and love it.
I can already see myself never not having a lift again...
You make it sound so easy! It does boil down to just about that though, doesn't it...
      06-18-2019, 05:03 PM   #14
msan
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
Thanks for taking the time to make this write-up
      06-21-2019, 08:39 AM   #15
Efthreeoh
Great write-up.
That's the easy part, just explain to her the money you'll save her fixing her car.
But seriously, I've estimated I've saved $18,000 on labor costs by DIY'ing JUST on my E90 alone. Regarding my wife's approval of a lift, I've kept her 22 year old Z3 (now approaching 190,000 miles) on the road far longer than it would be economically prudent to do so without DIY'ing it. I built an entire building to house my lift, which required leveling part of the mountain our house is situated on. Her only requirement was getting a ALI-certified American-made lift; she didn't want a car falling on me (not sure why, I have a good life insurance policy...)
tdott3942.50
      06-21-2019, 08:43 AM   #16
New2Roundel
Drives: Some fun stuff
Congrats, I love what you've done with your garage! I would totally rock your garage setup if I had the space---quickjack is pretty much as wild as I can go at my current house.
