E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > **NEW** - PAGID Brake pads now available for 335i/d
Reply
      10-08-2008, 10:22 PM   #1
E92Fan
E92Fan's Avatar
Drives: .
Arrow **NEW** - PAGID Brake pads now available for 335i/d
Just to let people know -
Pagid have finally released their upgraded brake pads in both front and rear fitments for the 335i and 335d.
The pad pattern numbers are as follows:
335i/d FRONT - Pagid # 8053
335i/d REAR - Pagid # 8051
The pads will be available in the following flavours -
Pagid 4-2-1 Black (fast road pad, standard OEM pad on Aston Martin, Ferrari, Lamborghini etc)
Pagid 4-2 Blue (fast road pad, higher friction co-efficient than the 4-2-1 Black pad, greater fade resistance, excellent cold friction, possibility of very slight pad squeal when cold)
Pagid RS19 Yellow (endurance track pad, low wear characteristics, suitable for Nurburgring and other track days, not ideal for general road use due to excessive pad squeal and reduced cold friction)
Pagid RS29 Yellow (development of the RS19, with higher friction levels and greater fade resistance)
Pads for the 320-325 models, and the 330 models, will be following in due course.
Pads for the 135i (and consequently the BMW Performance Brake Kit) will be available within the next three to four weeks.
      10-09-2008, 06:52 AM   #2
Steve A
Steve A's Avatar
Drives: too much
Ive got some pagid rs19 yellows and i can concour that they squueeelllllll like a whore.
But as they are only for track days the stopping power is amazing.
C350 cdi sport estate facelift 457lbft
130i M SportMercedes C350 CDI Sport Estate AutoMini Cooper Auto.Mercedes E250 CGI,Lexus IS-F,R36, RS4 Saloon,ML 420 CDI SPORT,M6, 335d, C55, C32, M3, M5, S3, ALL SOLD but fondly remembered
      10-09-2008, 07:29 AM   #3
R4R
R4R's Avatar
Drives: E89 Z4 35i
where do you guys normaly get these from?
i fancy some, but will remove them after each track day and put the OEM pad back in. its not too much of a faf, but probably worth the avoidence brown trouser moment first thing in the morning of a drive to work!
Dario
35i - DCT - Most of the toys - Smart top roof module - GLF.
www.onboardvision.co.uk
www.gtvr.co.uk
www.vehicle-launch-incar-video.co.uk
      10-09-2008, 08:11 AM   #4
E92Fan
E92Fan's Avatar
Drives: .
Dario
You should go through Ant at www.speedreligion.net
Speedreligion.net is likely to be cheaper than going through CBP (below), as Ant has a wholesale purchasing deal, and he sponsors our forum
Or if you need more info on Pagid products, contact Competition Brake Products directly (Pagid UK distributors), at www.racepads.co.uk or 01748 831200.
      10-09-2008, 08:14 AM   #5
Steve A
Steve A's Avatar
Drives: too much
Thats where i got mine
Dario
Thats exactly what im doing.
I had the Pagids put on with some braided hoses and some race brake fluid and the braking performance was mega.
The only downside was the noise.
Ant removed them and replaced them with the oems.
For each trackday ( im going to croft and oulton) im having them in.
      10-09-2008, 08:22 AM   #6
E92Fan
E92Fan's Avatar
Drives: .
Steve, you should consider upgrading the OEM pads (which even on your M6 are the utter rubbish Jurid 310 / Textar 4165 pads) to the Pagid 4-2-1 Black road pads. They give you a HUGE increase in performance, and yet don't squeal... They are a little bit more dusty though, but you can't have everything!!
      10-09-2008, 08:23 AM   #7
330cdsport
Right Responsible
330cdsport's Avatar
Drives: AW F21 M135i
Thanks for the info E92Fan.
Can you recommend any of the pagid pads you listed as a direct replacement for the OEM pads?
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension
Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys.
      10-09-2008, 08:24 AM   #8
E92Fan
E92Fan's Avatar
Drives: .
As a direct replacement for road use, but offering a massive upgrade in performance, get the Pagid 4-2-1 Black.
      10-09-2008, 08:48 AM   #9
330cdsport
Right Responsible
330cdsport's Avatar
Thanks
      10-09-2008, 09:24 AM   #10
Icedog_16
No Member
Icedog_16's Avatar
Drives: 2011 E92 335is
Thank goodness! I had the RS42's on my Elise and I loved them. Great pads!
      10-09-2008, 02:18 PM   #11
Steve A
Steve A's Avatar
Drives: too much
TBH tony that was the kind of thing i was after. Ant recommended the yellows as i said i was doing trackdays.
The performance of tbhe yellow is mega but the noise is embarrasing in the high st
when the yellows run out next year then ill just fit the Pagid 4-2-1 Black road pads and save the hassle of cahnging before each trackday.
      10-09-2008, 02:20 PM   #12
E92Fan
E92Fan's Avatar
Drives: .
I have a set of RS29 yellows, which I am intending to put on when I next go to the 'Ring in a couple of weeks time. I'll change back to the Ferodo DS2500 roadpads for the journey back...
      10-10-2008, 01:02 PM   #13
E902717
E902717's Avatar
England
57
Drives: E91 335d M-Sport
I would love some 4-2-1 black pads for my 325 when they come out, but how hard is it to change them yourself?
      10-10-2008, 02:14 PM   #14
willhollin
willhollin's Avatar
England
268
Drives: VW T5
http://shop.speedreligion.net/index.asp
Ant has the front ones listed on his site, drop him a line.
      10-10-2008, 04:21 PM   #15
E92Fan
E92Fan's Avatar
Drives: .
He only has the RS19 Yellow track pads listed, for the 335i/d. The front pads for the rest of the E9x range have not been made yet, although they will become available within the next three to four weeks.
      10-10-2008, 04:22 PM   #16
E92Fan
E92Fan's Avatar
Drives: .
You have to release the front caliper by undoing the hex bolts, swing the caliper off the disc, then replace the pads, and put the whole thing back together again. Worth bleeding the brake lines as well at the same time. Or, take your car to a garage and pay them one hour's labour to do it for you
      10-11-2008, 07:26 AM   #17
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
949
Drives: 997.2 GT3
Tony any reccomendations for the DXB?
997.2 GT3
      10-11-2008, 01:28 PM   #18
E92Fan
E92Fan's Avatar
Drives: .
As I've already written above mate. You should get Pagid 4-2-1 pads on the front next time you need new pads
      03-18-2011, 06:02 AM   #19
335iLondon
335iLondon's Avatar
35
Drives: 07' 335i Msport
As far as I can tell this never happened.
You cannot get the 421 Pagid black pads for standard fitment 335i
      03-18-2011, 06:23 AM   #20
zltm089
zltm089's Avatar
Drives: 335i SE Coupe Space Grey
2006 BMW 335i  [10.00]
Will the pads fit on the OEM brake discs? and do I need to change the brake fluid type aswell?...or will it work with standard BMW brake fluid?
What is roughly the price difference when compared to the BMW ones?
      03-18-2011, 07:29 AM   #21
Spaceman330D
Drives: E91 330D Msport
the thread is years old bud
think london was asking bout pads in another thread and it was confirmed that they don`t supply the pads.
      03-18-2011, 07:32 AM   #22
335iLondon
335iLondon's Avatar
35
Hi,
I have been researching a fair bit, and it seems we maybe in the same boat.
You can replace oem pads with a number of different ones.
I have decided to use the EBC yellowsftuff pads
My understanding is that to replace the brake fluid is recommended, but standard will wrk, but perhaps not extract the mx performance from the pads.
but the standard lines are generally hardy enough for occasional track use and fast road
check out my thread on the issue, some good advice from other members on there
Reply
e90post
