E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Help!!! My car has many engine codes
      03-12-2024, 04:29 PM   #1
07335ie93
Drives: 2007 335i
I have the following codes
2c7b
29e1
2c7c
29e0
2cab
2ca7
2f9e
2c6e
2deb
Car ran fine before one day wasnt able to reverse out of my garage and car went into trans malfunction.
      03-12-2024, 07:12 PM   #2
gbalthrop
Drives: 2007 328xi E91
Wink
2c7b
29e1
2c7c
29e0
2cab
2ca7
2f9e
2c6e
2deb
You have begun 5 threads in 3 days on this forum, with complaints regarding VANOS, O2 Sensors & ZF AT.
You have posted INPA screens on several of those threads. If you have INPA, if you use it correctly, you SHOULD be able
to correctly DIAGNOSE your issues, at least with Forum Help.
My suggestion is to review the attached pdf: "INPA Tutorial Quickstart", including HOW to Save & Attach INPA ScreenPrints, and THEN:
1) Save & Attach ScreenPrints of "INPA > Functional Jobs > F4 > F1 Error Memory, All Modules" which will be TWO Screens.
2) Provide Last-7 Characters of your VIN.
3) Provide a photo of Instrument Cluster after Engine Start, showing any Warning Lights present.
4) List ALL performance issues in the vehicle, such as rough idle, transmission issues, etc. and if there is ONE you would like to address FIRST, please identify.
5) If any maintenance was done on vehicle in week PRIOR to issue beginning, please describe, with History.
The Fault Codes you list here are related to:
a) O2 Sensors (4 Codes);
b) Mixture Control, BOTH banks, cyl 1-3 & cyl 4-6, 2 codes;
c) single code for Each (i) Oil Level Sensor, & (ii) Power Management
You appear to have Multiple Issues. We can suggest Next Steps you can do with INPA or a Multimeter, to properly DIAGNOSE an issue instead of "Throwing Part$". ISTA Fault Definitions are attached to NEXT Post.
George
BRG_N54296.50
      03-12-2024, 07:14 PM   #3
gbalthrop
Attached are two ISTA ScreenPrints showing 9 Fault definitions for codes you posted above.
George
BRG_N54296.50
      03-12-2024, 09:26 PM   #4
07335ie93
Drives: 2007 335i
I’m not sure if my inpa is messed up but this is all i get from error memory, i was able to see more info on errors in gearbox where my main issue is
1. see pics attached
2. 7X50226
3. Only lights that illuminate are windshield wiper fluid and service engine soon
4. Car starts up just fine, has rought idle for about 30 seconds then runs just fine. One morning after sitting in garage about a month or 2 ago got transmission malfunction and couldn’t reverse out of garage got, ended up getting to drive and went to school and back home. Was able to take it on a drive with my mechanic who wasn’t able to diagnose the issue very well or really at all. Transmission never really had much of an issue except for sort of delayed shifts and the notorious high rev from 2-1 downhill. Car can no longer reverse out of driveway at all now
5. no maintenance had been done in the week prior, only odd thing i noticed was when i went to pop the hood to trickle charge batter a couple days ago I saw my hood insulation covered in engine bay, A mouse i’m assuming had a field day and am wondering if the little sucker could have chewed on a wire or something.
      03-13-2024, 12:27 PM   #5
gbalthrop
2. 7X50226
4. Car starts up just fine, has rough idle for about 30 seconds then runs just fine. One morning after sitting in garage about a month or 2 ago got transmission malfunction and couldn’t reverse out of garage got, ended up getting to drive and went to school and back home. Was able to take it on a drive with my mechanic who wasn’t able to diagnose the issue very well or really at all. Transmission never really had much of an issue except for sort of delayed shifts and the notorious high rev from 2-1 downhill. Car can no longer reverse out of driveway at all now.
5. no maintenance had been done in the week prior, only odd thing i noticed was when i went to pop the hood to trickle charge battery a couple days ago I saw my hood insulation covered in engine bay, A mouse i’m assuming had a field day and am wondering if the little sucker could have chewed on a wire or something.
Automatic Transmission DIAGNOSIS is a specialty. As "GoRomeo" suggested in your first thread re AT, amateur diagnosis can get EXPEN$IVE. I understand that where you live, there are NO shops that appear competent for ZF AT diagnosis/ repair. Since you have INPA, you can provide INPA ScreenPrints to a shop MILES away, and perhaps do diagnosis by Web/email.
AT (Automatic Transmission) is the ONE system of a vehicle that I take to a pro for diagnosis & repair. Dealers usually are NOT competent in transmission Diagnosis/ Repair. That said, your INPA Screens offer some clues.
Your "Information Memory" INPA Screen showing "4F86", shows "Wandlerkupplung geregelt" = Converter Clutch Regulated at 175,464 km, and AGAIN at 178,416 km. That's 109,028 miles & 110,863 miles. NOW, at 181,640 km (112,866 miles), you see "Wandlerkupplung offen" = Converter Clutch OPEN. Those translations are with Google Translate, and may NOT be most technically-correct German to English translations. I would want to know:
1) WHAT is "Wandlerkupplung/ Converter Clutch"? Is that clutch that engages Reverse Gear?
2) WHAT does OPEN/ Offen mean related to that clutch? Is that an electrical issue (relatively cheap repair), or mechanical clutch failure?
3) Appears that fault was progressive over last ~ 2,000 miles. Has there been any AT Fluid LEAK? Since fluid loss, LOW AT Fluid level & LOW pump pressure can cause lack of gear engagement, is it reasonable to drain fluid, drop pan, check magnet for metal wear, change fluid & pan, and REFILL with proper amount of NEW Fluid. That is a DIY procedure for LESS than $200 (new fluid & replacement pan with incorporated filter. It does require Ramps/ Jack Stands to get vehicle off ground & LEVEL so you can add fluid with engine running.
4) There ARE some "cheesy/cheap" shortcuts on procedure above, such as: you could simply jack rear and pour in an additional quart of proper ZF AT Fluid, and see if anything changes.
YOU can learn a lot about your transmission issue by simply:
A) TRANSLATING the German to English on your INPA Screens:
https://translate.google.com/?sl=de&...r&op=translate
B) Take the time to study the Fault details or Freeze Frame data to see the conditions at which (including mileage) the fault was saved.
C) Using BMW Fault Code Lookup to get additional Information (SOMETIMES ;-) regarding a particular code.
D) Don't be afraid to THINK/ ANALyze.
Here are some BMW Fault Code Lookup Fault Info Sheet LINKS for your AT Codes. Look at the "Service Notes", which ALL state "Check Fluid Level":
https://bmwfault.codes/XMLDiagView?d...IANgA4ADAANAA=
https://bmwfault.codes/XMLDiagView?d...gANwA0ADAANAA=
https://bmwfault.codes/XMLDiagView?d...gANwA3ADAANAA=
George
BRG_N54296.50
      03-13-2024, 01:16 PM   #6
07335ie93
Drives: 2007 335i
thank you very much, i truly do appreciate your help. I plan on replacing the mechatronic sleeves, fluid and filter replacement, as well as the solenoids. Hoping that this will tackle many potential issues with transmission and help prolong the life. I was wondering if you had any knowledge on what wire L1-L4 means in terms of transmission. In inpa it states that wire L3 is off
      03-13-2024, 11:22 PM   #7
gbalthrop
... I was wondering if you had any knowledge on what wire L1-L4 means in terms of transmission. In inpa it states that wire L3 is off
I have the GM6 AT, GS1912 EGS in my 328xi, and do NOT have such a screen in INPA for that GS1912 Module. I would suggest check the GS19B Main Menu, or F5 Status Menu (presuming what you posted is a Status Screen), for the TITLE of that screen. It appears to have something to do with digital Gear Selector Position.
BTW, please check the Last-7 VIN you posted, as "7X50226" doesn't compute.
ISTA Transmission Wiring diagram shows 4 wires (P,R,N,D) for the Selector Lever Position Switch (in addition to Ground wire). There ARE INPA Screens in EGS Module, that show gear selected as Live data, found in EGS > F5 Status. Also, if the Black/Yellow wire at X1599/3 (Reverse Signal wire) were NOT connected or functioning, you probably would NOT see "R" on the Lower Instrument Cluster display when Reverse is selected.
Don't be afraid to experiment with viewing different INPA Screens, at least F5 Status Screens, as those ONLY show you Live data as INPUT to the EGS Module, and you are "Just Looking" & can't hurt anything. Please let us know what you find.
George
      03-14-2024, 06:44 AM   #8
07335ie93
Drives: 2007 335i
ah i’m sorry, last 7 of vin is px50226
      03-25-2024, 06:36 AM   #9
07335ie93
Drives: 2007 335i
update!!! underwent the diy trans service and found just what i expected. wasn’t able to go on real drive didn’t have enough fluid but reversed with ease off the lift
      03-25-2024, 01:53 PM   #10
gbalthrop
update!!! underwent the diy trans service and found just what i expected... reversed with ease off the lift
Congrats! I give up: WHAT did you "find"/replace, & WHAT is shown in photo?
George
      03-25-2024, 01:56 PM   #11
07335ie93
Drives: 2007 335i
it’s like the adaptor seal or something of that matter. I ended up doing a full trans service, new solenoids, filter fluid and mechatronic sleeves. Wasn’t able to take on full drive because the 7 liters of fluid wasn’t enough, but had my reverse and drive back
BRG_N54296.50
      03-28-2024, 06:43 AM   #12
07335ie93
Drives: 2007 335i
hello again, so came back to my car today as it was at my shop waiting for 2 more liters of fluid. When i got even near the car with the key the electrical system malfunction popped up. Then when turned on had damn near every light in the car pop up. Wasn’t able to drive at all before trans service but now won’t shift into second gear. Could this all be battery related. The voltage of my battery is like 11.5
      03-28-2024, 08:36 AM   #13
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
Can't speak to the warning lights, but battery is bad.
e90post
