04-28-2023, 02:12 PM | #1 |
Rep 345
sponges for traditional car wash?
seems like the technology has gotten better? i was skeptical at first, but watched a video where trapped dirt releases almost immediately with a light scrub against a grit guard. this release doesn't happen with a microfiber pad i use. i have to really work for the dirt to release.
most guides seem geared towards rinseless washes, but im interested in pairing with traditional soapy washes. anyone have experience with sponges? |
04-28-2023, 02:41 PM | #2 |
Rep 1,454
I haven't kept up with anything in the past 5 years, but have been pleased with using the sponges from Optimum (see below). I use them for a post-Opti-Coat ceramic low water wash.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
1209582821.50 |
04-28-2023, 02:43 PM | #3 | |
Rep 345
04-28-2023, 03:19 PM | #4 |
F15 daddymobile
2435
Rep 3,580
dirt and grit won't embed and get stuck between those cross cuts? how deep are they?
04-28-2023, 03:25 PM | #5 |
Rep 544
Run far away from any sponge
swainbmw629.00 FrankMstein1338.50 |
04-28-2023, 04:34 PM | #6 | ||
Rep 1,454
2017 X5M - Current
04-28-2023, 08:49 PM | #7 |
Rep 901
No sponge they Hold grit. Use a MF mit or pad and rinse before dipping back in soap
04-28-2023, 09:12 PM | #8 |
Rep 749
Sponge? Is so 1970...
Two Bucket wash with MF Mit... That is all, don't over think it! Free flow rinse car, then pressure wash, then foam, the rinse, then foam again, let sit 5 mins... Then soapy mit on foamed car, one panel at a time, rinse, using grit guards, then rinse again, dip in soap bucket and do another panel, repeat until done. I use a separate mit for the lower 1/3 of the car, front and lowers done last as that's where all any grit might be, doing it last limits the possibility of picking up a piece and scratching the paint... Good Luck! |
R BMW956.50 Gladius Nova81.50 |
04-30-2023, 10:34 PM | #11 |
Rep 345
i tried this with 15x towels. long story short, its not for me. it might be the safest method, but i prefer the simplicity of one mitt or sponge.
05-08-2023, 10:39 PM | #13 |
Rep 109
Hello All,
I'd like to give some advice in this regards having managed a detail business for 14 years, many years ago. This includes professionally buffing well over 10k cars alone during that period. There is no way I could count typical washes or other type details. I've been maintaining my own for nearly 40 years as well. I've also professionally painted a dozen or more vehicles going back to the 80's with factory results, for family/friends. So, the advice I'm giving comes from a lot of experience. The following is what I consider to be the best. 1) Purchase a CarPro merino wool wash mitt, period! I don't care for sponges nor microfibers. The merino mitt is far superior and safer for the paint. 2) Use the two bucket wash method. One bucket to wash with (soap bucket) and one bucket to rinse your mitt out with (rinse bucket). So, wash/rinse/re-load/wash. REPEAT...... The two bucket method is considered to be the best method by the vast majority of professional Detailers. I actually developed an even better method though; if you are willing to keep a spray bottle on your person. Have a spray bottle mixture of your favorite soap diluted with water. You'll only need one rinse bucket for this method which goes as follows. *Rinse your vehicle off as normal, prior to washing. *Spray an area with your soap bottle. *Wash the area with your mitt. *Clean your mitt out in the rinse bucket. *REPEAT...... This is the best method for washing your vehicle IMHO because 1) You're going to be washing with significantly more soap and consequently lubricity on the surface of your vehicle. Lubricity helps protect against imparting microscopic scratches. I just hook the bottle in my pants pocket as I wash. Trust me. This method is far superior then loading soap from a bucket. You just have to get used to having the bottle hang off your pants. DO NOT wash your vehicle via rinse-less methods when you can wash it! Most of that is sells hype and pushed by Detailers who are being compensated. Use your common sense. Rinsing dust from a car with water first and then washing it is safest. Spraying dust as it sits on your car and then wiping it off is not. You should only resort to that if you have no choice, such as winter/water restrictions (etc). Don't buy into the hype. Tip: As another poster stated, wash the very bottom last. 3) Dry your vehicle using two medium sized microfiber towels! That's all it takes. My absolute favorite and safest is the Platinum Pluffle. Keep one towel in one hand and the other towel in the other hand. Dry with your lead towel and immediately follow up with your second towel to pick up any remaining water. You'll need to wring out your lead towel two or three times. You can wash an entire vehicle with just these two medium sized towels because the lead towel is doing all of the work while the second towel is used for finishing purposes. Tip. I often use Eagle "Wax as you dry" during the drying process. You can also use their "Nano Wax" although it is not meant to be used as such. This is beneficial in two ways. 1) You're adding a protectant to your paint and 2) You're using extra lubricity while drying which again helps protect against imparting microscopic scratches. There may be other products available at this time. I've just been using the Eagle products for many years. There are other things to consider but you'll appreciate the above. Especially if you have a dark and expensive vehicle that you wish to keep pristine. God Bless, Ralph Last edited by Ralph III; 05-09-2023 at 04:21 PM.. |
05-08-2023, 11:51 PM | #14 |
Rep 23
I'm glad you added this Ralph, I saw a post about a sponge and wanted to reply that no detailer out of the 15 or so I have known personally has ever used a sponge. You just proved why that is. Thank you
05-09-2023, 12:29 AM | #15 |
Rep 116
Great tips Ralph! I wanted to reply with my washing routine but what you described is far more detailed and informative than what I had in mind.
My 2 cents: Try Kirkland's 36-pack microfiber towels. I go through them liberally, fresh towel for upper body -> bumpers / lower body -> wheels / tires -> tail pipe -> trash can. Also use fresh towels for drying. |
05-09-2023, 07:18 AM | #16 |
Rep 544
I love the Carpro merino wool mitt. Among the best wash media I've used. My only caution with it is be careful of it getting caught under badges or tight panel corner seams. I will occasionally find little clumps of wool caught in tight places as I'm drying.
2022 BMW M240i Portimao
Gone: 2020 Genesis G70 3.3T | 2018 Audi A5 SportBack | 2015 Challenger Scat Pack | 2011 Mustang V6 | numerous others.. |
Ralph III108.50 |
05-09-2023, 08:27 AM | #17 |
Rep 6,383
I use them for rinseless washing I wouldn't be comfortable using it with traditionally soap tbh although some people do with no issues. I use my CarPro microfiber mitt for soap wash. I think the myth about sponges being bad came from using grout/bathroom/dollar store sponges on your car rather than sponges made of proper soft foam.
1209582821.50 |
05-09-2023, 04:19 PM | #18 | |
Rep 109
I just much prefer the merino mitt because it accomplishes the same thing, only better IMO. I can also wash significantly faster with it as it covers more surface area. You just have to rinse them out afterward and hang them out to dry. Good luck, Ralph |
P111716.50 |
05-09-2023, 05:16 PM | #19 | |
Rep 109
Take care, Ralph |
cpt408.50 |
