07-18-2024, 03:50 PM | #1 |
Rep 5
license plate mount to front on 430i
Does anyone have recommendations on mounting a front license plate on a 2020 430i xDrive convertible? I'd rather not drill holes through the bumper so I'm looking for a mounting bracket that fits. There are tow hook options available but they might have sensor issues.
07-19-2024, 09:36 AM | #2 |
Rep 2,360
Posts Drives: 2023 BMW Z4 M40i Join Date: Mar 2021
Couple suggestion on this thread. Didn't look, but I'm assuming the places recommended also have something for the 4-series.
https://g29.bimmerpost.com/forums/sh....php?t=2116775
2023 Z4 M40i - San Francisco Red Metallic/Ivory White
Past: 2021 M340i xDrive - Sunset Orange Metallic/Black w/blue stitching |
07-19-2024, 10:33 AM | #3 |
Rep 954
Maybe check out a Sto-N-Go mount. They have models that mount to the bottom center of your bumper fascia, and have the plate mounted on a (removable) 90deg angle bracket.
07-19-2024, 11:27 AM | #4 |
Rep 2,015
For a 2020 430i (looking at your short post history), it depends if you have the M-Sport package, I see two different front bumpers, one with a grill where you can mount a true no-drill Carbonio: https://carbonio.com/products/bmw-4-...sports-package
Otherwise, you might be stuck with a Sto N Sho, which still requires drilling (but on the underside of the bumper so not as visible). With such a big thick flat section, I would look into 3M automotive double-sided tape, if you google it surprisingly many enthusiasts mount it that way. YMMV Edit: Here's another option that works with horizontal slats on the lower portion of the grill, not sure if the 2 screw holder would work with the non-M-Sport bumper: https://www.slybrackets.com/store/SL...LLE-p590976797 Last edited by jkoral; 07-19-2024 at 11:35 AM.. |
07-20-2024, 09:04 AM | #5 |
Rep 582
Our front plate is held on by double stick foam tape. It has been on there for over a decade. Came from the factory that way as we an ED.
Westside Guy6743.50 |
