Go Back   BMW E39 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Video + PC Gaming / Computing
      07-28-2011, 06:38 PM   #1
Nedim
Nedim's Avatar
Drives: 2007 BMW 335i
Building a new computer (help)
Hey guys
I want to build my own computer, and I have never done it before. Recently I upgraded my stock computer and put in a new video card (MSI 460 gtx Cyclone) and a thermaltake 850W power supply.
I want to order a new case, motherboard, and possibly a new processor (my current one is AMD Phenom x4 3.0ghz)
I want to do SLI as well so should i get another MSI card or something else?
The 460 clyclone is a pretty thick card, which motherboard should i get so that i can put 2 of them?
Also, what kind of a fan should i get to keep everything cool?
Thanks
      07-29-2011, 08:43 AM   #2
UltimateBMW
UltimateBMW's Avatar
401
Drives: MP4
Your options are endless.
I recommend reading reviews on the mobo. And looking at hardforums.com for general info and hidden customer reviews.
Otherwise, your general setup should probably be an i5 2500k, on a LGA 1155 socket mobo with a P67 chipset or X68. Most mobo's support SLI and while spacing isnt always the same between brands I don't think that will be a big issue to worry about. You will also inevitably need new ram if you are going up to a DDR3 mobo. In which case the sweet spot is 8GB of DDR3 1600 (PC 12800) ram. Top brands are G.Skill, Corsair/Kingston, and Crucial.
That should help get you started.
But here are some things to be aware of for upcoming tech.
Intel will release it's new Ivy Bridge chips in Q1 2012, this will bring with it a new chipset (X79) and a new high end socket on the mobo (LGA 2011). These new intel chips will be a major step forward, and will use Tri-gate transistors (3D transistors). Also, AMD should be releasing a new line of Graphics card in September with nVidia following shortly thereafter in late Q4 or early Q1 2012 with their next gen product lineup. And lastly, with the new intel chipset and new graphics cards will come full adoption of PCI-E 3.0, USB 3.0, and the new Thunderbolt transfer medium from Intel.
So I personally am waiting to build a new machine until LGA 2011, and PCI-E3.0 are out on the main market. Which won't be too much longer.
      07-29-2011, 08:46 AM   #3
UltimateBMW
401
Drives: MP4
One other thing, generally when using SLI you will want to use 2 of the same card (type and brand). This isn't to say that using 2 different cards isn't possible or appropriete but sometimes they can do wierd things and not get along that well.
Here is a sample build I made off NewEgg:
      07-29-2011, 09:52 AM   #4
Nedim
Nedim's Avatar
Here is what i have so far.
processor: http://www.newegg.com/Product/Produc...82E16819115072
cards: MSI 460gtx cyclone
motherboard: http://www.newegg.com/Product/Produc...82E16813130606
Ram: using ram from my existing computer (8g)
Power supply: thermaltake 850W http://www.bestbuy.com/site/Thermalt...0850&cp=1&lp=1
(not sure if its good enough)
And I need a good case, open to recommendations
with all the new stuff coming out later can i just switch out my processor and the cards on the MSI board?
And i can go with a more expensive setup, my budget is around $1000
      07-29-2011, 10:51 AM   #5
ragingclue
One cam is enough
ragingclue's Avatar
130
Drives: VF
About the RAM, what is your "existing" RAM. This may be an area where you'll have to upgrade. Is your existing RAM DDR3? What are its supported freqs and timings? Do you know of any issues with that Mobo and certain types of RAM? Mobos I have used in the past were tempermental with certain manufacturers or certain chips, so I always check for that now.
RAM is a pretty inexpensive part of a rig build, so it's always best to make sure you do pay attention to it and don't skimp.
Also, the overclock.net forums have a proposed build subforum, and build logs and stuff.... There's a lot of good information there about what builds are great ideas (to include bang for the buck and unforeseen compatibility issues). Check it out if you get a chance.
      07-29-2011, 11:10 AM   #6
Nedim
Nedim's Avatar
Thanks i will check out that website
Here is what i have for ram
Ram: x4 =8g
Installed Enabled Size 2.00 GB
Form Factor DIMM
Frequency 1.3 GHz
Slot DIMM1
Manufacturer Micron
Type
Type Details -
Total Bit Width 64 b
Data Bit Width 64 b
      07-29-2011, 11:50 AM   #7
UltimateBMW
401
Drives: MP4
CPU's and their socket are mutually exclusive since the number of pins and geometry changes.
PCI-E 3.0 will be backwards compatible however with the current PCI-E 2.0.
Basically, your GPU will work but it won't get the benefit of it. Your proposed CPU will not work with a newer LGA 2011 socket mobo. The CPU posted is a LGA 1155 only. Can't answer the RAM without at least the PC number.
      07-30-2011, 05:52 PM   #8
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
i remember those days; building endless computers for people.
Good luck with the build. It is not too difficult.
      07-30-2011, 06:08 PM   #9
Nedim
Nedim's Avatar
http://www.newegg.com/Product/Produc...82E16813131730
I think i will be going with this motherboard...
just a quick question.
Since i am swaping my old hard drive into the new computer, windows 7 will boot up right?
      07-30-2011, 07:09 PM   #10
UltimateBMW
401
Drives: MP4
Looks fine to me. A little on the higher price side though, if you are ok with that. I don't see an issue with running your old harddrive. What type of connection did it use? Did you keep it de-fragged regularly? Any virus issues?
I typically use the point of a new build as a 'spring cleaning' by getting a brand new fresh harddrive with a fresh install of my OS on it. As long as you keep your old drive around to reference the files, the choice is really up to you.
      07-31-2011, 02:24 AM   #11
Nedim
Nedim's Avatar
I dont know what connection it is, because i dont know much about computers. And yeah, the computer is defraged regularly. Will have to scan for viruses and double check. I dont really understand the thing with the SSD and how to transfer the OS to it so it boots faster..dont really need that though
      07-31-2011, 11:54 PM   #12
Nedim
Nedim's Avatar
Here it is... http://www.amazon.com/gp/registry/wi.../2Z5VTQS82FTCO
It took a week or so of researching and stuff.
Let me know if theres something i should change.
      08-01-2011, 10:18 AM   #13
UltimateBMW
401
Drives: MP4
Not too bad. I have a few questions though.
First, you have 2 different sets of Ram in your list. Not sure you'll need 16gb, it wouldn't hurt, but you could get away with only having 8gb in 2sticks. I'd also buy all the same type of ram, and not 2 different brands if you wanted more.
Secondly, what helped you choose that mobo? I've never been a big fan of the Fatal1ty branded products, and it is a bit pricey. There are some other options from AsRock that are better priced. It also is a p67 chipset. I've seen some z68 for less $. Here are 2 from AsRock.
$185:
http://www.newegg.com/Product/Produc...82E16813157250
$160:
http://www.newegg.com/Product/Produc...82E16813157229
On the graphics card, I think $200+ is a bit high for a GTX460. You could get a GTX560 for $190ish.
http://www.newegg.com/Product/Produc...82E16814130661
A GTX560ti would be about $30 more if you price shop for it a bit. I haven't taken the time to read any compatibility reviews on any of these components. If your previous component choices were based on that then it might not be bad to stick with that. But your graphics card shouldn't have any real compatibility problems.
Last edited by UltimateBMW; 08-01-2011 at 04:06 PM.. Reason: Corrected wrongly named chipset.
      08-01-2011, 02:41 PM   #14
Nedim
Nedim's Avatar
Secondly, what helped you choose that mobo? I've never been a big fan of the Fatal1ty branded products, and it is a bit pricey. There are some other options from AsRock that are better priced. It also is a p67 chipset. I've seen some x67 for less $. Here are 2 from AsRock.
$185:
$160:
there is 2 different ram because im not sure which to get.
i just think the motherboard looks really nice lol
and im thinking about getting the 580 card. http://www.newegg.com/Product/Produc...82E16814130587
      08-01-2011, 03:47 PM   #15
UltimateBMW
401
Drives: MP4
I just took a look at the RAM, I'd say go with the G.skill.
Here is the same stick on newegg, with a $20 promotion price cut. Pretty nice.
http://www.newegg.com/Product/Produc...82E16820231445
The G.skill has better timing and with that promotion seems to nudge it over the top.
      08-01-2011, 03:57 PM   #16
KGB7
Crazy Russian Bastard
KGB7's Avatar
Drives: 01 740i sport
You want a mobo with P67 chipset, NOT Z68.
http://www.newegg.com/Product/Produc...82E16813131703
http://www.newegg.com/Product/Produc...82E16813128478
B
M
W
      08-01-2011, 04:08 PM   #17
UltimateBMW
401
Drives: MP4
Originally Posted by KGB7 View Post
Can you elaborate as to why you think so?
      08-01-2011, 04:14 PM   #18
KGB7
KGB7's Avatar
Z68 is the enthusiast chipset for LGA 1155. It pretty much has all the functionality of P67 + some.
Here is a decent review.
http://www.tomshardware.com/reviews/...hing,2888.html
Because he has no use for the +some. He wont be using GPU that is built in to CPU, unless he is not using a discrete VGA.
Nedim
Its always best to perform a fresh install of Windows when you are switching motherboards.
B
M
W
      08-01-2011, 04:20 PM   #19
Nedim
Nedim's Avatar
Can you explain the difference of the board? i plan on getting the nvidia 580 card now
instead of the msi 460 sli
      08-01-2011, 04:23 PM   #20
UltimateBMW
401
Drives: MP4
Nedim
I would agree, if the prices weren't already so comparable.
At this point, I don't think it really matters which one he chooses.
      08-01-2011, 04:25 PM   #21
UltimateBMW
401
Drives: MP4
From what I remember, the only big differences are the z68's support for integrated graphics, and a SSD booster. Neither of which you need, but alternative mobo's aren't that much cheaper than what you were looking at.
      08-01-2011, 04:29 PM   #22
UltimateBMW
401
Drives: MP4
This seems like a decent price point lower, if going with P67.
$160
Amazon:
http://www.amazon.com/ASRock-P67-Ext...2234258&sr=1-1
Did you have any specific preference to your board selection KGB?
