E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > E90 Car Alarm
      05-10-2005, 08:21 PM   #23
Nathan
Nathan's Avatar
Drives: 2010 X5 3.0
what is the installation procedure? heck i'll put it in myself if its simple.
      05-10-2005, 08:35 PM   #24
RichReg
RichReg's Avatar
Drives: 2015 435Xi GC & 2000 323Ci.
Well, for the E46 you first have to remove the microfilter from under the hood first. Its just behind the dashboard, all the way in front. Then theres a predrilled spot for you to mount the siren and connect it.
In the trunk, behind either the left or right panels behind the wheelwells, is a spot for you to mount the tilt sensor. Then finally, you open a little compartment in the overhead inside the cabin where the courtesy lights are and connect the control module to a pre-colored wire harness. That's basically it.
But then this all has to be set in motion by the dealer, who still has to activate the alarm ($$$$). And once again, we're talkin' E46 here...things may have changed.
      05-18-2005, 12:09 PM   #25
BMRu4ia
Drives: 2013 X3 28i VR
i like the two way feature of the compustar, but then you have to carry around the bmw fob, compustar alarm remote and the two way device. seems like a lot to carry around. I'm all for the extra protection though. I wonder if you can just have the bmw fob programmed to eliminate carrying two remote fobs? if anyone know let me know.
I do like the idea of the simplicity of just a plug-n-play factory alarm, rather than an aftermarket where they have to cut and drill into my new baby. -might void some electrical warranty down the road.
      05-29-2005, 01:51 PM   #26
ryce2go
Drives: 335 Coupe
i called pacific yesterday, the guy quoted me $300. so i told him i saw it on the forums for $237. He said oh, you have to get the from online at pacficbmw.com
and he said it is back ordered or out of stock, it wont be in until june or july.
is pacific the cheapest around?
      05-29-2005, 02:02 PM   #27
TwinPowerF30
TwinPowerF30's Avatar
Drives: 2008 335i Coupe
what 2 way device
you just carry the bmw fob and the compustar fob
      08-11-2005, 10:37 AM   #28
deez330
Drives: 2017 F80 M3 Comp, 2014 F15
2015 BMW X5  [0.00]
2006 330i  [0.00]
i'd rather not get the bmw alarm and just get the compustar with remote start, altho its annoying to carry around two key fobs but i think its worth it.
hey has anybody successfully installed a compustar with remote start on their e90?
i wasnt sure if remote start would work on the e90 because of the push start ignition, which requires the key fob in the slot
for those who have installed the compustar with remote start
how much was it?
does it void the bmw warranty?
thanks
      08-11-2005, 10:41 AM   #29
CC 330i
CC 330i's Avatar
44
Drives: 330i SG/Blk/Alum
It's a little different install in the E90. Here is my DIY. I would be happy to fax the official BMW instructions to anyone with the kit that needs them.
http://www.e90post.com/forums/showthread.php?t=1487
      08-11-2005, 07:07 PM   #30
LEDZEP
LEDZEP's Avatar
418
Drives: 2009 E70 & 2011 F25
There have been other threads on this, but here's the scoop: It's an option. I had it installed for $455 at the dealer.
      08-11-2005, 11:02 PM   #31
Hunter399
Hunter399's Avatar
325
Drives: F90M5
goto Circlebmw.com
They have good prices... Cheaper than Pacific.
      08-12-2005, 12:49 AM   #32
Imperial
Imperial's Avatar
Drives: '06 330i
at the risk of sounding redundant, what specifically came with that install? Is it the siren and everything, too? My dealer said that there wasn't any kind of audible alarm, just a power cutoff or some such (I wasn't listening too carefully) but I found that hard to believe...
2006 330i 6MT - Black Sapphire Metallic - Terra Leather - ZSP - ZPP - iDrive - Sirius
      08-12-2005, 08:00 AM   #33
Frank_NJ
///M Specialist
Frank_NJ's Avatar
Drives: E30 M3, E52 Z8, G83 M4Cx
In the box is the following:
Siren
Bracket for Siren
Hood ping switch and bracket
Interior Motion Sensor
Bag with screw and nuts
2023 M340ix my Daily Driver
G83 M4CV, F80 M3 CS, E30 M3, Z8, other various BMW's
Ferrari F8
      08-12-2005, 09:38 AM   #34
330i06
Drives: 2006
how much was it?
thanks
I'm was also wondering the same thing. Compustar with a remote start would be sweeeet. If I have a compustar installed why would I still need to carry the BMW remote?
      08-12-2005, 09:55 AM   #35
CC 330i
CC 330i's Avatar
44
Siren
Bracket for Siren
You can see a picture of each item in my DIY. First picture.
e90post
