10-25-2023, 08:39 AM | #1 |
Rep 238
Anyrecommendations for electric power washer?
I’m looking for an electric power washer used only for sprained down the car and also cleaning the wheels. I don’t want to break the bank. Anybody have any recommendations?
Thanks! |
10-25-2023, 09:16 AM | #2 |
Rep 144
For your limited use, sounds like a $100 or less unit from Amazon or Harbor Freight would be fine. I've been using a $100 unit from Amazon for the past year and it works perfect for my use (car washing only). I have upgraded the hoses/fittings/nozzle-gun though.
For a bit more money, $300-$400 range, Active 2.0 units have good reviews. |
10-25-2023, 09:36 AM | #3 |
Field Marshal
6757
Rep 1,832
Posts Drives: '08 E92 M3 Join Date: Jul 2010
Amazon 4.5 stars with 55,000 ratings. The SunJoe SPX3000 is what I have. Amazing value and quality for $131 deal price. Will clean your brick and driveway too.
. https://www.amazon.com/Sun-Joe-SPX30.../dp/B00CPGMUXW .
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
Pauly Wauly4131.50 ///M Power-Belgium69194.00 |
10-25-2023, 09:39 AM | #5 | |
Rep 238
I also have ceramic coating as well. Last edited by james1138; 10-25-2023 at 09:46 AM.. |
10-25-2023, 09:43 AM | #6 |
Rep 113
I have this exact model, and I'm very happy with it.
I power washed my deck a couple of years ago (which is huge, 48×20) plus the privacy railings without any fuss. It gets used at least a couple of times per week, and I never had any problems with it. https://snowjoe.com/products/sun-joe...ressure-washer
“Straight roads are for fast cars, turns are for fast drivers.”
DrFerry6757.00 |
10-25-2023, 09:46 AM | #7 |
Rep 113
No, it's not too powerful for the car.
10-25-2023, 09:50 AM | #8 |
Field Marshal
6757
Rep 1,832
Not with the lower powered wider nozzle(s). Comes with 4 different nozzles as well as mixing tanks for soap. As with any pressure washer when washing a car keep the wand and nozzle a reasonable distance from the target surface. The pressure drops off with the square of the distance if I remember Bernoulli’s equation correctly. The SunJoe is not a steam cleaner and uses cold water input from a garden hose. See Amazon comments at the link above for more car cleaning information too.
10-25-2023, 10:57 AM | #10 |
Rep 260
Another vote for the Sun Joe. I have the same model and used it for a couple of years now without issue.
Pauly Wauly4131.50 DrFerry6757.00 |
10-25-2023, 11:15 AM | #11 |
the me
363
Rep 327
I have a Kranzel, but would buy this now. The new Active 2.0, with what ever accessories package you want.
https://shop.activeproducts.com/coll...-washer-m22-15
01 Z Coupe, 5MT, SB, not much else
08 M3 Coupe, 6MT, JB, not much else 21 M2c Coupe ,DCT, SOM, not much else |
10-25-2023, 01:45 PM | #12 |
Rep 1,916
I also have a Kranzle (K 1122TST). I bought it over six years ago and it hasn't missed a beat. If I were buying today, I'd likely still buy Kranzle, but would look at a portable unit since they're more versatile.
I know the big box store electric pressure washers are a favorite on this site, but I couldn't get there. Bought a SunJoe initially and it leaked out of the box. That was all I needed to see to go in another direction since I was on the fence to begin with. Anyhow, like most things YMMV. |
10-25-2023, 07:03 PM | #13 |
F15 daddymobile
2434
Rep 3,580
I'm running an Active and like it. I would recommend that whatever PW you buy, invest in better attachments (gun, nozzles, QCs, hose). It will make your washing experience enjoyable.
10-25-2023, 08:50 PM | #14 | |
Rep 169
10-26-2023, 05:55 PM | #15 |
Rep 177
Posts Drives: BMW X5 xDrive40i Join Date: Jul 2023
I have a lesser Sun Joe model. SPX-2700. I got exactly what I paid for. Not much. Pressure’s fine though. But let’s say at this point in my life, I’m used to much higher quality tools/accessories/connectors. I’ll cuss it through next early spring and then do a little more research.
10-27-2023, 07:32 AM | #16 |
Rep 113
On mine, you can only use one tank at the time. I just turn the knob to whatever tank I want to use.
11-07-2023, 09:39 PM | #17 |
Rep 134
Posts Drives: 2021 M2 Competition Join Date: Dec 2019
I will add another vote for the Active 2.0. It has a really good pressure and water output for washing cars. I added a mosmatic stubby sprayer, 40 degree nozzle, kobrajet hose and MTM foam cannon for a nice setup.
spammysammich1885.00 |
11-08-2023, 11:22 AM | #18 |
Rep 915
Posts Drives: 2019 M550i Join Date: Aug 2018
whatever you do don't buy karcher. I like the thing but you need adapters cause it uses proprietary connections. Didn't realize this until I had it for a while and wanted to get a foam sprayer and stubby gun.
11-08-2023, 02:21 PM | #19 | |
Rep 1,916
Retired: 2018 BMW M3 CS, 2018 BMW M3 ZCP, 2016 BMW M3
11-08-2023, 07:46 PM | #20 | |
Rep 134
Sun Joe and Karcher will not produce a flow of 2 gallons per minute. |
Clark_Kent2301.50 spammysammich1885.00 |
11-08-2023, 08:23 PM | #21 | |
Rep 4,023
Works great for my needs. |
11-08-2023, 10:49 PM | #22 |
Bergspyder
1559
Rep 1,243
I have and love the Harbor Freight one....but THIS is what makes it the tool you want.
FOAM CANNON!!!!! https://www.harborfreight.com/premiu...non-58131.html
