12-28-2013, 03:59 PM | #23 |
Rep 13,003
I see that BMW pulled a fast one with their cheapo Business Navigation (the first time since the E46 in the USA) standard and $2500 for the Professional Navigation.
12-28-2013, 04:08 PM | #24 |
Rep 2,672
Dang! That much for this experimental vehicle and inconvenience of severely limited range and space. What am I missing? How long before one breaks even? Tesla is laughing pretty hard.
12-28-2013, 05:34 PM | #25 |
Rep 1,061
Any idea what's on page two of the price list?
FWIW, the pages are numbered, but page 2 is missing in the attached .pdf.
Might be a glitch in the original file generation, but more likely, it was purged from the document prior to posting (or, someone messed up!?). Thoughts? |
12-28-2013, 06:28 PM | #26 | |
Rep 1,061
Their entire purpose in life is different...trying to compare them is futile. IF you need a compact, comfortable car for running around the city, you'd consider the i3. Almost anyone, at least in the USA, is likely to have a second vehicle for those longer trips, or race day, etc. Or, you can buy a package from BMW to ensure you have a suitable gasoline powered vehicle for your needs when the i3 won't work. That you may not have a need for a vehicle like this is no reason to knock it for what it does do. |
12-28-2013, 08:07 PM | #28 | |
Rep 9,134
12-28-2013, 08:39 PM | #29 |
Rep 1,061
If you're never going to get out of the city, the i3 may be more practical. It will not have the same fun factor if you can and will take it out of the city, though. Probably a loaded question. They are designed for two very different purposes. The M may be sitting in traffic, wasting expensive fuel most of the time. Gasoline is very likely much more expensive/mile driven than electricity to recharge the thing.
12-28-2013, 08:50 PM | #30 | ||
Rep 2,672
12-28-2013, 09:58 PM | #31 | |
Rep 1,061
SOmeday, we may have the infrastructure and reliability and range with fuel cell powered electric vehicles...first ones for limited release are likely to come in 2015. But it will be a long time before they are able to be refueled anywhere easily. If you can only support one vehicle, and are concerned with efficiency, diesels are usually better than gasoline powered. They can be high powered, but they still don't have the allure of racing engine speeds and engine sounds people associate with a performance vehicle. It all comes down to your needs, and the conditions and restraints you need and want for your specific application. I have a gasoline powered BMW...I would very much have preferred to get it with a diesel, but BMW chooses not to sell it that way in the USA. The majority of my driving is short trips - not very good for an internal combustion engine. I plan to keep it, but am seriously considering augmenting it with an i3 that really doesn't care about short trips and won't care about polluting the oil with the short trips or corroding the exhaust system, or taking awhile to get comfortable. With the i3, you can condition the interior while it is still parked, and ideally, while still on the charger, so you leave with a fully comfortable cabin, and a full charge on the batteries. Trying to do that with an internal combustion engine, and you'll waste a lot of fuel, and run time on the engine. You only get to spin the crankshaft and move those pistons around so many times...ideally, that only happens while you're moving, and only a little bit while stopped. An electric car doesn't really care. |
12-29-2013, 07:16 AM | #32 |
Rep 1,417
Volkswagen Canada: If you drive less than 25km /day you should not drive diesel.
http://www.theglobeandmail.com/globe...rticle4099688/ But again short distance is also bad for gas powered hence hybrid or electric is better. The idea is consumer choice more the better, the market will decide. Another viewpoint is occupant safety in a crash. Generally, a larger vehicle is preferred. As the streets are clogged with more vehicles one would expect more accidents. |
12-29-2013, 08:10 AM | #33 | |
Tom Moloughney
44
Rep 243
Check your electricity bill to see what you are paying per kWh if you don't already know. Chances are if you live in a major metropolitan area you are paying more than the average American though. Here in NJ we pay 17-18 cents per kWh so it would cost me about $4.00 to drive 100 miles. But that would be if I didn't have a solar array which makes all my electricity so I can drive my i3 as much as I want without worrying about refueling cost!
Tom Moloughney
My BMW i3 Blog |
12-29-2013, 10:05 AM | #34 |
Rep 2,181
Drives: .
Garage List 2018 Audi RSQ3 (8U) [0.00]
2022 BMW X3 xDrive3 ... [10.00] 2015 BMW M235i (F22) [10.00] 2017 Mini Cooper S ... [0.00] |
The price is not bad for the advanced technology in the car.
12-29-2013, 10:59 AM | #35 |
Rep 1,061
FWIW, all internal combustion engines can have problems if they are continually used for short trips...both for efficiency and longevity, they only work best once they are fully warmed up, and a short trip may get the temp gauge up to full, normal value, but it takes awhile longer at that temp to purge it of unused gas, water and other byproducts of that combustion process...thus, electric really is a path to longevity if the car will be used in that manner. A hybrid may or may not end up better, as a plug-in hybrid that is requested to accelerate greater than a certain rate, or exceeds the battery capacity, or drive at a higher speed, the motor may come on, and it may end up with the same short trip problems of a normal car.
Battery tech is improving...waiting for a few years may give you a battery replacement with much greater energy density and thus range, or, a savings in weight, which is equivalent, not counting the wear improvement if the whole package becomes lighter. Short trips with a diesel, especially in colder temperatures, will wreck havoc with the battery life...it takes a fair amount to turn over a diesel when cold, and short trips may not recharge it fully; eventually, you have a dead battery. We may never have a vehicle that does everything well. Just like you wouldn't expect a car to carry the same load as a big pickup truck, you shouldn't expect a car optimized for city use to carry you to grandma's house across many states. If your pattern of use matches, the i3 will fill that need for transport very well...if it doesn't, you either will have a second vehicle, or forgo the benefits of that platform and make compromises. Your choice, your pocketbook. Just like a pair of pliers will remove a nut, the proper sized wrench does it better and the nut will look better and last longer. |
02-18-2014, 05:55 AM | #37 | |
Rep 18,754
But with that said, why does one need a car for true city life anyway? Most cities offer excellent public transportation, or city dwelling usually means most life essentials and entertainment is a short walk away; making a car pointless. Oh, one would like a car to get away on a trip for the weekend? Then where does the i3 help in that situation with its 80 mile limited electric range? And where can you securely plug in the i3 for its over-night charge cycle? Yes, the i3 will suit some people, but the ICE-powered vehicle suits MORE of the general population needs, which makes them plentiful, and thus inexpensive to manufacture and support with common infrastructure. |
02-18-2014, 09:55 AM | #38 |
Unloved BMW Addict
86
Rep 1,185
Drives: Z3 Coupe, 3 318Ti
It's not about breaking even. It's about not using Gasoline, a limited earth resource.
02-18-2014, 10:12 AM | #39 | |
Rep 9,160
My sister moved out of the country and I bought her beater, a Mazda 3. It's fine for my current commute, but barely gets up to coolant temp on my commute and never gets full oil temp, meaning I run full synthetic and change it and the plugs much more frequently than if I had a longer commute. I frequently never sit at one light on my commute and never get above 45 mph. We also got a dog. The dog goes to day care twice a week. She really wouldn't like being in a basket on a bike, and it would make it pretty unsafe. So ideally, I need a car to get her there, which is about a four mile total commute. I also ride bikes for fun, nearly all of the trails I mountain bike at are within forty miles and many already have charging at the trailhead. The i3 can easily hold two bikes inside and I can use the HOV lanes when two of us are going. My wife's commute isn't much different than mine, and her last 135i had noticeable carbon buildup at 42k miles and we used it for longer weekend trips and road trips, so it at least got driven at full operating temps much more often. I'm sure the X1 won't be any better. Direct injection and short trips really aren't friends. Why add a second car to the mix when we could get a city car? If I go troll a Ford F350 site about how I think driving in cities in duallies is absurd, will you go easy on Tesla and i3 threads? We get it, you don't understand, but many of us do. Last edited by Red Bread; 02-18-2014 at 10:20 AM.. |
02-18-2014, 03:50 PM | #40 |
Rep 1,061
FWIW, while my small city does have public transport, buses are at least an hour apart, and don't run that late, then, they don't go all that may places. When 9 out of 10 trips are only a mile or so each way, with a cooling off stop at the destination, an ICE is a terrible thing...the thing is running rich all of the time to warm up the catalytic converter and the byproducts are lousy. Something that works just fine from cold, like the i3, without the expense of oil changes (unless you have the REx) or sparkplugs, or exhaust system to need work really does make sense.
The studies have shown, the average commute is easily handled by the range of the i3, even in the cold, and extra range available in the warmer weather when you may more frequently wish to take a side-trip. I understand that many people may not be able to support multiple vehicles, but then, those probably wouldn't consider the i3 as an only car either. I'm still awaiting an opportunity to check one out for those things that are important to me...maybe within the next month or so, the local dealer may get one for test drives...then, I'll decide if it is a viable option. I have to fit, and my folding recumbent trike needs to as well, otherwise, it's a no-go. If both of those work, I'll probably be ordering one. |
02-18-2014, 07:27 PM | #41 |
Rep 18,754
02-18-2014, 07:30 PM | #42 | |
Rep 18,754
02-18-2014, 07:39 PM | #43 |
Rep 1,061
My trike won't fit into a Tesla, and, even with the range, trying to go anywhere an ICE can go, it just doesn't cut it. So, I'll likely have an ICE until they can get the battery technology improved for faster recharge and longer range. While Tesla's battery exchange program is interesting and fast, there aren't many of them around, with the same issue as with the recharging stations. On a trip, you can generally find fuel anywhere...it will be a long time before you can say the same thing on fast recharges. A fuel cell would be interesting, but then, you still have the issue of filling stations. And, it takes a fair amount of energy to break the H2 from whatever it is attached to, either NG, or water are the two more common sources.
01-24-2015, 09:55 PM | #44 | |
Rep 917
Drives: 2015 BMW M Sports Convertible
Leaf only has 3 year battery warranty. BMW has 8 years battery warranty, 5 years car warranty and 3 years free serving.
2015 220i M Sport convertible.
2016 225xe M Sport. Last edited by Kiwi; 01-24-2015 at 10:00 PM.. |
