12-29-2023, 11:20 AM | #2 |
Rep 2,084
I ordered a CF wheel from ebay - after 1 day of driving with it I had to return it. The contours were so sharp they were uncomfortable and the flat bottom was impractical for anything more than small turns.
In then end I just went back to my old wheel but spiced it up with M1/M2 buttons that cycle through the drive modes, CF trim and extended CF paddles. |
12-29-2023, 11:45 AM | #3 | |
Rep 198
12-29-2023, 12:36 PM | #4 | |
Rep 2,084
They can only cycle through the options that the car has (sport, sport+ etc etc). Our cars don't have the individual modes like M cars, so these buttons can't give you that. I guess sport individual is the closest we get. |
12-29-2023, 01:12 PM | #5 |
Rep 198
So, can I get them to do comfort and sport or does it have to go through eco pro? Say I wanted sport plug on m1 and comfort on m2.
12-29-2023, 01:18 PM | #6 | |
Rep 2,084
Sport - comfort - eco M1 goes left, M2 goes right. So when I start in comfort, M1 puts me in my last used sport mode (e.g. sport+ if that's the last sport mode I was in). Pressing M1 again cycles through the 3 different sport modes. M2 puts me back in comfort. I never use eco personally but same logic applies if pressing M2 from comfort mode. |
12-29-2023, 04:21 PM | #8 |
Rep 2,084
The placement of the sport/comfort buttons by the gear lever is awful imo - you have to look down from the road to press it, not good when driving. These buttons are the perfect solution to that. For the price they were a no brainer for me.
However if you don't change modes often, they won't be of much use. |
01-02-2024, 03:19 PM | #9 |
Rep 22
Attachment 3353056 In then end I just went back to my old wheel but spiced it up with M1/M2 buttons that cycle through the drive modes, CF trim and extended CF paddles. Attachment 3353057 Hmmm, your eBay steering wheel look solid on the Carbon edges….may be too solid for comfort wheel…my is full leather and top and bottom is not that much flat as yours, so it may make big difference.I feel fully comfortable on turns.
TS
01-03-2024, 02:03 PM | #10 |
Rep 3,044
Drives: 2022 BMW X5
Carismo for the win
all function work including heating pic right after install about a year ago, leather smoothed out with time
chicagofan0019327.00 |
01-03-2024, 04:30 PM | #12 |
Rep 2,084
Yeah, it was definitely too hard - not the CF but the contours built into the leather grips. Felt way too 'sport' and not enough luxury.
01-06-2024, 04:40 PM | #17 |
Rep 2,084
01-06-2024, 04:56 PM | #18 | |
Rep 206
Of course, if it had a heat button that did in fact work, that would be a nice treat to have (back). Then, knowing that an LCI cannot be coded anymore at this point, I wondered if any of these considerations combine for a different wiring situation/setup/plan/offering/set of recommendations compared to pre-LCI. |
01-06-2024, 07:06 PM | #19 | |
Rep 2,084
When you buy a custom steering wheel you get just the bare wheel - no trim, no electrics, nothing (except if its heated it has the element built in). So you would get a new wheel, and swap all trims and buttons and electric internals from your old wheel to the new. Everything is the same from your current wheel except the 'frame' of the wheel itself. You have no button currently on your trim, so that would not change. To all intents and purposes you're going to put back everything thats on your current wheel. Of course you can buy new trims at the same time if you wish, you just buy a new trim with no button. |
aug0211167.50 |
01-07-2024, 07:32 AM | #20 | |
Rep 206
mobilejo1119.50 |
01-07-2024, 12:43 PM | #21 |
Rep 2,084
No problem. I ended up doing extensive research into wheels, trims, paddles, electrics etc as I was ordering lots of stuff from China and had to ensure I got the correct parts. I've taken my wheel apart and rebuilt it numerous times now.
01-08-2024, 01:14 PM | #22 |
Rep 50
