      01-25-2013, 09:41 AM   #45
Adam135
Drives: 2014 435i
Originally Posted by sharkatron View Post
Just a heads up for anyone getting this done - on my 09 135i, the RHS plug was upside down. After disconnecting the plug from my non-LCIs, and then trying to connect it to the new LCIs, I was wondering why couldn't the plug fit into the light? I realised that for some reason, the shape of the plug could only fit into the LCI socket if turned 180 degrees - ie upside down. The lights work perfectly fine - just thought I'd let anyone know in case you started to panic wondering why your plug wasn't fitting.
Strange I don't recall having that issue. I could be wrong, though
      01-28-2013, 04:28 AM   #46
Simonnn
Simonnn's Avatar
22
Drives: 135i
Same thing happened to me! was damn confused for ages.. when I finally realised why I felt a bit stupid
Maybe its an Australian model thing..
      02-04-2013, 07:29 PM   #47
1MMM
Drives: BMW 1M
good job !!
      02-22-2013, 10:54 AM   #48
Rockstar1487
Tarnished One
Rockstar1487's Avatar
77
Drives: e92 M3
dack excellent work. i followed this to install mine just now, took about 20 mins i guess.
anyone looking to buy this kit, i got mine from ecs tuning. mine look a little bit darker than dacks. heres the part for mine #63212225282. looks amazing.
09 LMB M3
Retired: 05 MB 330i, 08 CS 135i, 17 EB M240i, 13 CB 135is, 16 ABM M4
      02-28-2013, 11:43 AM   #49
MLSavage
MLSavage's Avatar
Drives: 2010 135i AW 6MT
Pro-tip #1
The plastic plugs retaining the carpet to the body are different from the Left vs Right side of the car on a US spec 2010 135.
The left side is a 2 stage retaining clip, remove the inner, smaller, plug first and it comes out easily. I messed with it for 3 minutes before I realized I was being a numpty. The right side is a simple expanding, thick, fastener that is basically ruined once you remove it. Good thing it doesn't have to withstand much force.
Other than the plastic fasteners the job is incredibly easy and Dack's DIY is excellent.
I do have concerns over the rubber ducting not sitting flush with the body of the car in the rain channels, I'm thinking that water is definitely going to find its way into the lights. Any suggestions? Fixes?
This could be a non issue but I am very pedantic and have an anal attentive attention to detail. It's the engineer in me.
2010 N54 135i - Alpine White - 6MT - M-Sport - LCI Blacklines - 1M Mirrors - PSS - Powdercoated Black 261M
SELLING MY CAR
      03-02-2013, 01:27 AM   #50
DrGadget
DrGadget's Avatar
Australia
46
Drives: M140i F20 LCI-2
2018 BMW M140i  [0.00]
Originally Posted by MLSavage View Post
Pro-tip #1
@MLSavage: The funny things is that BMW replaced both my tail lights with updated stock lights (as Dack started out with) under warranty, and it is exactly the same in that I had to try and get the rubber further under the boot rubber. It just looks like a design weakness to me. Sorry for the sacrilege in saying BMW could possible have a design flaw.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016.
Sold: Alpine White 123d e82, 2010, 150kW/204hp.
      03-02-2013, 06:11 AM   #51
MLSavage
MLSavage's Avatar
I already have a few ideas on getting the water to flow over the rubber instead of under it.
Does Schmiedmann get their lights from BMW? I do think they are design issues so much as tolerance and molding issues. That is a very peculiar feature and has to be perfect to work correctly. That would add a lot of cost. Would be nice if they would come out with a retrofit kit for the ones that are bad instead of replacing the entire units. Because if they have to replace mine I will have to order them myself.
SELLING MY CAR
      03-05-2013, 02:58 PM   #52
rmjames007
Drives: 2009 BWM 135i E82
Where did you buy your LCI tail lights?
      03-05-2013, 08:39 PM   #53
Satalite
Satalite's Avatar
Drives: 128i
2009 128i  [10.00]
Information and pictures here -
http://www.1addicts.com/forums/showt...line+group+buy
Buy them here part number 63-21-2-225-282 make sure that its for Xenon equipped cars to get the cool LED swoosh - http://www.schmiedmann.com/1_series/...e2.htm#1944982
      03-06-2013, 03:04 AM   #54
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
I bought mine at my local German dealer.
Since US bmw dealers can not order EU parts... you need to order it from a EU dealer. Most have gotten their Blacklines at Schmiedmann
xenon LCI blackline kit... #63-21-2-225-282 for 320 euros...
http://www.schmiedmann.com/632122252...uctnumber.aspx
      03-24-2013, 08:04 PM   #55
mrHellas
BMW Enthusiast
mrHellas's Avatar
Drives: '09 N54-135i M-Sport, 6MT
So basically I got in a baby accident a while ago and my rear passenger tail was cracked! I was furious... accident was not my fault. Anyway, I figured it was a perfect time to upgrade to the LCI's as I have a 01/09 build. I should mention that the blackline LCI's from schmiedmann (model number ending #282) was a perfect P and P fit. No coding or anything. Only difference is now my daytime running lights are also on in the rear. I like this.
So without further ado... here are my LCI upgrades completed with the blacklines from Schmiedmann. They were here in Chicago in less than a week from purchase order. Fedex sent me an email to fill out an HS7 customs declaration form and that was it. Easy peasy. Great packaging and less than 20 minutes to install the pair. Longest time spent was just trying to get the gaps/spacing around the lights nice and even. I found it easiest to torque down the top of the three bolts first, then the other two.
Here's some more pictures of what to expect from Schmiedmann, and some other random stuff, if it isn't aready abundantly clear from this great DIY.
Oh, and some quick notes. Don't forget to remove the (-) battery terminal before beginning. It can't hurt and I've read reports of people getting issues without doing that. Also, I found it helped me to start on the driver side first to get a good feel for it, because my passenger side has a stupid cargo net thing which makes it a PITA to pull the cargoliner back.
Anyway... i'm beyond pleased. the new LCI's look sweet, especially the blacklines. much meaner looking. <3 Anything for my gurl! daddy treats her right!
      04-29-2013, 11:21 AM   #56
TR_BMW
Drives: 123d
Perfectly done!
      04-29-2013, 01:20 PM   #57
crystaweizen
crystaweizen's Avatar
Drives: Alpine White '08 135i
2008 BMW 135i  [10.00]
Originally Posted by Dackelone View Post
,,,turns out the sports ARE the same as the Blacklines. They really aren't as dark as I thought they be. I rather like them. So only two LCI versions... regular and Blacklines.
LCI tail lights- can you retrofit them to an 08/08 E82
http://www.1addicts.com/forums/showt...512006&page=12
where did you order your blackline LCIs from? i wrote the part numbers down, i have adaptive lighting. are the 273 and 274 corect for an 08 135i with adaptive lighting?
      04-29-2013, 02:24 PM   #58
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Yes, the #273 and #274 are the correct Blackline LCI tails to work with Xenon equipped cars. Actually they also work on halogen cars too.
But a better deal is to order BMW's Blackline LCI tail light kit. It comes with right AND left tails at a slightly lower price.
BMW p/n 63212225282
Since I live in Germany I simply bought my Blacklines from my local BMW Zentrum. A US dealer will not be able to order these bc BMW will not sell you euro non DOT approved parts. So most 1Addicts have bought from Schmiedmann. You have them most likely in less than a weeks time via FedEx.
$322 for the #282 kit...
      04-29-2013, 04:48 PM   #59
crystaweizen
BMW p/n 63212225282
So Schmiedmann will ship to united states? i just dont want to deal with the hassle of purchasing overseas if there is a chance shipping could get messed up
      04-29-2013, 04:53 PM   #60
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Yes, they ship all over the world. You might have to pay a customs fee. But most do not. Read the Blackline LCI thread to learn more. Its pretty much hassle free with buying from Schmiedmann. I would pay extra for FedEx shipping though. The German Post is very slow.
      04-29-2013, 05:01 PM   #61
crystaweizen
i will try that then here soon. so just to be clear i buy the ones for the vehicle equipped with adaptive? and adaptive is the headlamps swivelling with steering input correct?
      04-29-2013, 05:03 PM   #62
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Yes.
      04-29-2013, 06:56 PM   #63
Eddie135
N55 Commando
Eddie135's Avatar
Australia
55
Drives: 135i - DCT - N55
Is it a must to remove the - ground terminal on the battery?
I did not remove mine when I installed the black LCI.
      04-29-2013, 07:10 PM   #64
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Noop. I did not remove it on my car. I think some people just like to over think things(and play it safe). You are perfectly ok by unplugging the tail light connector and installing the new one.
      04-30-2013, 07:36 PM   #65
TS135i
piggy in the mirror
Australia
47
Drives: 2013 6MT 135i
Also you don't need to remove the rubber boot liner, just simply lift the lip.
135i Coupe N55 PPK+JB4
X3 30d LCI
      06-04-2013, 01:30 PM   #66
ChrisCote
Drives: 135i
Would LCI off of a N55 fit an N54?
Are there any changes to the housings from 2010 to 11?
1addicts
