E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > BMW Intentionally Gives Us Inaccurate Speedometers!
Reply
      02-16-2006, 10:16 AM   #1
sdorn
sdorn's Avatar
26
Drives: 2006 Jet Black 325i
Dead Thread
Kill this thread.
2008 Sparkling Graphite 535i
2009 Land Rover LR2
2003 Porsche 911 Turbo (SOLD)
2006 Jet Black 325i (SOLD)
2001 Bullitt Mustang (450rwhp - SOLD)
      02-16-2006, 10:18 AM   #2
ben1364
Drives: E90 330iA
Have you ever owned a motor vehicle that was equipped by the factory without an optimistic speedometer? This is not a BMW thing.
      02-16-2006, 10:19 AM   #3
ward
Drives: F
also the fuel gauge is pessimistic
      02-16-2006, 10:21 AM   #4
sdorn
sdorn's Avatar
26
I currently have a Ford F-150, Mustang, and I just got rid of a Saturn SC2. All three of them had accurate speedometers that matched the GPS readings exactly. In fact I have owned more than a dozen cars, both foreign and domestic, and this is the first one with an inaccurate speedometer.
2009 Land Rover LR2
      02-16-2006, 10:27 AM   #5
Geneb2450
Geneb2450's Avatar
Drives: 2006 325i
If the odometer was off (recording more mileage than what you really traveled) then I'd certainly be concerned as the warranty would expire prematurely. I'm curious what tires you run. Tire circumferance may have an effect on displayed MPH. Not sure where BMW speedometer gets it raw data from though, but changing tires to a lower aspect ratio on my Prelude had the effect you described.
325i Artic/Black Leatherette/Aluminum Trim/Sports Package
      02-16-2006, 10:30 AM   #6
obLu
obLu's Avatar
50
Drives: 330i 6MT ZSP
Meh, seems like a non-issue to me. Can't imagine getting so worked up about it that I wouldn't buy another BMW. Where's the safety issue at?
As long as I'm moving faster than the traffic around me, what do I care what my exact speed is .... until I see the trooper on the side of the road I'm rarely looking at the speedo. I'm looking at the cars around me.
      02-16-2006, 10:32 AM   #7
E90Fleet
South Africa
1312
Most european cars are like that
They have to make shure that even when the approved tire with the most tread is on the car that the spedo will not read over the actual speed ( you will find there are diameter differences between makes of tires, eventhough they are the same spec ).
If your actual speed was 61MPH and your guage read 60MPH you could take the manufacturer to court if you recieved a speeding fine.
Also remember if testing by GPS to do it on a level road. If you are going slightly downill or uphill the unit would show your speed differently than your speedo would. ( if you fall straight downward at 100MPH [ or any speed ] your GPS would show your speed as 0 )
BMW if you are reading, I need a job, Please.
      02-16-2006, 10:33 AM   #8
obLu
obLu's Avatar
50
PS. usually the odo and speedo pick up is in the transmission ... but yeah, running smaller circumfrence tires than it was designed for (+/- a certain %) will impact both speedo and odo readings. Because you're effectively changing the final drive ratio.
I'm pretty sure that as long as you're +/- 10% the automaker isn't going to take notice.
      02-16-2006, 10:36 AM   #9
E90Fleet
South Africa
1312
If you change your tire profile to a non-oem size your speedo and milage would be wrong in any make of car
      02-16-2006, 10:44 AM   #10
sdorn
sdorn's Avatar
26
I have the stock wheels and tires. The car is only two weeks old. I tested using the GPS multiple times over long stretches of interstate with the cruise control set at different speeds, and the difference was constant between the speedometer and the GPS.
Driving around Atlanta I don't have to worry about the speedometer that much because there is a lot of traffic around, and like was mentioned above you just stay with the flow. However, I often drive on interstates in rural areas where there may not be any other traffic. I need to be able to set my cruise control at a precise speed (within 1 mph) in order to make the best time while at the same time not have to worry about getting a ticket. This has never been a problem with any other car.
Plus, it is just one of those things with me. I need my clocks to be set within seconds of the atomic time. I need my speedometer to be accurate. I need my thermostat to maintain accurate temperatures. I expect instruments that measure something to be accurate, regardless of whether it is in my car or anywhere else.
Whats worse is that the car knows the correct speed. If you get into the unlock menu and display Menu 8 that shows the actual speed, it is correct within 1-2 km/h which would be great. Why would a car have the accurate information available, and then display inaccurate information? It makes no sense.
2009 Land Rover LR2
      02-16-2006, 10:46 AM   #11
dtelle
Drives: 320d Touring still in making..
it is not exact your remark about a delta between GPS speed and speedo.
all GPS chips are able to calculate the "3D" velocity if the GPS is able to track more than 4 satellites (better 5).
I am speaking from the signal send by the GPS to the computer. then the computer can of course project this velocity vector on the ground, loosing the vertical velocity. But with the rigth software on my pocket PC, i am able to read the 3D velocity (taking the GPS in my Hand and moving the GPS from my head to the ground, it is able to measure the vertical velocity (with enough satellite signal of course).
On the other Hand no idee how is managing the i-Drive in a BMW.
At least my pocket PC with his bluetooth GPS is giving me my "absolute" velocity
320d Touring, Jet Black Uni II, Lemon Leather....
      02-16-2006, 10:46 AM   #12
YV1
YV1's Avatar
Drives: 325 354 LCSW ZSP ZPP ZCP
2006 325  [0.00]
2006 X6  [0.00]
2000 Saab 9-3 SE  [0.00]
2001 GS 650  [0.00]
Even your GPS is not 100 % accurate. Read the GPS manual, it is on it. Your BMW speedometer has a 5% error. There is like 1-2 % diference on your speedometer betwen brand new tires and worn out tires. It is impossible to do it better than this. Why would any cop give you a ticket for less than 9 miles?
325 silver black ZSP ZPP ZCP PDC CA XENON
Saab 9-3 SE 2000
C240 1999 sold
e36 328 touring 1998 sold
e39 540 1997 sold
Toyota Supra Turbo 1994 sold
Porsche 911 1989 sold
      02-16-2006, 10:48 AM   #13
obLu
obLu's Avatar
50
Hahaha, that's the real crux of it; my wife's the same way ... if she knew the speedo on my car was that off she'd freak too. I probably shouldn't tell you how much time the car's clock looses per month should I?
      02-16-2006, 10:48 AM   #14
shragon
shragon's Avatar
i agree it's off too. around my work, we have a couple the electronic speed limit signs which tells you how fast you're going and to slow down if you're going to fast. i was going 30 mph in the 325i, and the speed on the sign said something like 27 or 28 mph.
      02-16-2006, 10:49 AM   #15
SteveMD
SteveMD's Avatar
196
Drives: 2016 F10 535i MSport
Next on E90Post.com: The orange dashboard lights are too orange.
Seriously, the speedo can be upto 10% in error and still be legal.
I don't know about our E90s but when I put a bigger wheel tire combo on my Suburban, I had the ECM reprogrammed to reflect the new size. Speedometer is accurate (compared to my Garmin 330 GPS).
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      02-16-2006, 10:53 AM   #16
sdorn
sdorn's Avatar
26
In Georgia, cops won't bother pulling you over for 9mph over the limit. Most won't give out tickets for less than 14mph over the limit, as they don't go on your license anyway. When I travel on rural interstates, I set my cruise control at exactly 82mph (70mph limit). With the speedometer in the BMW, I can't do that. I have to guess at what speed is really 82mph. It is somewhere around 86 or 87mph, but I am just guessing. Then when the limit drops to 65 or 60, I have to guess at what is 12mph over that. I shouldn't have to do that. If they can put an accurate speedometer in a used $6k Saturn, they can put one in a $40k BMW.
2009 Land Rover LR2
      02-16-2006, 10:54 AM   #17
shragon
shragon's Avatar
actually, i have no problem with the speedo being off. i tend to have a lead foot, so it may actually save me.
      02-16-2006, 10:56 AM   #18
sdorn
sdorn's Avatar
26
That is a ridiculous excuse. Who cares what is legal. They are intentionally giving us inaccurate instruments in what is supposed to be the "Ultimate Driving Machine". That is just ridiculous.
2009 Land Rover LR2
      02-16-2006, 11:02 AM   #19
akhbhaat
Drives: ///M318ti Type-R Turbo S
Originally Posted by sdorn
We need to start a campaign to get BMW to address this issue. If all the members of this board and any other boards we can get to participate suddenly started taking their cars into their dealers to complain about the speedometers, that would cause a huge backlash at BMW. It might be enough to get them to fix the problem. Sending letters to BMW would also be a great idea, like one every week.
Yeah, you're definitely a first-time BMW owner.
      02-16-2006, 11:03 AM   #20
obLu
obLu's Avatar
50
Me thinks your SA is the normal barely knowledgeable ticket taker and just made up some crap to keep the shop guys from laughing at him for creating a worthless work order. I highly doubt it's "intentional". I think it's more that they just don't care.
      02-16-2006, 11:03 AM   #21
JackMac
Recovering BMW Addict
JackMac's Avatar
Scotland
151
Drives: <OO (|||)(|||) OO>
BMW has done this (optomistic speedo readout) across the product range for many years. One more thing to make your car unique from the crowd.
      02-16-2006, 11:07 AM   #22
E90Fleet
South Africa
1312
Our local car magazine uses a calibrated wheel that is attached to the car to detemine speedo accuracy, and I can tell you there isnt 1 car that is 100% accurate, no matter what the make
1 or 2 cheap makes overread soometimes, but the rest always underread.
Also you can have a 100% accurate spedo on 1 set of tires,but wear those tires down a bit or change to a different make of tires and the reading will be different
Reply
e90post
