F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Mystery Leak
Extreme Powerhouse
      04-26-2024, 10:26 AM   #1
Prak903
Prak903's Avatar
198
Drives: 2018 440i xDrive Gran Coupe
Mystery Leak
Hi folks, went outside this morning and after backing up my car, noticed that there was this huge remnant of a leak underneath middle of car. Thought it was oil at first, but touched it and it was a clear, watery consistency. Put the car on ramps and saw something leaking from the front jack point hole, not sure what it could be. Coolant was below min (although not by much) so my thoughts are some hose broke, but I have not had a warning or high temps or anything of the nature. Any ideas?
Ignore the actual oil specks, those are from my 04 accord
      04-26-2024, 10:50 AM   #2
JayPixelF33
Drives: 2018 430i
I would suspect coolant. Have you checked the coolant lines going to the coolant tank. That is most common place for these cars to have failure
There is a recall on this so can get it fixed for “free” they will probably try to sell you a water pump or thermostat ect during the repair
      04-26-2024, 11:20 AM   #3
Prak903
Prak903's Avatar
198
I was doing some research and it looks like the recall is for th 4 cylinder engines, not the B58. Is that what you were referring to?
      04-26-2024, 12:25 PM   #4
bimmer456
Drives: 340i
Yes I had to do coolant lines on b58 didn’t get a recall notice on that and wasn’t covered under regular warranty as it’s considered wear and tear normal
Maintenance. Maybe if it happened on a brand new super low miles car they will pay for it.
      04-26-2024, 09:02 PM   #5
TX552
Drives: 2021 M340i, 21 X3
Open the hood and see if you can locate blue green coolant leak on top of the underbody panel. Then look at your water pump and hoses for white dried spots.
Prak903198.00
      04-28-2024, 10:46 AM   #6
Prak903
Prak903's Avatar
198
Thanks all. Looks like water pump is leaking from weep hole. Also noticed tensioner was very bouncy. Ordered both on FCP, going to do both while I'm in there.
      04-28-2024, 11:51 AM   #7
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
If it's water it's probably from the AC, which drains into the drive shaft tunnel.
f30post
