03-24-2023, 03:40 PM | #1 |
Rep 114
Posts Drives: BMW M3 Join Date: Mar 2019
parking sensor's not working after PPF
Hi guys,
I got my car back from PPF today and it says all of my sensors are reduced. I looked at them and there is some condensation around the sensors. Were they supposed to cut out circles where the sensors are or will this work itself out. Thanks! Also the trees are flowering purple these days! |
03-24-2023, 04:02 PM | #3 |
Rep 114
03-24-2023, 04:06 PM | #4 |
Rep 1,250
Did you get the whole car wrapped? How much did you pay? I remember years ago, I went to a cheaper PPF place and they didn't cut out the sensor holes and dust/dirt got in them and it was a mess. I didn't get any error messages though.. This was on a Tesla Model S.
03-24-2023, 04:20 PM | #5 |
Rep 114
I didn’t get the whole car wrapped, just the most important bits. This guy came recommended from my detailer which is annoying.
I’ll reach out and see what he has to say. |
03-24-2023, 04:36 PM | #6 |
Rep 114
Some pictures of the sensors. Pretty clear that the holes are not cut out.
03-24-2023, 04:54 PM | #7 |
Rep 114
Okay guys said he would cut them out.
He said typically it dries out and they work fine. He said okay to wait a few days until he has time. Any reason to try and get it done sooner? Also - any thought I should wait on the ceramic until this is done? Thanks guys. |
03-24-2023, 05:54 PM | #8 |
Rep 509
My full front end PPF had the sensor holes cut out.
Westside Guy5657.00 |
03-24-2023, 10:02 PM | #9 |
Rep 114
So I’ll take it back and he will cut them out. Waiting on that and then will proceed with ceramic.
03-24-2023, 10:16 PM | #10 |
Rep 212
That's just lazy. I've never seen any PPF shop do that. My sensors have cut outs too. Water being under the film like that would eventually cause adhesion issues later. It's good he's cutting them out, but you really need to look closely when he does. He's going to hand cut them so he can avoid re doing the whole bumper. He's going to have to be very careful to make sure he cuts a clean, perfect circle. There's a good chance they will look odd.
Most films are computer cut with sensor holes already cut out, so you get a perfect, clean cut circle for the sensors. Let us know how it turns out after he cuts the holes. If it looks bad, which I'm thinking it will, but i hope i'm wrong, then he'll need to re do the whole bumper. Don't get the ceramic done in case he does have to re do the bumper. It won't cause any issues leaving it like that for a few days, besides the sensors not working properly. My only worry would be the moisture on the PPF glue. |
achawla10189.50 |
03-24-2023, 10:34 PM | #11 |
Rep 3,929
If you look closely, the rest of his cuts look like shit as well. This guy has no idea what he's doing.
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
03-25-2023, 01:23 AM | #13 |
Rep 114
Okay thanks for the input.
I’m going to take it back to him on Tuesday and let you guys know how it goes. |
03-25-2023, 08:48 AM | #14 | |
Rep 4,365
Posts Drives: 2022 Z4 M40i, 2021 228i GC Join Date: Sep 2021
Either he is lazy or incompetent and didn’t pay attention to this important detail. |
03-25-2023, 10:03 AM | #15 |
Rep 2
03-25-2023, 10:14 AM | #16 |
F15 daddymobile
2341
Rep 3,507
many top notch ppf installers have computer cut templates for cars. however, many still do custom bulk sheet installs so they can wrap the edges and provide a cleaner install. the water under the ppf will dissipate over a week or two as most ppfs will breathe and there shouldn't be any issues. it's also very easy for a skilled installed to cut the sensor holes by hand. when you cut ppf you aren't cutting thru the film, you're scoring the top and then pulling it apart... if that makes sense. ppf shouldn't interfere with the sensors either.
that being said, that is way too much solution fluid under that ppf at the sensors. it appears he's cut the film a little uneven on the edges too? some spots have bigger gaps to the edges than others? as i say, "it's hard to find good help these days".
03-27-2023, 03:36 PM | #18 |
Rep 3,277
Posts Drives: E46 M3 Coupe/G80 M3CX Join Date: Jul 2021
My PFF covers my sensors. Most of them are good but one or two look like they trapped some lint or dirt in them and arent adhering properly. They said they could cut them out if I wanted but now Im worried they'll damage the paint. Also they would be guaranteed to get rock chips on them on the first drive home.
03-27-2023, 03:57 PM | #19 | |
Rep 3,929
03-28-2023, 05:31 PM | #21 |
Rep 114
So update.
My sensors are now working just fine. The fluid that was there is mostly gone. I took it back to the guy and he used a thin razerblade and a a needle to drain any residual fluid. He said he could score the area around the sensor and peel it off. Which seems reasonable given there is a small space where the sensor is. Also , if the PPF around the sensor was removed, there is risk of damaging the paint where it is not present. He said that in his “training” they gave the option of cutting out the sensor area or leaving it. I’ll take some more pictures later but overall I am okay with this. |
