10-08-2014, 09:15 PM | #45 |
Rep 1,711
This is a great thread. I am about to install my akra slip-on, and found this video made by EAS, showing the installation of not only the rear section, but x-pipe as well.
http://www.youtube.com/watch?feature...&v=T1aROyPuZZs |
10-09-2014, 05:33 PM | #46 | |
Rep 3,422
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
11-16-2014, 09:54 AM | #47 |
Rep 24
What a great DIY guide, Thank you!
I just bought an M performance axleback system from an associate of mine and thought it would be fun to install it myself. Then I put it off for a week thinking do I really want to do this. A friend has a lift at his house and I thought I would call in a favor. After reviewing this thread and all the comments I decided to tackle it at home in my garage.
I jacked up the car from the rear jack pads, and placed each rear tire back down on a large chunk of lumber (7" thick, 14" wide, 24" long). I also chocked the front wheels. I then threw a couple of padded moving blankets under the car on my slippery garage floor - which made it easy to slide in an out. With no help, I was able to loosen the front bands and yet keep them engaged then systematically removed the nuts from the rest of the hangers. It was easy to use a normal ratchet on the 18mm nuts on the differential hangers by the way. The last thing I did was to remove the last nuts from the rear most hanger and using my body (laying on my back, feet toward front of car) gently lowered the OEM unit onto my body. It is amazing how heavy the OEM unit is in relation the M performance unit. I gently let it down on the moving blankets and then pulled it out from under the car. I used the Lisle muffler hanger tool (GREAT TIP and worth the $20) and WD40 to remove all the rubber doughnut hangers (tip - put units side by side and remove and reinstall one at a time so you get orientation correct). I then slid the new unit with all hangers installed under the car and set the front of the exhaust tubes into the loose clamps which held surprisingly well while very loose. Then I was able to push the rear up with one hand and get one of the side rear mounts on its studs and stick one nut on with the other hand. This was by far them most challenging part of the job. Once it was self supported, I put a nut on the opposite side rear mount and then moved to the diff mounts. These went on very easily and I tightened them. Next I fully tightened the clamps at the front of the unit to the front section of the exhaust. With this done I was able to remove the temp nuts on the side rear mounts (diff mounts and front clamps held perfectly) and move the unit around to get the rear hangers situated correctly and then went around and tightened up everything. There were no hiccups and I would say actual work time was less than an hour. In fact it would be a 20 minute job on a lift - especially the second time around. That was my experience and I just want to say thanks to those of you that took the time to post this thread and all the comments. I have been on this forum for years but mostly just read and almost never comment. This is such a great resource. btw, my car is a early production 2012 e92 M3 coupe 6MT ZCP. The little screws on the lower bumper cap were standard hex heads (I think 5/16") no special tools needed. Thanks again! |
jvictormp913.50 |
02-11-2015, 03:03 PM | #50 |
Rep 473
04-12-2015, 03:14 PM | #51 |
Rep 67
Great write up and post! It helped me swap out my stock exhaust for and ACM modded unit, and it was really straightforward based on these instructions. I'm loving the nice deep rumble of the V8!
04-19-2015, 09:02 AM | #52 |
Rep 146
Thanks for the DIY. Had to put the OEM modded exhaust of my old M3 onto my new one, so I basically had to do it all twice. It was pretty easy the second time
06-17-2015, 03:25 PM | #53 |
Rep 173
On my '09 E92 all nuts are metric given that our cars are Euro. Not sure why some are using SAE sockets on Euro cars. All that are required are 18mm (front hangers), 8mm (bottom bumper support). Everything else is 13mm.
I used an ATV lift as it's wider and inherently more stable and made the job so much easier. If you're doing this job by yourself a hydraulic jack is mandatory. I would also say if you're going to attempt this DIY that you invest in this tool to help remove the rubber hangers. It will make all the difference in this job being easy or a PITA. I bought one and it just paid for itself. http://www.amazon.com/Lisle-38350-Ex...st+hanger+tool ***SOLD***Selling my Corsa Sport Exhaust in excellent condition, no winters, used less than 7K miles, black chrome tips, local pick up only. Fits E92/E93 M3 (coupe & convertible). Part #: COR1456X $1300.00 Last edited by Nice Rumble; 11-07-2015 at 08:52 AM.. |
08-26-2015, 08:18 AM | #54 |
Rep 1,247
Do those "wires" from the stock exhaust need to be reconnected to the aftermarket exhaust? Or are they not needed on aftermarket exhaust?
2009 E92 BMW M3.
08-26-2015, 04:52 PM | #55 |
Rep 173
They are small braided security cables in case the actual mounting bracket fails. The cables would hold the system from dragging on the road. Yes, they need to be reconnected.
08-27-2015, 12:28 PM | #56 |
Rep 562
+1 on the rubber hangar removal tool thingy.
man i wish i had that when i did this job
TTFS Tune | DINAN Exhaust | Bimmerworld Xpipe | OHLINS Coilovers | Challenge Carbon Trunk | Eventuri Intake | APEX Wheels | AP Racing BBK | Turner Monoball
11-15-2015, 03:50 PM | #58 |
Rep 10,680
Or are they ground wires? If so, mine are nearly broken so I will replace them or make something.
11-15-2015, 10:40 PM | #59 |
Rep 1,682
They are in fact ground wires.
12-12-2015, 02:31 AM | #60 |
Rep 875
Thanks for the writeup OP. I was going back and forth about doing this myself due to time constraints, but honestly it was rather painless. I was worried about the rear hanger bracket with the reverse torx bolts but an 8mm socket hooked up perfectly. Best thing is having the peace of mind knowing that the job was done properly. It took me a little over an hour taking my time and double checking everything.
02-08-2016, 12:48 PM | #61 |
Rep 1,369
Does anyone know the torque spec values for the clamps?
03-01-2016, 11:37 PM | #62 |
Rep 2,526
I asked Remus for their clamp's torque specs but I'm sure it would apply to OEM, too. I will update when their R&D department responds.
Any opinion on using the cheaper $15 muffler mounts to replace my cracked hangers? https://www.ecstuning.com/BMW-E92-M3....0L/ES2597169/ The OEMs are $40 each. https://www.ecstuning.com/BMW-E92-M3-S65_4.0L/ES39865/ EDIT: Aaaaaand their R&D dept. has no idea. Last edited by TWiTCHY; 04-21-2016 at 11:18 PM.. |
06-26-2016, 11:25 PM | #63 |
Rep 600
Very nice diy, was able to install an MPE on my car in less than 3 hours. And I have never done any diy before except for changing wheels and installing intakes. Thank you OP!
12-08-2016, 02:14 PM | #64 |
Rep 104
Great !
Crawled around on the garage floor yesterday removing a Eisenmann Race exhaust on my 2008 M3 that I just bought. It's a bit loud for my 55+ neighborhood and one local track will not allow it. Went back to the stock and may add a Eisenmann middle of the range later.
This write up allowed me to feel confident to be able to get this job done myself without bleeding all over the place. The suggestion to remove the hangers would not have occurred to me and while the Lisle hanger tool works, it would have been tough with the hangers on the car. Thanks for the write up and all the comment and suggestions. Doug |
12-27-2016, 12:53 AM | #65 |
Rep 981
Another bump of thanks for this great DIY. I wished i had read further into the thread and seen the hanger removal tool though... My hands are still sore from manually removing them!
2013 M3 (E93) - ZPP/ZCW/DCT
07-15-2017, 05:15 AM | #66 |
Incognito
119
Rep 566
Great DIY , was a breeze with one variation.
I have an e93 , so you need to remove the centre rear and middle side bolts for the cross bracing so it drops enough to let the exhaust out. Other than that its fairly straight forward. I have a battery operated impact wrench (rattle gun) and it broke the resistance on the bolts easy. |
