07-31-2022, 08:23 AM | #1 |
Rep 1,473
Thinking about buying a cheaper MB380SL
Has anyone owned an older MB V8? Things to look at for negotiating/haggling?
My gal has wanted a convertible and this one still has it's optional hardtop which is a plus. |
07-31-2022, 09:23 AM | #2 |
Rep 1,004
How old? I was looking at the 2005 +/- SL models at the beginning of the year, and there is a ton of info on them online. Motor mounts, roof mechanism, trunk struts, etc. Lots of very expensive systems on them that you have to be sure about. I ended up getting a very different car, not because of the Mercedes issues but because my needs changed. Would still love an SL, but buy with great care, a PPI, and some research. I think MBWorld is the forum with the most activity, which will help. Also reading through the descriptions, work performed and comments on these on BaT helps develop an understanding and a feel for better sellers.
floridaorange10126.50 |
07-31-2022, 09:25 AM | #3 |
Rep 1,004
Another tip, scope out the local mechanics before you buy anything. If there isn’t good service locally, it might not be the right car where you live. If there is good service, they can be a source of cars for sale (client cars)
07-31-2022, 10:06 AM | #4 |
Rep 1,473
It's an old skool 80 OBD nothing. It's just for my Gal to drive to work and maybe for us to go to beach every other week.
07-31-2022, 01:09 PM | #7 | |
Rep 1,473
It's a giggle fun in the sun car because Miata's are over priced and what else is out there for a simple rwd convertible. E36 has electronic top yuck as does e46 and e30 has drifto tax. |
07-31-2022, 01:25 PM | #8 | |
Rep 3,411
07-31-2022, 02:07 PM | #9 |
Rep 1,473
Nah it's ok, I get it but these older SL"s were available with a manual 5 spd back in the day and were quite common in EU as a manual. Just wished it was a eu version with TV headlights and 2.5 mph bumpers but would be more money.
07-31-2022, 03:33 PM | #11 | |
Rep 1,473
Thinking LS from a Escalade or Tahoe with AL heads and maybe a cast iron block unless I find a AL Block/head truck engine. |
08-01-2022, 09:52 AM | #12 |
Ring Leader of G8X Haters
25074
Rep 8,762
chassis have any knowledge on the R107's?
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300 |
chassis6490.00 |
08-01-2022, 02:24 PM | #13 |
Big Beaver Smile
2101
Rep 3,791
We've got an '85 380SL and it's been trouble free it's whole 262k mile life. My dad bought it for my mom in '85 and I inherited it in 2014, other than routine maintenance, it's been a great car.
You and your girl will hate the the top though. Stupid wrenches to unlatch it from the header and a crank in the back. I think my Jeep is easier. The rich ladies they were designed for probably had pool boys to do the roof for them I should also add that my 20-something kids LOVE to take it and drive around listening to my old Kraftwerk cassettes on the Blaupunkt
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
overcoil3073.50 Esteban43331.50 nyalpine907423.50 stein_325i25073.50 2000cs3495.00 chassis6490.00 GERMAN M34181.00 floridaorange10126.50 |
08-01-2022, 02:32 PM | #14 |
Rep 5,577
I think some of the older 1980's 380 MB V8 engines have timing chain issues. single / double
And maybe a well known rust issues around rear bulkhead and sills. And the fuel injections were massive and trouble prone. there is an SL newsletter, but it might be predominately for the early 60's to 1971 years. |
chassis6490.00 |
08-01-2022, 08:53 PM | #15 |
Rep 2,304
Posts Drives: 9Y0 Cayenne S Join Date: Mar 2019
No personal experience with the R107, just a lifetime of car experience.
I adhere to the unbreakable rule that there is nothing more expensive than a cheap Mercedes. Caveat emptor in extremis This will not be a set-it-and-forget-it relationship with this car. It is not the single owner vehicle wrickem talks about. You, or someone you pay, will do significant wrenching on this car. Personally I wouldn't touch it. The M116 V8 engine is prone to timing chain failures pre-1983. The solution is a double row chain to replace the single row chain. Check for this. The fuel injection is Bosch Jetronic. Pretty easy to work on, but parts might be hard to come by. Wiring harnesses will likely need to be replaced or remade due to brittle insulation. I rebuilt a 1982 Jaguar 4.2L inline 6 cylinder with L-Jetronic and the engine harness was a mess in 1999. Transmission is the 722.1, the first MB auto box. Good news is the K4A 040 variant is near the end of the 722.1 lifecycle, meaning most of the bugs were worked out during production. But is is a 42 year old transmission. It can't be assumed the torque converter, oil seals, friction discs or bearings won't need attention. Plan for transmission replacement and look for a shop that offers rebuilt units. Before you buy this car, or anything like it, read the following thoroughly: https://en.wikipedia.org/wiki/Merced...nical_troubles https://en.wikipedia.org/wiki/Merced...engine#Usage_2 https://en.wikipedia.org/wiki/Merced...25_and_K4A_040 https://mbworld.org/forums/sl-slc-class-r107-62/ |
08-02-2022, 06:09 AM | #16 |
Rep 62
R129 SL500s have 12 separate hydraulic cylinders to actuate the soft top, they all go bad. If you don't have documentation that they have been rebuilt, plan on that expense. They leak onto the seats and ground in front of the rear wheels.
Search for "Top Hydraulics" for more info. Early to mid 1990s have the "eco" insulation on the engine wiring harness that crumbles to dust with the slightest touch. |
08-02-2022, 08:15 PM | #17 |
Rep 2,304
Summary: run, don't walk, from this vehicle and anything similar to it. Unless you have unlimited time and funds to sink into it.
08-03-2022, 01:32 PM | #18 |
Rep 6,081
My buddy had a couple of R107 560SLs, in red on palomino. Lovely car. He was able to make it work since he personally knew a Mercedes mechanic and he hardly ever put any miles.
It's such an iconic car.
Former
-2008 E90 328 black/brown -2012 Lexus IS250 black/black |
