07-11-2019, 11:32 PM | #617 |
Rep 6,095
FWD...not even once.
I was hoping for a modern replacement for the 3-series as that car has become too large and numb. I'm sure this will be more fun than the A3 and A-class/CLA, but FWD simply cannot replicate the magic of the E36, E46, and E90.
Former
-2008 E90 328 black/brown -2012 Lexus IS250 black/black |
M3 Adjuster7909.00 |
07-11-2019, 11:36 PM | #618 | |
Rep 11,785
seis-speed2462.50 |
07-11-2019, 11:57 PM | #619 | |
Rep 584
A total miss without in my opinion, as the lift-back is one of my favorite features of the 4GC. |
07-12-2019, 12:13 AM | #620 |
Rep 14,141
Drives: G82 M4C X-Drive
Some people want a vehicle with a shorter wheelbase even if the weight is the same at the 3 Series. It changes the driving dynamics of the car. Not everyone wants a boat.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
07-12-2019, 12:15 AM | #621 |
Rep 14,141
Ditto. FWD is a huge huge disappointment. The 3 is now too big. My first impression was a true successor to the 3 series but this isn't it.
Germanauto9741.50 |
07-12-2019, 01:25 AM | #622 | |
21697
Rep 8,692
I hope you're correct.
07-12-2019, 01:28 AM | #623 |
Rep 6,095
It makes sense from a business perspective as competitors are FWD. But it's just another example of BMW selling out on us enthusiasts.
Former
07-12-2019, 02:31 AM | #624 |
21697
Rep 8,692
If BMW takes this platform Electric it can be RWD or AWD.
Germanauto9741.50 |
07-12-2019, 02:56 AM | #625 |
Rep 14,141
EV's with all the low end torque makes sense to be RWD. They already have a RWD 2 Series. Why couldn't they just carry this onto the GC? I hope this doesn't mean the next 2 Series Coupe will be FWD as well.
///M TOWN21696.50 |
07-12-2019, 03:06 AM | #626 |
BMW Miniature Collector!
13796
Rep 7,999
I like the new camouflage stickers they applied!
07-12-2019, 06:01 AM | #627 |
A family of bimmers
2757
Rep 7,743
I hope he is as well. xdrive, 300hp, liftback, slotted between the size of the e46 and e90. I'm sold
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
07-12-2019, 06:54 AM | #628 | |
Rep 804
Maybe look at it the other way around: the M2 might be the only reason the next 2 Series Coupe will still be RWD and not FWD as well, so they can keep making the M2. And, for a coupe, people care much less about rear-seat passenger space. If BMW introduced a RWD 2GC with absolutely ridiculous rear-seat space, people would be just as grumpy. They just can't win. I understand that this sucks for all the small sedan/lift-back lovers in the US, but at least BMW keeps the RWD 2er Coupe/M2 around for now. |
Germanauto9741.50 |
07-12-2019, 06:59 AM | #629 | |
Rep 804
https://www.2addicts.com/forums/atta...6&d=1555948091 The way the gap circles upwards from the rear lights to the rear window, I would say it doesn't look like a lift-back, but maybe somebody with more experience in that domain can comment? |
///M TOWN21696.50 |
07-12-2019, 07:32 AM | #630 |
Ring Leader of G8X Haters
25172
Rep 8,769
Looks like the 2 coupe is still the only way to find a new old 3 series, sadly, with the compromise of only 2 doors, which won't work for some of us.
Germanauto9741.50 M3 Adjuster7909.00 |
07-12-2019, 08:23 AM | #632 | |
Rep 19,368
RWD FAAR EVs can happen in principle, but I still think it is unlikely. The platform supports AWD, so obviously you can put power through the rear wheels, but the chassis was not designed with RWD-first applications in mind. If you look at the way rear suspension is engineered for a small RWD-first vehicle architecture and compare it to the rear suspension of a small FWD-first architecture, the former typically has a stiffer subframe, more stout control arms, beefier half shafts, etc.
It can all be retrofitted to FAAR at a cost, yes, but I am not so sure it makes sense given that this platform's useful life is probably only til the end of next decade. It won't be used for the next generation of MINI vehicles set to arrive starting in 2023, and it is quite possible that the next generation X1 and X2 (which will be fine with FWD/AWD electric drive) and next generation 1 Series Sedan will be the last BMW FAAR products. EVs built on legacy platforms are most cost effective when they drive the same wheels as their ICE or PHEV counterparts. EVs built on dedicated electric platforms should be RWD-first or the manufacturer has really blown it, badly. You don't introduce cross-talk between the drive system and steering system if you don't have to, and with an EV, you definitely don't have to because you can package the motor at the rear of the vehicle very cheaply (unlike with an ICE). Quote:
https://www.2addicts.com/forums/show....php?t=1630541 |
07-12-2019, 08:54 AM | #633 |
Rep 5,187
What BMW needs to do is go back and read the R&T article from 2016 that compared the 228 to the 235 and M2 and then put the 300hp 35i 4 banger in the 2 series and call it a 230is. Limit production, drop the weight, manual transmission, RWD, loaded up with leftover M performance parts bits as standard. That would sell.
07-12-2019, 09:33 AM | #634 | |
Rep 19,368
But it won't happen since the F22 and F23 are inside their final two years of production, and there is currently only a B48A20T1 (transverse), no B48B20T1 (longitudinal). However, the car you describe could still appear as a next generation G42 product. In fact, there was an indication that there might be no B58-powered G42 at all, which would mean that a 300hp+ B48 model would be the only one available (in the US). It's not clear at this point whether this will happen or not. It is very likely that a significantly-higher-output longitudinal B48 will arrive sometime in the next three years or so though, which would mean they have all the pieces of the puzzle. |
07-12-2019, 09:38 AM | #635 | |
21697
Rep 8,692
And I mean really fast, because Tesla is absolutely killing it.
07-12-2019, 09:40 AM | #636 | |
21697
Rep 8,692
But it's still always a possibility.
07-12-2019, 09:52 AM | #637 | |
Rep 19,368
Any other new BEV entering development now, be it on FAAR, CLAR, or some other new vehicle architecture, has no chance of arriving ahead of that date. But, we know BMW has a lot more BEVs coming by 2023, and at this point it is anyone's guess what those will be. I maintain that any of those that might be built on FAAR will be front motor FWD (like the new MINI Cooper SE) and/or dual motor AWD. |
07-12-2019, 09:54 AM | #638 | ||
Rep 11,785
Instead of being grateful for what we get .. I demand excellence in the form of RWD coupe and RWD sedan like E30, E36,E46, and E90. |
