08-05-2009, 01:28 PM | #24 | |
Rep 2,736
I hope so. I'm going to see how much it costs first. If it's cheap or expensive, I'm still going to try my local dealer and see if I can get it for free lol
‘23 RRS First Edition
'22 X7 M50i '18 R8 V10+ http://www.bimmerpost.com/forums/attachment.php?attachmentid=133578&d=1204654487[/IMG] |
08-05-2009, 02:07 PM | #25 |
I can't belive this car is a 4 door family sedan.
66
Rep 385
Its possible- Normally warranty only covers things that are 'broken' but you might be able to say, my driveability is very bad and the clutch pedal does not feel right- Say you know there is an updated spring that fixes this issue... worth a shot!
08-06-2009, 07:20 AM | #27 |
Rep 442
08 E90 M3, JrzB/BB, 360 Forged 8 Mesh, H&R Springs, RPI Scoops, Eisenmann Sport Exh, VRS Lip, CF Decklid, CF Diffuser, OSS LED AE, Rear Headrest V1, '09 iDrive Controller, Euro Rear Fog, OEM BlackLine TL, MRTM Design E90 Pedals & Door Lock Studs
08-06-2009, 11:49 AM | #28 |
Rep 5,012
Hey John, what exactly the spring does to clutch effort?
I noticed the 'updated' spring is actually an EXTRA one, as the larger looks identical to the old one. Does that increase or decrease pedal effort? Or is it just to alleviate pressure at the very bottom of the pedal travel? Inquiring minds want to know. I have no problem with my clutch so will probably leave it alone, but curious about the change. Thanks man. |
08-06-2009, 07:52 PM | #29 |
Rep 46
So I've put my spring (newer) back in. It was 10 times harder than taking it out.
It definitiely feels smoother with the spring in -- it's feels like a single continuous smooth action, However, it does feel a little squishier through the first half of the travel. There's also noticeably less lateral and front to back play in the pedal at rest. |
08-06-2009, 11:25 PM | #30 |
Rep 959
I had the newer twin spring design and prefer the feel of the clutch without it. The first half of the travel felt very artificial to me with the spring in. I think I have a better feeling for when the clutch engages without the spring in place. I also just changed my pedals so that may be playing a part in the more direct response.
08-21-2009, 03:52 PM | #31 |
Rep 12
I have a sedan that was delivered in early April 09, would it have the new spring setup? If you don't know, can I identify it by the color, etc. or do I have to take it apart to see? (I have already spent too much time under the dash )
Is the part you called out the whole assembly with the springs and spring seats/links that you show in the photo or just the part number for one of the springs? |
08-25-2009, 11:42 PM | #32 |
Rep 6,125
"Part number: 35-00-6-769-442"
Is that only thing I need to order to make my 08 clutch feels like 09? I see total 3 different parts in the picture (one main spring looks exactly the same as 08). I want to make sure I order the correctly. Please help this poor soul. =)
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
09-03-2009, 04:01 PM | #33 |
Rep 425
I believe my M3 with a build date of 3/08 has the new spring in it. It doesn't have the increased pressure on the top half of the pedal travel like my 335i does. It's more of a linear feel.
Allen
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick 2016 Agate Grey GT4 PCCB LWB 2013 HP4 Competition |
09-03-2009, 04:37 PM | #34 |
Rep 5,012
Doubt it. My 6/08 doesn't have it. It started in '09, I believe. Try the clutch on a new M3 and it feels like a Civic . I must say I prefer it that way than a freaking '08 GT500 (have you tried one of those? They were lightened for '10 too), but the '08 is ideal IMO.
09-17-2009, 03:50 PM | #35 | |
The King of Speeding
19
Rep 100
Drives: E60 M5, F90 M5C
That increased pressure at the top of the pedal you guys are talking about is the sweet spot where the engagement action happens. If you're used to pivoting your foot to control the clutch you'll find the absence of this feeling foreign and hard to predict, as I did. |
09-17-2009, 09:18 PM | #36 |
Rep 230
Drives: '24 M4 Comp xDrive
OK, I'll bite. I'm going to try the spring removal. But I am holding you responsible if it sucks worse without the spring.
09-17-2009, 09:30 PM | #37 |
Rep 229
For those of you that removed your clutch spring, did you put the "piston" assembly back in place?
I wish I had taken some pictures of this. I wrapped a piece of paper and some tape around the middle to hold the two pieces together but still let it extend and contract as designed. This keeps the pedal from wiggling around as some have commented. |
09-18-2009, 07:34 AM | #38 | |
Rep 6,007
it does not keep the pedal from wiggling around. Just leave it out.
09-18-2009, 07:49 AM | #39 |
Rep 229
09-18-2009, 05:57 PM | #40 |
Rep 1,508
I you look at REALOEM, it seems like the new spring appeared as of build 9/08 (which coincidentally is when my car was built)
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates Previous: 2009 E90 M3 |
10-17-2009, 04:17 PM | #42 |
Rep 6,125
I purchased the new spring and the shop is installing those as we speak (doing suspension and exhaust install same time).
The part # I bought was one complete set (not single spring as I thought) in that gold plastic body (my 08 is in all black plastic) with spring assembly. It looks like both springs are inside (and made them into one complete set) but it's hard to see (and my shop isn't really happy with me right now so I couldn't ask him too much or taking pictures). I'll let you guys know how it feels after I pick up my car.
10-17-2009, 06:34 PM | #43 |
Rep 6,125
Installed.
Clutch pedal is slightly softer (not much) but main different feel is that after you press, you have not much pressure/feedback back from clutch pedal to your foot. It's very gentle operation. I like it for daily drive but I now understand some 09 owners complain that can't feel the engagement point. It's so smooth, I just can't feel the engagement. But I know I'll love it when I stuck in the LA traffic on 405-S.
10-21-2009, 10:10 AM | #44 |
e36s54, e70x5d
151
Rep 1,723
Just did this - EXTREMELY HAPPY - My biggest complaints about my e90m3 have been:
1. Servotronic Steering = Awful, cant turn it off, wish it felt like e46m3 2. Shifter = Synchro from 1st to 2nd, Synchro from 2nd to 3rd and sloppy light feel 3. Clutch = lacks feel and feedback This "mod" solves #3 for me and actually helped with issue #2 -- as I can feel my way into the next gear now. (waiting for the AutoSoulution's SSK and installing the heavier ZHP knob will hopefully sovle the shifting issue) Now, ... If I could only retrofit the ZCP or regular e46m3 Steering Rack into this car/ Thanks for the DIY BTW-- If you get a metal pick and insert into the back of the retaining clip and pull off -- it goes in 2.5 seconds -- its a matter of correct positioning. |
