Go Back   BMW E39 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos
      07-20-2023, 12:07 PM   #1
pistolp0440
Drives: BMW 545i
Unhappy HELP!
This is my first time on here and I am at a loss. I have a 2005 545i. While back car would crank but not start. I checked spark (spark plugs, coils, wiring) and replaced fuses and the relay. I have spark. Still had the issue and sprayed starter fluid in the intake and it would crank and start. So, after hours of youtube I replaced the fuel pump and fuel filter. Still has the issue. Sometimes it will start and sometimes it will not.
Codes it throws are: (1) P112B "DTC definition not found" and (2) P0017 "Engine Coolant Temp Sensor" - which I replaced last year.
Any ideas would be a HUGE help. Thank you!
      07-20-2023, 01:23 PM   #2
Anderson11
Anderson11's Avatar
463
Drives: 2023 BMW M4 Comp
Suggest you hit this forum E60 for technical help....
2023 M4 Comp
Dravit Grey Metallic
