M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > DRL much dimmer on driver side
      06-04-2022, 08:56 PM   #1
DigitalMio
Drives: 2020 BMW M2C
I recently bought one of my dream cars couple of weeks ago, a 2020 M2C with 7200 miles for a decent price. The car itself is great so far, wonderful power with great looks. The only issue I'm seeing is that the driver side DRL is quite a bit dimmer versus the passenger side, which I recently noticed when seeing my lights reflection off the backside of a car.
Do I need to get a new headlight? I tried asking the local BMW dealership whether this is covered under warranty, but was told that it was only covered if it's broken, not dimming…
      06-04-2022, 09:34 PM   #2
chip_dip19
Drives: 2018 M2
That looks "broken" to me
Moflow2484.50
Kikuchiyo125.00
      06-04-2022, 09:34 PM   #3
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
The dealer is full of ish, the headlight/module is covered under the factory warranty (also extended warranty for the module). I would try another dealer or push the issue with the resistant one.
However, if you want to repair it yourself, you don't need a complete new headlight, the DRL LED module is sold separately and takes 5 mins to replace.
Part number: 63117494851
      06-05-2022, 04:10 AM   #4
DigitalMio
Awesome. Thanks for the quick response! Just found YouTube video of a guy having the same exact issue as me and that replacing this module fixed it for him. Hopefully it works for me too…went ahead and ordered the part.
Poochie9107.50
      06-05-2022, 09:34 AM   #5
Sublime00
Drives: Car
But why not use the warranty to get this fixed? Unless you're paranoid the dealer will screw something up.
Moflow2484.50
      06-05-2022, 02:04 PM   #6
KevinC
your average JAMF
KevinC's Avatar
Drives: '21 M2 Comp, '19 Golf R
Absolutely get that fixed under warranty!! NFW that should cost you out-of-pocket. SA at the dealership was an idiot.
'21 M2 Comp
'19 Golf R
      06-05-2022, 02:08 PM   #7
DigitalMio
My local dealership is like 60 miles away. The part was only $150 with shipping. I rather pay out of pocket and seems like a very easy install than deal with the inconvenience.
      06-13-2022, 08:40 PM   #8
DigitalMio
So…I got the LED module and installed it, same issue. The driver side DRLs were still relatively dimmer than the passenger side. Digging around, it seems the issue all along was the DRL lens that guides the light from the module was not properly installed in the module housing… Well, at least I have an extra DRL module for later on.
      06-21-2022, 11:57 AM   #9
Poochie
Poochie's Avatar
Drives: 2016 M2
Sorry to hear the module was not the issue with your DRL but I'm not sure how the rings came out of place, maybe a physical collision shifted them within the headlight housing because there is no mechanical parts within the rings to go bad, it just simply magnifies the LEDs lights from the module. Although they might look complicated from outside, it's a pretty simple MO and easy to diagnose..
You can sell back the LED module, they move quickly on eBay..
      01-24-2023, 04:58 AM   #10
N23EEL
N23EEL's Avatar
Drives: BMW m2 competition
How did you manage to solve this? I’m having the same issue and changed the module but that didn’t fix it
Thanks
      07-30-2023, 03:50 PM   #11
rjpiston
Drives: 2019 M2 Competition 6MT
I'm having the same issue. Same halo as well. Does anyone know if there is a way to test if it's the module or not, without buying a new one and installing it?
      04-22-2024, 07:52 PM   #12
jstnf87
Drives: 2020 M2 Competition
Is there any tutorial on how to adjust the DRL rings and put them back into place? Have the same issue with my 2020 example. Just today I noticed my driver side inner DRL halo is a tad dimmer than usual.
      04-25-2024, 04:50 PM   #13
Stealth.Motorwerks
Drives: 2019 BMW M2 Competition
I'm having same issue on mine. Same inner DRL on the drivers side. Is this a common issue?
      04-26-2024, 12:10 PM   #14
Stealth.Motorwerks
DRL Fiber Optic Tube Broken
So I opened up my drivers side headlight underneath the DRL Module and the clear tube that shines the light from the LED to the halo rings was broken. Any idea if or where I might be able to find a replacement for that part?
      04-26-2024, 02:10 PM   #15
jefe2000
jefe2000's Avatar
Drives: 2018 M2 6MT
2018 BMW M2  [10.00]
As I understand it, the front headlamp assembly is pretty much sold as a packaged unit. I don’t see the halo light guide listed as a separate component on RealOEM:
https://www.realoem.com/bmw/enUS/par...N-BMW-M2&mg=63
m2
