11-19-2007, 11:31 AM | #67 | |
Rep 256
but since you put all this faith into steved we can wait for his response to your post, i expect steved to agree though. btw i take offense with your comment about american twisty roads not being as good as european ones. we have our fair share of very nice canyon roads.
11-19-2007, 02:08 PM | #68 | |
Rep 8,027
You think the 335i will be quicker on a twistie road than the S5, that's fine by me, we will agree to disagree on this one. You talk about the S5 being worse because of it's huge weight disadvantage , I'm a bit confused on that one as the European spec from each manufacturer states that there is only a 30Kgs advantage in favour of the 335i which by my reckoning isn't that huge at all. Secondly you might assume that it's nose heaviness will play a major role in stopping it corner well, yet (I hate to use figures) it's lateral grip is 0.92g compared to an E92 M3 which is only 0.01g better and both I might add are better than the 335i can manage. So it looks like it can go round corner then, now combine this with is great traction out of the corner because of it's quattro system and it's greater torque over a the lower rev range (compared to an M3) and you might start to understand why I am saying that it will be as quick as an M3 on a tight and twistie road. By the way, at no point did I say which would be having to most fun or which would I prefer to be driving. P.S. Unless the guy in the S5 is a complete dick I don't recommend you try it in your 335i if that's what you are driving as I wouldn't want you to look bad in front of your girlfriend/wife/mate. |
11-19-2007, 02:35 PM | #69 | |
Rep 256
the torque will give the S5 an edge...then again, the m3 might actually have more torque due to gearing multiplication which would render that advantage of the S5's meaningless.
11-19-2007, 03:00 PM | #70 | |
Rep 471
-Adam |
11-19-2007, 03:13 PM | #71 | |
Rep 8,027
Do you agree that the Quattro system gives the S5 a slight advantage out of the corners, if so then we can go forward with the next reason why I reckon the S5 will keep up with the M3. I have driven most forms of drive systems, be it fwd, rwd and awd and without exception awd cars are by much the easiest to drive close to and at the limits, because of this in most occasions with normal drivers involved the S5 will be easier for such a driver to use most of it's abilities, unlike the M3 driver who though his car has higher limits won't be able to use them as easily and will be no faster than the S5. The same thing applies to the GTR and the Zonda, the Zonda might be quicker but it's harder to drive nearer it's limits unlike the GTR and because of this the GTR will be all over it on a tight twistie road. That's the bare facts of the thing. |
11-19-2007, 03:15 PM | #72 |
Rep 4,128
Drives: M235i & G30 540i
Let's not bring the 335i into this. The only reason I mentioned it was to show how close the performance was with the S5 having 54 more horses against it.
The M3 has about the same power advantage over the S5 as the S5 has over the 335i and the S5 only beats the 335i by tenths of a second. You seriously think it will pull on an M3. Oh please.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
11-19-2007, 03:18 PM | #73 |
Rep 4,128
Now you are changing what you said earlier. Keeping up and pulling away is 2 totally different things.
11-19-2007, 03:34 PM | #74 | |
Rep 2,234
Audi are quoting UNLADEN weights, whereas BMW quote EU1 DIN standard, which includes 75% fuel and driver as well. The 335i weighs 1,615kg (including driver and 75% fuel) The S5 weighs 1,630kg UNLADEN. If you compared it on a level playing field with the 335i it would weigh over 1,700kg! The S5 is both LONGER, and significantly WIDER than the 335i, and it has 4WD. It is visually bigger too, and the design only emphasises it's size. It looks like it's based on the A6 chasis, and not a shared platform with the new A4. |
11-19-2007, 03:34 PM | #75 | |
Rep 8,027
This applies to both swamp2 and Smoltz, I know the M3 is an amazingly good car and agree that it's easier to drive fast than almost all other rwd cars but from experience no car is as easy to drive quickly as an Audi (which is part of it's problem) and I know how quick it can cover ground. I don't doubt in the hands of an experienced driver the M3 will when the battle quite easily but as most people aren't skilled drivers the facts still stand that on most occasions the S5 will match the M3 on these types of roads. I suppose I knew this type of statement would be received with such comments and to most here I would sound stupid, but I know what I know and I stand by what I said. |
11-19-2007, 03:35 PM | #76 |
Rep 2,234
11-19-2007, 03:42 PM | #78 | |
Rep 471
Unfortunatley, the horsepower is not the same, and the S5 weighs more and not only does it weigh more, but the US one weighs more than the euro spec one due to standard equipment. I have also driven the S5 and the E46 back to back, and there is ZERO doubt in my mind that the E46 can keep up with the S5 (I am being conservative here), and despite some of the negativity surrounding the E92, no one claims its slower than the outgoing car. -Adam |
11-19-2007, 03:42 PM | #79 |
Rep 8,027
There is much debate on other sites as to whether you statement is correct about Audi's figures. Some well informed people believe/know there are indeed the same as BMW's. But even if they are not, at most that puts the S5 85kgs more which is still only 5% more. Not that huge when you consider it has an extra 16% more power to counter that. |
11-19-2007, 03:45 PM | #80 |
Rep 4,128
I'd like to correct my post above about the S5 beating the 335i. I know Fifth Gear is mostly for entertainment, but in this video it was the other way around. The 335i beat the S5 on the track and all through the course they were neck and neck. Now you can argue about good drivers vs normal drivers all you want. With any car a better driver can beat you with less power than yours. But on a level playing field, there is no way the S5 will pull on an M3. That's just rediculous to even think so.
http://www.youtube.com/watch?v=aHj0zbhjLZI
11-19-2007, 03:46 PM | #81 | |
Rep 8,027
Oh well, clearly I stand corrected. Sorry for all of my ranting, will go and hide under a stone again. |
11-19-2007, 03:54 PM | #82 | |
Rep 2,234
And no, it doesn't put the S5 at 85kg more. That would just about cover the weight of the driver. What about the 75% full fuel tank? By no means am I entering the debate about whether the S5 would be faster than an M3 point to point. I'm merely saying that if you think the S5 and 335i weigh roughly the same then you are living in the home for the terminally bewildered. |
11-19-2007, 03:58 PM | #83 | ||
Rep 4,128
11-19-2007, 04:17 PM | #84 | |
Rep 256
taking into account my recent enlightenment on the S5's weight i stand by my previous argument. btw, i too have driven fwd, rwd, and awd cars.
11-19-2007, 04:18 PM | #85 | ||||
Rep 8,027
Now as to prove what I say is indeed correct in that the S5 is in a different class on the road to the 335i I present some comments from a roadtest back to back of the S5 vs 335i. Quote:
11-19-2007, 04:25 PM | #86 |
Rep 4,128
Ok you're right I took what you said the wrong way. I mean it basically means the same thing but as you stated it it doesn't mean you said the S5 will pull away from the M3, but anyway forget that.
Let me ask you this. How can you really doubt the M3 can pull away from an S5??? Especially after knowing how close the performance is to a 335i.
11-19-2007, 04:31 PM | #87 |
Rep 8,027
It's only close on the track where the limits of each car is easier to approach in safety, on the road where hedges, walls, trees etc are ever present then I know that the car which makes you more comfortable to approach these limits will mean it will be quick in these occasions as the S5 will be compared to the 335i and I reckon will be closer to that of the M3.
Like I said it what I personally think, i have no hard evidence to prove it will be the case other than my experience of driving lots of different cars on numerous occasions. |
11-19-2007, 04:38 PM | #88 | |
Rep 4,128
