E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Rev for Track Days
Reply
      01-23-2009, 06:15 PM   #1
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Drives: Green Bastard
Rev for Track Days
Finally, I'll know when my timing gets pulled. Chart from the Rev iphone app.
      01-23-2009, 06:42 PM   #2
satakal
satakal's Avatar
95
Drives: e46
what's the time step and duration along the abscissa? What explains the spikes? How does this relate to timing? Sorry, but I'm curious.
      01-25-2009, 09:29 PM   #3
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Every 5-6 tenths of a second. The spikes are throttle blimps I performed with boost. I shocked to see how quickly the temps increase. I wasn't testing the timing yet, just practicing some runs prior to getting the real data. I want to see how the temps impact the timing in real time.
      01-25-2009, 10:24 PM   #4
O-cha
O-cha's Avatar
218
Drives: Mcoupe
How much did the whole thing cost you? I've been thinking about getting it because it's more convenient then my laptop logger.
      01-26-2009, 07:59 AM   #5
double35
double35's Avatar
Drives: 335i
2008 335i  [0.00]
$280 ($230 hardware, $50 software) assuming you already have the iPhone.
      01-26-2009, 09:20 AM   #6
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Ocha, you'll have to update your iphone to 2.2 prior to using this software. Just keep that in mid.
      01-26-2009, 09:29 AM   #7
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Where did you buy the hardware? I thought I saw yours had cables instead of blue tooth? Is the sampling rate adjustable (.5-.6th tenths is a little slow)
That doesn't bother me(iphone broke have 3g now), $200+ bothers me. If it was 100 or less I totally would have jumped on it.
Then again it's probably the only logger you can take out on track safely and mount in a visible place on the dash.
      01-26-2009, 09:37 AM   #8
Bubbles
Bubbles's Avatar
Cayman Islands
2753
The cable plugs from the OBD port to the wireless transmitter. I agree about the price, but it's portable.
The developers are working on the timing, I've emailed a few suggestions that will be implemented on the new update. They want "car guys" to send in suggestions to improve the product. They are working on reducing the data log intervals now. I'll take a pic of my setup and post it in a bit. With your set up, $100 bucks compared to strapping your laptop in there.
      01-26-2009, 12:17 PM   #9
nicknaz
nicknaz's Avatar
3188
Drives: C6Z
Can you log everything that the ECU has access to? stuff like the yaw rates from the traction control, throttle position, steering angle?
      01-26-2009, 12:28 PM   #10
O-cha
O-cha's Avatar
218
Drives: Mcoupe
OBDII specification sensors, basically things that pretty much every car has. In other words throttle probably, yaw probably not.
      01-26-2009, 08:35 PM   #11
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Ugh, screw you Sal man, I just bought one.
      01-26-2009, 08:51 PM   #12
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Don't fight it....you can't overcome the power of the Rev.
      01-26-2009, 09:08 PM   #13
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Yea but I know as soon as the hardware ships some asshole is going to post about how you can use this cable with this Wlan interface to make yourself a $50 hardware piece that works.
In fact I'm pretty sure If I plugged one of my usb or serial OBDII cables in to a Wlan converter it would work. But it's not worth it for me to bother really.
Oh BTW my stuff is on the car, you're going to get pulled so hard next Sebring you'll think you're in limp mode.
      01-27-2009, 08:16 AM   #14
Bubbles
Bubbles's Avatar
Cayman Islands
2753
I hope so, with my rolly-polly family car.
      01-28-2009, 10:45 AM   #15
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Ahahahaha, nice sig change. BTW did you ever check out safe?
http://www.safemotorsports.com/schedule.htm
1st 30 min 1 run group 2nd 30 min another run group, then the next 5 hours of track time is totally open session.
      01-28-2009, 09:54 PM   #16
Bubbles
Bubbles's Avatar
Cayman Islands
2753
I did, but the dates are so far away.
      02-01-2009, 03:05 PM   #17
double35
double35's Avatar
Drives: 335i
2008 335i  [0.00]
Bubbles,
So where and how are you mounting your iphone? Are you putting it in the arm rest?
      02-02-2009, 06:36 AM   #18
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Originally Posted by double35 View Post
Bubbles,
I am using a proclip mount here with a tilt swivel mount here and use a power supply tap to the glovebox aux power (BMW adapter $10). It's a bit expensive but very high quality, clean and secure.
Reply
e90post
