02-23-2009, 04:11 PM | #23 |
Rep 4,737
03-17-2009, 03:31 PM | #27 |
Rep 1,973
Is any shop equipped to do an alignment on our cars? An alignment at BMW runs $200+
MDCT ... so you can drive and eat a hamburger at the same time. |
03-17-2009, 04:19 PM | #28 |
Commander-In-Chief
2204
Rep 8,949
Drives: 2023 M2 Coupe, 2020 GLE 450
Most independent alignment shops can do it. Are you asking about Norcal tuners in particular?
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
03-17-2009, 06:02 PM | #29 |
Rep 4,737
05-24-2009, 04:22 PM | #31 | |
Rep 6,918
Torque specs: http://www.m3post.com/forums/showthread.php?t=183005
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
05-27-2009, 11:24 AM | #32 |
do a wheelie!!!
156
Rep 929
Drives: E46 M3 - '72 2002 - '65 Impala
It did not take me 6 hours. I started at about 11:00 AM and was done by 2:00 PM and we ate lunch after we did the fronts and then started the rear. (following this DIY of course...)
but there was 2 of us.
~Adam
06-11-2009, 11:49 AM | #33 |
Rep 425
Your pics show a removal of the upper spring hat before wrestling the front shock/spring assembly out of the fender. This must have been a pain. Didn't the shock rod extend out?
I followed the approach outlined in the first link by keeping the assemblies intact while removing them from the car. Unbolted the entire shock from the car to avoid any contact with the body. The Autozone in my area charges for the spring compressor value but refunds the whole amount when you return them. Allen
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick 2016 Agate Grey GT4 PCCB LWB 2013 HP4 Competition |
06-14-2009, 11:39 AM | #34 |
NASA SpecE30 Racer
82
Rep 1,307
Just finished the front. I removed the three nuts at the top and dropped the whole spring/shock combo and then compressed the spring to give me more room to work. Took me about 3 hours for the fronts. The backs will be after lunch and rehydration.
King Tut
2012 BMW M3 Individual: Sold lsb.ridedomain.com 1987 BMW 325is SpecE30: spece30.ridedomain.com 2009 BMW M3 Coupe: Sold e92.ridedomain.com |
06-14-2009, 11:54 AM | #35 |
Rep 6,918
The rears are a breeze compared to the front. Should take an hour tops!
06-14-2009, 01:45 PM | #36 |
NASA SpecE30 Racer
82
Rep 1,307
Yeah it should except I was finishing up the 4th quarter after just torquing the bolts, and I notice that the H&R logo is upside down. God damn it, I put the spring in upside down. So now I get to tear it back down and do it again. It was the side with the leveler sensor too so that is even more work. I'm taking a break before tackling it again. Note to others always check and make sure your spring is in correctly before reassembling everything.
King Tut
06-24-2009, 12:23 AM | #37 |
Rep 6,107
yep ... it took us 2h to get it done ...
07-29-2009, 12:19 PM | #39 |
Rep 425
Depends on the size of your muscles and the tools you have to work with. It's a pretty typical suspension install.
I helped a friend do his springs recently and we left the front assemblies connected at the bottom while swinging the top hats out. This is much easier but requires two people. Someone needs to hold the assembly while the helper compresses/decompresses the spring. I still recommend undoing the hats once the assemblies are pointed away from the car. Allen
03-26-2010, 09:23 PM | #44 |
Rep 613
You dont need to replace the bolts. Give me a break, just put loctite back on the 3 bolts that hold the strut brace and on the main center bolt that holds the hat to the strut.
