01-06-2023, 12:48 PM | #23 | |
Rep 3,412
Not a Doctor, those are just my initials.
02-15-2023, 06:25 PM | #24 | |
Rep 870
Also, OP, this guide is invaluable. It was the absolute worst job I’ve ever done to date but your guide made it waaay better. Thanks again! |
02-15-2023, 08:30 PM | #25 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
Any coding for eliminating the CEL?
03-29-2023, 01:59 PM | #28 |
Rep 1,085
FYI. No vendors that I know of can tune "out" SAP. They just change parameters wide enough where ECU won't trip. You will need the relay and sensor on that hose plugged in. Motor doesn't need to be plugged.
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
03-29-2023, 05:09 PM | #29 | |
Rep 33
My track car runs fine (fingers crossed) with BPM Sport Stage || tune. SAP deleted, straight x-pipe + Valvetronic. |
Lienrocs704.50 |
07-18-2023, 10:55 PM | #30 |
Rep 23
Is there a reason why you can’t just put a cover plug on the valve? The same kind of plug that they have for the intake side. The only negative I see is if the temps get too high for the plastic plug but the original hose is plastic there too.
08-10-2023, 03:10 PM | #31 |
Rep 100
I'm sorry but just wanted a little clarity on this as I'm performing the sap delete while the engine is out. The two plugs that were attached from the harness to the pump need to still be plugged in? Or can I just jump the plugs to have it work?
08-28-2023, 08:44 AM | #32 | |
Rep 1,085
Here's a GT4 replica block off plate by NRW Design. You can also use OEM E36 M3 block off plates, but there isn't a place for the back heat shield to bot onto to, NRW is nicer. As for the intake block off clip, reach out to Leddy's Motorport. https://www.nrw-design.com/products/s65-cover-plates *Disclaimer: This mod is meant for motorsports use only. If you live in a state where emission inspections are required, your car will not pass.
