      08-30-2012, 07:32 PM   #23
froop
froop's Avatar
Australia
171
Drives: 08 AW 6MT E82
Sorry for the poor iPhone photos but here's a photo I took last night midway through install, and then the finished product this morning
      09-22-2012, 09:42 PM   #24
cptJLPicard
F1 Fan
cptJLPicard's Avatar
94
Drives: M2CS; F22/230i
As always, excellent write up Dackel, thanks! Do you know if the same parts would fit my Canadian 08 135i w/Xenon and AHL? Would there be coding required?
2020 M2CS, 6MT;
2017 230i, 6MT, M Track Pkg/Premium/Executive
      09-23-2012, 06:34 AM   #25
Dackelone
European Editor
Dackelone's Avatar
Germany
10628
Drives: N54 e82
Even though BMW says you need an adapter cable for early cars (cars built before Sept, '09) I have not seen anyone say they needed one! So I believe these LCI lights (either Blacklines or regular ones) are totally "plug & play"!
      09-23-2012, 08:34 AM   #26
cptJLPicard
F1 Fan
94
Do you happen to know what the part # is for the adapter? Just in case I run into with the guys at the dealership.
2020 M2CS, 6MT;
      09-23-2012, 08:45 AM   #27
Dackelone
European Editor
Dackelone's Avatar
Germany
10628
Drives: N54 e82
bmw part #61122219698 (they say you need two @60 euros each).
http://realoem.com/bmw/showparts.do?...76&hg=63&fg=95
I really would not order the cable(s)... bc like I said so many people here have installed the LCI's and LCI Blacklines with no trouble what so ever.
And here is the Blackline Kit bmw part #63212225282 (for two tinted tail lights). It is cheaper order the #282 kit vs each tail light individually. A US dealer can not order these bc the part does not have DOT approval. But as we all know... they work just fine on our cars.
      09-23-2012, 09:05 AM   #28
cptJLPicard
F1 Fan
94
Dackel, you rock!! I'll try ordering tomorrow. If they say no can do, I'll get them from ECS. Thanks again for your help
2020 M2CS, 6MT;
      09-27-2012, 01:02 PM   #29
WINDman
Hong Kong
Drives: 135i
I just ordered some as well directly from Germany
      10-27-2012, 10:09 AM   #30
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
Hey Dack! I just installed my blacklines but I am worried I did incorrectly. Did you remove one of the plastic washers off of your new lights before installing? I noticed on the original lights that one of the 3 bolts didn't have the washer on it. And now looking at it, I noticed that this washer sits a little on the seal. It is the one closest to the license plate. Do think this will cause an issue with the seal?
      10-27-2012, 11:34 AM   #31
Dackelone
European Editor
Dackelone's Avatar
Germany
10628
Drives: N54 e82
I do not think mine had any washers.
Q). is how do your tail lights fit? IF they are flush I would not worry about it. You could also try and water test them, and pull some of the inner truck carpet out and check for any leaks. But I am fairly sure mine Blacklines only had that foam gasket and no washers on the studs or threads.
Dack
      10-27-2012, 03:22 PM   #32
OrangeCrush
1236
http://www.1addicts.com/forums/showthread.php?t=708869
You can see the white plastic washers in this thread. Notice how it is missing from the one that would touch the foam gasket? I did not remove that one. I am worried that it will deform the gasket enough that it doesn't seal.
      11-11-2012, 04:37 PM   #33
fredy
Drives: 135i
Great!!
      12-16-2012, 09:28 PM   #34
chrisko
chrisko's Avatar
Drives: 2016 M3
Thanks for such a comprehensive DIY!
I just ordered mine and this has made me even more anxious to get them installed!
      12-16-2012, 10:19 PM   #35
SGM <3
Internet Famous
SGM <3's Avatar
Drives: '09 SGM 135i
I installed mine a few moths ago and just recently they started leaking and shorted all the electronics in my car
Luckily I was still covered by warranty, but just as a heads up I'd check to make sure your seals are tight if you do this yourself.
Cheers!
      12-20-2012, 10:39 AM   #36
chrisko
chrisko's Avatar
Drives: 2016 M3
Mine just got delivered 5 minutes ago. Did you have to take off those little rubber seals on the light like in the video? Or can you just leave them on? I assumed he did that because of it being a convertible or something.
2021 M2 Comp | STEK Stealth Wrapped | PSM V2 Trunk Spoiler
2022 X3 M Comp | (SOLD)
2016 M3 | AWE Switchpath Diamond Black 102mm (SOLD)
      12-20-2012, 11:35 AM   #37
Dackelone
European Editor
Dackelone's Avatar
Germany
10628
Drives: N54 e82
You leave the foam gasket on the new lights. When you remove the old tails... you will see the foam will have molded to the body opening for the lights.
Don't go crazy when you torque the new tails in place. The nuts/studs feel like they could break off IF over torqued.
Also before you snug the new tails in place... you will see you can move around the light housing some what - make sure all the body gaps are linear. Then your good to go!
      12-20-2012, 11:41 AM   #38
Section147
Good To Be Alive!
Section147's Avatar
Drives: Lotsa Stuff
Perfect instructions, Dack.
I followed each of those steps when installing mine in August and it's been all good.
      12-20-2012, 12:16 PM   #39
chrisko
chrisko's Avatar
Drives: 2016 M3
Perfect! Thanks for answering my question more thoroughly than I would have ever expected! You've been a great deal of help
      12-22-2012, 12:58 AM   #40
chrisko
chrisko's Avatar
Drives: 2016 M3
Thanks for all the help and tips, this was the result:
Love it
      12-30-2012, 04:08 PM   #41
vodycolk
vodycolk's Avatar
Drives: 2008 135i
/\ I've seen your photos on instagram haha.
Once word of caution, keep a good hand on the nuts when you take them off/put them on. I dropped one underneath all the trunk carpeting and I had to take 3/4 of it apart to retrive it.
      12-31-2012, 11:56 AM   #42
chrisko
chrisko's Avatar
Drives: 2016 M3
Haha small world, or good hashtagging on my part
Yeah, I kept a magnet at the tip of my socket just in case they slipped through my fingers.
      01-23-2013, 08:12 PM   #43
andnkuhn
andnkuhn's Avatar
Drives: 135i.N55.6SPD.M-SPORT
2011 BMW 135i  [0.00]
thanks for the great write up! you couldn't have explained it better.
I the LCI NON blacklines..i have space gray and im not a big fan of the murdered out look. I put tints on so it makes it look darker already. so i wanted more contrast and stayed with the non-blacklines...had my car been white i would def get the black lines... thanks again dack
TauK-n Tky 1. at a time///
      01-25-2013, 07:25 AM   #44
yawn
Drives: M2 Competition
Just a heads up for anyone getting this done - on my 09 135i, the RHS plug was upside down. After disconnecting the plug from my non-LCIs, and then trying to connect it to the new LCIs, I was wondering why couldn't the plug fit into the light? I realised that for some reason, the shape of the plug could only fit into the LCI socket if turned 180 degrees - ie upside down. The lights work perfectly fine - just thought I'd let anyone know in case you started to panic wondering why your plug wasn't fitting.
1addicts
