BMW M3 Forum (E90 E92)
Mporium BMW
      05-21-2012, 08:25 PM   #89
Small Yellow
Track Addict
Small Yellow's Avatar
Taiwan
110
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
Hi,
I have a 2010 model so I have the plastic green one with two springs. What I did was remove the outer bigger spring but kept the small one in. It helped reduce the wobbling around of clutch pedal a bit. I then removed the silver spring that is hooked on the clutch. Not sure if that is a good idea or not but it made the clutch lighter but for some reason felt more direct than if I had just remove the bigger clutch spring. With the big and small spring still seems like the best way to go but i dont like how the clutch wobbles around.
BMW ///M3 Coupe
Completed November 16, 2009
Received December 29,2009
      05-21-2012, 08:28 PM   #90
stefan
stefan's Avatar
Drives: M2 Comp
Has anyone with 2010+ cars done this? Any noteworthy improvement? I see how it would significantly change 2008/2009 models (pre 2010 clutch spring change).
///M Power
      05-21-2012, 08:29 PM   #91
Small Yellow
Track Addict
Taiwan
110
LOL I just posted... unless you want 2011-2012
BMW ///M3 Coupe
      05-21-2012, 08:31 PM   #92
stefan
stefan's Avatar
Drives: M2 Comp
lol... literally within minutes. It's like you read my mind. Thanks for your feedback. Couldn't remember what year went to the dual spring. Looks like 2010 did indeed get it. Thanks again. Keep up the awesome DIY work by the way!
///M Power
      05-21-2012, 08:31 PM   #93
Small Yellow
Track Addict
Taiwan
110
Originally Posted by ndog14 View Post
I really hate to bring this thread up, especially as a 328 driver *flame suit on* but my buddy and I were talking about BMW manuals a few minutes ago. We discussed how the M3 does not have a CDV as the regular E9Xs do. He said that only M3s have the clutch pedal spring but not the 328 and 335. As I am out of town I cannot go and check, but do 328s also have the clutch spring?
I would like to know too.... because if they dont why do their pedals not wobble... mine with it removes wobbles left and right and i can push it down about 1-2cm before i feel any increase in need of force to push it down further.
BMW ///M3 Coupe
      05-21-2012, 08:39 PM   #94
Small Yellow
Track Addict
Taiwan
110
Thanks, for some reason I think early 2009 and late 2008 models have the dual spring versions too... if you look at the previous posts, unless I scanned through them too quickly
BMW ///M3 Coupe
      05-21-2012, 11:27 PM   #95
stefan
stefan's Avatar
Drives: M2 Comp
Oh weird.. good to know.
///M Power
      07-11-2012, 12:30 PM   #96
cmichaelo
cmichaelo's Avatar
46
Drives: '10 E92 M3, '22 Toyota Rav4
Hi,
I test drove a used 2011 M3 this week and was quite disappointed in the clutch feel. Particularly how light it felt and which makes it hard to feel the engagement point because I can't feel the pedal pressure under my foot as I let go of the pedal.
I'm just wondering if removing that spring you mentioned would indeed cause an improvement in the pedal feel, essentially resulting in a somewhat "stiffer" clutch which I guess I prefer.
---M
2011 E92 M3 mods: Alex tune, mod'd X-pipe, MPEv2, MS intake stage 2, ESS power pulley, Monoball bearings, SSFBs, PFv3 rotors, MFactory DSv3, RE SSK, Voltphreaks Li batt.
For sale:
E92M3: BW Race muffler, front thrust arms, stock muffler, 19" Vorsteiner VFF103 rims
Z4MC: KW V3 coilovers (rears)
      07-12-2012, 02:27 AM   #97
Small Yellow
Track Addict
Taiwan
110
---M
It wont, it actually makes it lighter going down and heavier going up but I could feel the engagement point a little better. If you remove both springs as stated in the first page it should make it feel a lot better but I didnt like how the clutch felt loose and moves right and left, there is also about 1-2cm of up and down movement that is free which does nothing to the clutch which I didnt like. I am afraid the single spring method I tried is just something in my head and has no actual benefits so I might make it stock again and see if what I did is an actual improvement. Lets be truthful, the clutch in our e9x M3 sucks.
BMW ///M3 Coupe
      07-17-2012, 08:35 PM   #98
tma1c
tma1c's Avatar
Drives: 08 E93 6MT M3
has anyone done the spring removal and the clutch stop on an 08? Was wondering how that combo feels.
      07-22-2012, 05:02 PM   #99
mtl88
Drives: 2011 1M VO
I just installed the clutch stop from eBay and I am so happy with the results. I performed the clutch spring removal a few months ago and was also very happy with the results. I should have done this 3 years ago. I definitely recommend both mods mentioned above with the lighted ZHP mod.
      08-02-2012, 05:17 PM   #100
bretster
bretster's Avatar
84
Drives: E92 M3
I did this on a buddy's 335 and when we finished he had no clutch engagement and i believe he had to bleed the clutch or something with brake fluid and a pressure bleeder.
Is this the case with the M3? I have an 08 M3 and just went out to buy the T15, T20, and T25 torx bits. thanks guys
      08-02-2012, 05:32 PM   #101
schnell325
Bored at work....
schnell325's Avatar
Drives: 2016 F82 M4 GTS//2022 M235iGC
NO such issue with my '08.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      08-02-2012, 05:49 PM   #102
bretster
bretster's Avatar
84
Drives: E92 M3
Sounds good I'll try this now!
      08-02-2012, 07:39 PM   #103
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
I just did this. Piece of cake. I sat on the ground on a piece of cardboard next to the door sill. Took about 10 minutes start to finish. No trouble at all removing the circlips or e-clips with a long thin small bladed screwdriver. I did a clutch stop at the same time. I like the pedal feel from the spring loss. Also like the clutch stop. My next shift mod may be the weighted ZHP knob. No need to bleed the clutch slave, though if you do your brakes sometime, do the slave as well.
      08-05-2012, 10:19 PM   #104
ndog14
Drives: E90 328xi 6MT
So I went to do this on my 07 328xi and to my surprise the previous owner must have done it. I have the clutch stop installed for anyone that needs a reference point.
      08-07-2012, 11:02 PM   #105
bretster
bretster's Avatar
84
Drives: E92 M3
Just did this on my M3, after all the doubts of not fitting and shit. Worked out nicely, feels amazing, it was free, couldn't ask for a better mod. Thanks M3p
      08-08-2012, 02:08 AM   #106
karussell
Drives: 4 wheels
whats a recommended clutch stop for this car?
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
      08-10-2012, 09:25 AM   #107
W///
W///'s Avatar
7526
Drives: F82GTS, E36/E92M3, Z4M
On my E46, I just went with the cheap route. I got those pads you put under furniture legs so that they don't scratch hardwood floor. Put 2 of those on the carpet. Works just like $20 aftermarket clutch stops.
I'll have to try this clutch spring mod on my 08 since everyone seems to have positive results
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      08-10-2012, 03:59 PM   #108
pbonsalb
I am using the $10 ebay stop. It appears to consist of $3 in parts, but you might spend more if you had to buy packages of several parts each.
      08-10-2012, 04:01 PM   #109
marksae
marksae's Avatar
36
Drives: ///M
What does the clutch pedal stop do exactly? Does it prevent the clutch pedal from going all the way down to the floor? If so, doesn't that prevent the clutch from being actuated fully when you step on the pedal?
04 E46 M3 6MT - AW / Cinn
93 FD RX-7 Base Manual - BB / Blk
IG: @gearheadtwins
      10-19-2012, 10:41 PM   #110
danio
Drives: M3
is there any fix to the pedal wobble? I love the feel of the clutch and really don't want to put the "coilover" back in, but the wobble is driving me nuts!! I also have a 1cm or so of nothing before I can feel the pressure as someone else has stated above.
m3post
