European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      08-31-2014, 03:50 AM   #23
Mandi90TT
Drives: BSM 6MT M4 F82
Originally Posted by ybbiz34 View Post
I can't believe the dealer charged you.
That's an issue that should be covered under warranty.
This.
You need to complain to BMWNA (as some others have said) and perhaps have a talk with the GM of the dealership. If all else fails, take your business to another dealership.
      08-31-2014, 06:10 AM   #24
dhoggm3
dhoggm3's Avatar
Drives: 850i C, Gated R8 5.2, E63
Oh I think I'll get satisfaction from the dealership. They're one of the BMW NA Gold Award dealers, and I'm sure they'd like to keep that status. We'll see.
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune
Alpina B8, zero performance mods
      08-31-2014, 08:20 AM   #25
SOM3
Drives: SO F80
Originally Posted by solstice View Post
1100 miles during my euro delivery. No pulling to the right. Car tracks like an arrow unless you are in the horrible comfort mode where the the car has no on-center feel and sways in all directions on autobahn...
What? You might want to get that checked out.
      08-31-2014, 10:00 AM   #26
Definitive
definitivecars.com
Definitive's Avatar
Drives: Elsa - 2015 F80 M3 - YMB/SS
My car also has a slight pull to the right as well. I feel like this is pretty normal for cars these days. Maybe taking into account how lots of us drive with our left hand on the wheel pulling a little on the wheel, ending up in a straight line???
      08-31-2014, 10:15 AM   #27
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Wow, I really thought I was the only one that is having this issue. Didn't know it's actually pretty wide spread. Either way, I'm having my dealer to take a look at mines. They won't charge me as long as I'm under 2000 miles.
      08-31-2014, 10:45 AM   #28
Needsdecaf
Needsdecaf's Avatar
6599
Drives: 2024 G80 Comp xDrive
This is a problem I am keeping an eye on.
It was a known problem with the F10's when they first came out. My car suffered through it. It took a lot of hassle on my part to get it fixed, and involved a software fix, rotating the springs in the mounts, and finally replacement of the upper steering column. Not to mention about 5 alignments.
In the end, the car still wandered on the highway, but at least it didn't pull.
Let's hope this is not a chronic issue.
      08-31-2014, 10:07 PM   #29
solstice
Drives: 2015 M3 6MT
I couldn't care any less as long as the default mode ( Sport ) is perfectly weighted and stable with perfect tracking with no micro adjustments needed. I will never, ever go to comfort again so it matters less than zero.
      08-31-2014, 11:09 PM   #30
Spencer25
2015 M4 Coupe, Black Sapphire
Drives: 2013 F13 M6; 2015 F25 M4 Demo
I also have this problem
      09-01-2014, 12:33 AM   #31
MWS55
Drives: MW/SO M4
Is yours sitting on 18's as well?
      09-01-2014, 12:56 AM   #32
Pharmacist_
Straight outta Loca$h
Pharmacist_'s Avatar
Drives: '15 f80 M3 '13 f25 x3 35
Concerning and sub'd.
2015 F80 ///M3 (AW/SO|6MT|Exec|LED|HK|M Susp|Black 19s|Cameras)
ED Date: October 13, 2014
PCD Date: December 5, 2014
      09-01-2014, 01:22 AM   #33
brian1225
Drives: 2015 F80 M3 MW/BLACK
Mine has this problem too! Let me know what your dealer figures out.
2011 E92 M3 AW/Black Competition Package Fully loaded.
On Order 2015 F80 M3 MW/Black loaded minus ceramic brakes. Production start date: 07-08-14
      09-01-2014, 01:28 AM   #34
binky
Drives: 2013 BMW M3
Having the same issue at 1400 miles. What to do?
      09-01-2014, 01:47 AM   #35
Wei718
Wei718's Avatar
340
Drives: 718 GT4
This isn't going to be good! Hopefully BMW issues a TSB to address this issue and I doubt it has anything to do with 18's or 19's.
      09-01-2014, 04:27 AM   #36
Milban
Drives: Porsche GT3 ordered
I've been running auto repair shops for too many years. When a car pulls left or right, and the alignment specs are good, and the tires pressures match, it's usually a "radial tire pull". The way to troubleshoot it, is to switch the front tires left to right, and see if it has an effect. If the tires have a directional rotation, switch them front to rear (if they're all the same size). The results usually bring a smile.
Invictus137.50
      09-01-2014, 07:30 AM   #37
dhoggm3
dhoggm3's Avatar
OK Milban I'll flip them L/R. The rears are a lot bigger, so I hope that does it. Thanks.
      09-01-2014, 07:41 AM   #38
Milban
Just remembered.. Twice, I've seen back ones bad enought to make the steering pull. If the fronts don't do it, try the rears.
On a complete segway, make sure the brake aren't dragging on the right side.
Good Luck! "Have fun storming the castle!",
      09-01-2014, 07:50 AM   #39
Mandi90TT
Are the PSSs directional? If so, you probably shouldn't flip left and right, either.
      09-01-2014, 08:28 AM   #40
onatuesday
Drives: Hyundai
What's the best way to bring to BMWs attention (above the dealership level)? Seems to be affecting enough ppl (and also an issue that was addressed in other models) that BMW should start working on a solution but I don't think we should take it for granted that they know about it
      09-01-2014, 09:47 AM   #41
Needsdecaf
Needsdecaf's Avatar
6599
Guys, when you say "pull to the right", if you remove your hands from the wheel, how long until the car changes lanes.
On my 535, it was between 2-3 seconds before I was more than 50% in the lane next to me. I think that closing in on 10 is to be expected with wide front tires and some camber in the road.
Just curious. In my old car it was not a "hey look I'm sort of wandering over to the other lane I think I might want to grab some opposite lock to keep me going forward" it was "holy fuck I just changed lanes without turning the wheel!"
      09-01-2014, 10:14 AM   #42
Wei718
Wei718's Avatar
340
Drives: 718 GT4
2-3 seconds my car will be in the ditch once let go of the steering wheel
      09-01-2014, 10:49 AM   #43
brian1225
Geez the pull on my vehicle is not that bad.
      09-01-2014, 12:07 PM   #44
Maddict3
Maddict3's Avatar
192
Drives: 2015 991 GT3
mine does this as well!!
2015 Porsche 991 GT3 Sapphire Blue Metallic
2015 BMW F80 M3 Silverstone Metallic
f80post
