11-18-2015, 10:23 AM | #221 | |
Rep 3,661
2016 F80 M3 AW/SO (Manual) - Picked up at the Welt 08/28/15 My Amazing European Delivery Story |
11-18-2015, 11:14 AM | #222 | |
Rep 310
My 16 with Contis does the same exact thing. Interesting note is I did ED and did NOT have the issue in Germany.... |
11-18-2015, 11:16 AM | #223 |
Rep 310
11-18-2015, 11:18 AM | #224 | |
Rep 310
11-18-2015, 11:19 AM | #225 |
Rep 3,661
US roads then
11-18-2015, 11:37 AM | #226 | |
Rep 2,997
On MY car, it was dead straight from the factory. When I switched my summer tires back on this spring, I put them on opposite sides - which introduced radial pull.
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
11-18-2015, 01:32 PM | #227 |
Rep 310
I think the shipping line / trucking line is tying them down incorrectly. Especially given a lot of people have this issue.
Used to see it all the time when cars were towed into the shop - they'd attach the chain to one of the front tie rods and crank it down, slightly bending the tie rod. Swapping tires isn't solving the problem, especially with symmetrical tires, which the contis and michelins are. Also clearly not solving the problem when two different types of tires are having the same problem. |
11-18-2015, 08:34 PM | #228 | |
Rep 479
their dime
they charged me zero. i only have 900 miles on the car.
11-18-2015, 08:35 PM | #229 | |
Rep 479
hard pull to the right for me
11-18-2015, 08:57 PM | #230 |
Rep 5,373
This thread is making me really nervous. I'm picking mine up in 3 weeks and it would drive nuts. Had the same issue on my S5 and tt. Damn.
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
11-18-2015, 09:11 PM | #231 |
Rep 84
Drives: E46 M3/2016 M4
So my car now tracks perfectly. Swivel bearing was replaced.
11-18-2015, 09:23 PM | #232 |
Rep 84
11-19-2015, 06:39 AM | #233 |
Rep 1,530
Mine does pull to the right since I got it from the dealer 7000 miles ago. It actually got much worse. It's annoying me to no end. On an empty highway I let it go from the left lane across middle lane to right lane then exit, all in 150 yards. Why didn't I take it to the dealer you ask? Pessimism!! Yes..my previous E92 M3 was straight like an arrow for 70K miles then started to do that. I took it to the dealer, $150 later it still did same thing, changed tires, rotated it, danced for it...nothing. I give up
11-20-2015, 06:24 PM | #234 | |
Rep 479
show him this thread
mine is 95% better after they replaced swivel bearing, adjusted camber and realignment. I say 95% because I have not had a chance to fully evaluate the car yet, weekday traffic is crazy in orange county. That being said, it seems to be fixed.
11-20-2015, 06:28 PM | #235 |
Rep 479
problem
i knew about the problem before I took delivery, was hoping I would not have the issue. When I took delivery it was late, traffic and raining. I did not test drive it prior to delivery but did notice the pull after about a week. I was in denial at first, my cls550 had the same issue.Had to have it addressed at the break in service thought because it was definitely a hard pull and NOT CROWNING IN THE ROAD.
11-22-2015, 04:53 AM | #236 |
Rep 155
Just got this issue as well and im at around 14k miles. Its noticeable worse where i feel that i have to be making constant corrections. What was once a smooth easy driving experience is now ruined. I took it to dealer and they said they found nothing but the steering feels lose and off center and pulls hard to either left or right.
11-22-2015, 11:40 AM | #237 |
Rep 479
update: Problem still exits, it drifts now as opposed to hard pull. Taking it back in this week to dealership. It is quite a bit better but still has the issue.
11-22-2015, 11:43 AM | #238 | |
Rep 479
first one to say it pulls to the left
Did you change anything on the car just before you noticed this problem? You are the first to report a pull to the left I believe, all other posts say their car pulls to the right.
11-22-2015, 06:30 PM | #239 |
Rep 155
It started from my 19s i just switched over to 18s winters and thought it would improve. It hasnt. Dealer did rotate tires as well with fronts now in rear. Yes it square winter set up.
11-23-2015, 06:56 PM | #240 |
Rep 479
ride quality
How much of a difference is there in ride and performance between the 18 vs 19. Dropped car off again today for the pulling issue, attempt #2.
11-28-2015, 03:39 PM | #241 |
Rep 876
I didn't read all 11 pages but I had this exact thing happen with another car...after like 5 trips to dealer and multiple trips to indy alignment shops, I was told everything with respect to suspension was fine and was told it has to be the tires...sure enough, I swapped out the tires and pulling to right instantly went away...the tires in question were part of dealer program where you get new crappy tires for life and I will never take those crappy new tires ever again.
11-28-2015, 07:10 PM | #242 |
Rep 479
fixed
The car is okay now. I drove it on many different roads to diagnose if it was fixed or still drifting. I had to drive it on an air strip to determine whether or not it was still drifting, no crown on air strip. The car is very sensitive to the road crown. It was definitely not crowning in the beginning causing the car to pull, and they did rectify that problem of a hard pull to the right.
