05-08-2024, 06:44 AM | #1 |
Rep 32
Noob question: Using 47ET at the back, could I go down?
Hello!
I bought the car, an F32 with the following setup: For the tires. 225/40 R19 -front 255/35 R19 -back For the rims. 8Jx19 ET36 -front 8.5Jx19 ET47 -front Im planning to buy new rims for the summer, but with ET47 its really hard to find one. Could I go down to like ET40-45 for the back? Will the tires fit, will the geometry be bad? -What would you guys do, maybe new set of tires? Sorry for beginner question, tried to search the web, but there are some questionable and different answers everywhere. Good day |
05-08-2024, 06:46 AM | #2 |
Rep 2,963
You could go down to the 20s it wouldn't matter unless you're lowered
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
morcsekovszky7.50 |
05-08-2024, 06:49 AM | #3 | |
Rep 32
So as for the tires, it doesent change a bit just how it sits on the car, is that correct? Also, after I do like ET43-44-45 etc.. I should align the car and all fine, right? |
05-08-2024, 06:52 AM | #4 |
Rep 2,963
The "et" is the offset which is basically just the distance from the hub to the inner edge of the wheel. Et37 would be like putting a 10mm spacer on the stock wheel which people do all the time. No alignment is needed
morcsekovszky7.50 |
