08-07-2014, 10:10 AM | #1 |
Rep 270
Drives: F15 X5 35, E60 530
BMW 437M wheels (Black M4 wheels)
Hi everyone, i would like to take your expert opinion on changing my OEM F32 44M2 wheels to the M4 Black wheels
The F32 oem are Front axle: 8"J x 19" offset 36 Rear axle: 8.5"J x 19" offset 47 The 437M wheels are Front 9JX19 ET:29 rear 10JX19 ET:40 Thank you. |
08-07-2014, 10:30 AM | #2 |
Rep 29,203
Front will extend 20mm, and rear will extend 26mm.
Don't know if that's too much though.
08-07-2014, 01:47 PM | #3 |
Now in the dark side !
65
Rep 1,136
Wow, for once, the M wheels look like an almost direct fit for the non-m cars.
I've seen people posting 9j x 20 30 offset and 10j x 20, 40 offset installed without any problems. If you have a good relation with your SA, I suggest you go there and try them on to see the fit. I know my SA would do it, just to see the looks it gives to the car...
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
08-07-2014, 02:16 PM | #4 |
Dinosaur supervisor
3033
Rep 4,214
Will work on a lowered car (as the camber will tuck them). On stock height they will be 10-15mm outside the fender.
My HRE where an identical fitment (look at my older threads). |
08-08-2014, 02:35 AM | #5 |
Rep 270
Thanks for the reply guys. i saw these wheels on F30 and it looked damn cool. i am planning to select more conservative tires not the same as the stock M4, so for the front 245/35/19 and rear 265/30/19. i checked on tirerack.com and found these tires for BMW. will that make difference? do i still need spacers?
08-08-2014, 01:08 PM | #6 |
65
Rep 1,136
Since they are already limit on fitment, don't put spacer as things will get worse.
Spacer substract from the offset, so the wheel will stick out more.
08-09-2014, 08:55 AM | #7 |
Rep 270
No plan for spacers don't like them anyway,, I am planning front 245/35/19 and rear 265/30/19, will it rub on stock M sport suspensions?
08-09-2014, 09:43 AM | #8 |
Dinosaur supervisor
3033
Rep 4,214
It will look silly on stock suspension. The wheels will be 10-15mm outside the fender. You need to lower the car.
opticspen3.00 Alpine-F80203.00 |
08-09-2014, 11:11 AM | #10 |
Dinosaur supervisor
3033
Rep 4,214
hooligan_G016431.50 |
08-10-2014, 03:53 AM | #11 |
Rep 270
08-10-2014, 04:07 AM | #12 | |
Rep 270
need to check on tire rack.com if its can be done. thanks for the help |
08-10-2014, 07:41 AM | #13 |
Pace Car Driver
1557
Rep 3,166
http://f30.bimmerpost.com/forums/sho....php?t=1003865
http://f30.bimmerpost.com/forums/sho...d.php?t=994084 Link? What you probably saw were 20" M5 wheels (or knock-offs). This has been covered numerous times. |
08-11-2014, 01:05 AM | #14 |
Rep 270
i saw it parking nearby, don't have a photo sorry,,, and i am sure its 437M i had the M5 wheels, or actually i still do have them in my garage after selling my F10 however i couldn't find anyway to fit these M5 oem rims on my F32,, thats why when i saw these black rims on that car i was shocked, it looked really nice.
08-11-2014, 04:51 AM | #15 |
Rep 270
not sure if you guys saw this thread http://f30.bimmerpost.com/forums/sho....php?t=1020934
looks nice, and no rub. |
11-12-2014, 11:34 PM | #22 | |
Rep 270
