01-05-2024, 03:23 PM | #1 |
Rep 80
Mr 12 volt coding for non CD changer cars
Hi all,
I am a little confused about coding in CD changer functionality to work with the Mr 12 Volt P2000 for those of us with cars that never had that option, but DID have "6 CD preparations" option. Most instructions reference using Bimmercode, but I dont have it. I am competent reading various modules with NCSExpert, manipulating them with NCSDummy, and then coding them into the car. A few questions: What modules must be read first? For those modules read, what must be changed/manipulated? Is a K-DCAN cable sufficient or not?(I have read that not all modules can be read with one on these cars - specifically the 2URAD module) For reference, my car is a manual '08 with a CIC retrofit. Everything works. Any help for coding the "old fashioned way" with NCSDummy is greatly appreciated.
2001 E39 M5 - Titanium Silver
2007 Z4 M Coupe - Sepang Bronze 2008 E92 M3 - Jerez Black |
01-05-2024, 11:47 PM | #2 |
Rep 1,049
The module is the CIC itself, I think it was 'HU_CIC"
You need to set CDMM_CHANGER_3 to mp3_cdc. Unsure if there is something additional needed for CIC retrofit cars. K-DCAN cable works just fine. |
01-06-2024, 10:32 AM | #3 |
Rep 80
The problem is that I can’t code the CIC directly with a k-dcan. When I try to find it on the list of available modules in NCSExpert, it isn’t listed.
I did edit the VO for the CAS, NFRM, and the FRM by adding $672 and deleting $694 (this adds the CD option to the car). But I’m not sure if that’s sufficient, I will find out soon |
01-06-2024, 11:37 PM | #4 |
Rep 1,049
I think the issue lies in the coding done for the retrofit itself. At the conclusion of the cic retrofit, you are expected to default code the CIC module, which means it likely wasn't done if you cant see it in NCS_expert.
Did you update the build date to at least 0909 before coding CAS and NFRM/FRM? Did you add $6VA to the VO? Last edited by drwankel; 01-07-2024 at 12:39 AM.. |
01-10-2024, 05:53 PM | #5 | |
Rep 80
I did not update the build date nor add $6VA, are those things necessary? |
01-11-2024, 02:16 AM | #6 | |
Rep 1,049
Example procedure: http://blog.obdii365.com/2016/06/14/...ng-ncs-expert/ Not 100% sure if everything in here is accurate. I can confirm that I can view CIC in NCSexpert on a native CIC car with a k+dcan cable. |
01-11-2024, 08:12 AM | #7 | |
Rep 80
01-11-2024, 01:38 PM | #8 |
Rep 3,988
Sounds like you have a separate issue not being able to read the CIC module.
That usually means something was skipped in the retrofit coding, hopefully the above mentioned will fix it. Also consider that some harnesses that split behind the CIC HU sometimes blocks the ability to code the CIC. So youd have to uninstall the harness to code it. I have the older version mr12volt with the CIC controller harness not the new one, so I can't confirm if this is the case or not. But android units usually have that problem. So something to consider. But if you always haven't been able to read the CIC module then it's probably due to steps omitted in the retrofit coding. |
01-12-2024, 01:24 PM | #9 | |
Rep 1,049
If it still doesn't work and you are using the new version with factory mic integration- you might have to remove it to be able to code CIC, and then put it back in. |
01-20-2024, 12:34 PM | #10 |
Rep 80
Just following up, managed to get everything working by recoding the CIC after removing the harness, then reinstalling the 12 volt. Thanks everyone for the input, I couldn’t have done it without the help
01-20-2024, 01:23 PM | #11 | |
Rep 1,049
In the DSP and prior boxes, there is no quadlock adapter, so you can still code it with the P2000 installed. |
