10-27-2020, 01:20 AM | #45 | |
Rep 2,367
Drives: 2011 335i
10-27-2020, 01:21 AM | #46 |
Rep 2,367
Drives: 2011 335i
10-27-2020, 03:16 AM | #47 | |
Rep 45
Before I installed all correctly, for testing I grab power from Combox and can from PDC. When you disconnect the TRSVC, the PDC is working? |
10-27-2020, 04:02 AM | #48 | ||
Rep 2,367
Drives: 2011 335i
10-27-2020, 08:22 PM | #49 | |
Rep 1,351
Congrat buddy. Thats why i am here and thats why i share here! Made my day!
And you are right bout the space. E93 is tight. E90 was alot better. e92 is the best i guess Quote:
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
10-27-2020, 08:24 PM | #50 |
Rep 1,351
Did you properly VIN flash the JBE3 and default code for your car?
10-27-2020, 08:25 PM | #51 |
Rep 1,351
i can remotely code everything u need!
10-27-2020, 08:55 PM | #52 | |
Rep 2,367
Drives: 2011 335i
10-27-2020, 10:19 PM | #53 | |
Rep 1,351
If you can not communicate with the TRSVC check the Software No. If it starts with Numbers then it belongs to F series and i also had one and does not work for our cars! If it starts with Letter (A,B,D) that belongs to E series which is fine. LMK! F series : E series :
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 10-27-2020 at 10:25 PM.. |
johnnyorange52.50 |
10-27-2020, 10:34 PM | #54 | ||
Rep 2,367
Drives: 2011 335i
10-27-2020, 10:39 PM | #55 |
Rep 1,351
Wrong part. That belongs to F series and F series uses 500kb vs E series uses 100kb on KDCAN. Just like the F series CIC cant fit on E series! So i warned couple of Ebay sellers who put a title like X1 E9X on a F series TRSVC but cant correct everyone. You need to get E series!
+ I tried to Expert Flash the TRSVC with X1 files using the winkfp But since i couldnt communicate , i couldnt flash it.
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 11-26-2020 at 07:47 PM.. |
10-27-2020, 10:41 PM | #56 | |
Rep 2,367
Drives: 2011 335i
10-27-2020, 10:44 PM | #57 |
Rep 1,351
Send me the VIN no. Let's see what E series X6 came from! All E70/E71 TRSVCs came with Side View or Top view options there is No single Fakra E70/E71 TRSVC in the states!
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 10-27-2020 at 10:59 PM.. |
10-27-2020, 11:07 PM | #58 |
Rep 2,367
Drives: 2011 335i
That sounds right. Got a link to any reasonable one
10-27-2020, 11:17 PM | #59 |
Rep 1,351
You can get this one. You will see top view camera error on ISTA but will work without an issue. Later on you can activate the top view , if you find the camera with harness!
unrulyteach392.00 |
10-28-2020, 12:01 AM | #61 | |
Rep 2,367
Drives: 2011 335i
10-28-2020, 10:33 AM | #62 |
Rep 1,351
Whenever you are ready let me know 👍🏻
BFZ4M9.50 |
10-28-2020, 11:31 PM | #63 |
Rep 67
hey there, I installed the trsv below the combox/media bracket with a nut and secure it with a zip tie.
I don't have more pictures of the oem camera and the chinese handle, but I had to dremel a lot of the inside where the chinese camera was to make room for the bulky oem camera. The end result looked very similar to Sangria's camera fitment. |
SaNGRia986.00 unrulyteach392.00 |
10-28-2020, 11:46 PM | #64 | |
Rep 1,351
That's about right. Great job!
10-30-2020, 04:49 PM | #65 |
Rep 2,367
Drives: 2011 335i
Still getting the same results as i did with f series trsvc module
10-31-2020, 12:53 PM | #66 |
Rep 45
