BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
      10-02-2023, 04:34 PM   #287
DimitrisM3
e90 my big fat lady!
DimitrisM3's Avatar
Greece
49
Drives: e90
Originally Posted by SaNGRia View Post
Well i have never seen any of the modules that has a full set of number on the version that works on E series. Usually it includes a letter in it. If that was a working TRSVC on E series then it must be exceptional.
Because I am confused what camera Modul need for e9x with nbt !
From F series from e84-e70 ??
      10-03-2023, 02:11 PM   #288
DimitrisM3
DimitrisM3's Avatar
Greece
49
Drives: e90
No answer 🤷🏻*♂️
      10-03-2023, 02:14 PM   #289
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
478
i had iCam on my e90 with NBT retrofit. i think you can use both iCam and TRSVC from e84 but you will have to wire it before or after the adapter
      10-03-2023, 02:32 PM   #290
DimitrisM3
DimitrisM3's Avatar
Greece
49
Drives: e90
I have the adapter from Carsystems
      10-03-2023, 02:56 PM   #291
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
478
i've used that with iCam. not happey with the iCam, i would go for TRSVC. check this topic or the other topics, somebody explained to to wire the TRSVC for the emulator to work
      10-03-2023, 03:20 PM   #292
DimitrisM3
DimitrisM3's Avatar
Greece
49
Drives: e90
I read it all but I never found it
      11-05-2023, 05:49 PM   #293
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
I have finished fitting the camera to my E92. It really wasn't that terribly difficult to do just that the parts were expensive. I managed to spend $400 on all the parts for this retrofit.
Install notes for anyone else fitting this in the future:
1. E7x top view camera module works just fine.
2. Don't glue the camera in as you will never fit it in the trunk. Make sure you cut enough to where the camera can friction fit in the hole and the lens is sticking pretty far out. Place the camera in the trunk lid, then fit the handle, then push the camera into the handle so that it is snug in place.
shannon1639.50
Luxury85.50
      11-17-2023, 11:35 AM   #294
norkus
Drives: BMW E92
Thanks for the great DIY.
I wanted to ask if I have an E92 LCI with front and rear original parktronics, do I still need to buy a PDC module from the E84?
I am going to buy F10 reverse camera, TRSVC and its cable. Would that be enough for me? And what exactly TRVSC do I need? Should be with only one output and that’s enough?
Thanks for your experience and reply.
      11-18-2023, 03:26 AM   #295
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
478
yes, you need PDC from E84 with reverse camera, also ideal would be TRSVC from the same car (although will work one from e70 also). don t get TRSVC from F series !
      11-18-2023, 09:29 AM   #296
art unique
Drives: E92
I have the full retrofit kit for this DIY if anyone is interested
      11-20-2023, 07:42 AM   #297
norkus
Drives: BMW E92
how much?
Also, would rear camera from F10 work with TRSVC from E70 but with these outputs? (Top rear view camera) or it requires only with one output?
      11-20-2023, 10:46 AM   #298
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
478
i ve just told you that trsvc from e70 works, it was said several times on the topic already.....
there is no e70 trsvc with one output
      01-03-2024, 11:31 AM   #299
unrulyteach
unrulyteach's Avatar
Drives: 2011 335i
2011 BMW 335i  [0.00]
How do i go about adjusting the lines to be after the bumper?
      01-08-2024, 06:49 AM   #300
Mert335d
Drives: E92 335d LCI
  [0.00]
Yeah my lines are also a bit „in“ the bumper. Would like to adjust the lines as well. There is a thread about that. I tried by changing the values in NETTODAT.TRC. But it didnt work.
Note: You can only code the TRSVC with K+DCAN (Enhanced) or ICOM.
      01-12-2024, 09:11 AM   #301
Adam M
Drives: BMW e92 M3
Just done this for the second time in a car.
Just wanted to say a huge thanks to Sangria for the hardware and coding support. The man is a legend/genius.
SaNGRia986.00
      01-19-2024, 07:17 PM   #302
SaNGRia
SaNGRia's Avatar
986
Drives: LCI E93 M3 + F85 X5M
Appreciated brother
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
      01-22-2024, 04:45 PM   #303
03BeastCharmer
03BeastCharmer's Avatar
257
Drives: '13 M3
I have an old Alekshop rear camera setup that only works occasionally. Wonder if I would switch over easily since I already have a camera wired to the trunk. That was pretty plug n play as the module just piggybacked into the screen and other harnesses, but rarely worked during the summers.
Current: '13 E92 M3 Euro Delivery
Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3
      02-11-2024, 05:47 PM   #304
unrulyteach
Drives: 2011 335i
Hmm can u post the thread here
      03-05-2024, 02:08 PM   #305
scroller
Drives: 335i
I have changed my PDC because my original PDC module wasn't able to flash to the X1 with the part number i need it so after doing some more research i have done it successfully the retrofit and i'm so happy
      03-10-2024, 08:54 PM   #306
SaNGRia
SaNGRia's Avatar
986
Great. Congrats!
, F85 ACC Retrofit
      03-11-2024, 07:44 PM   #307
CTMike
Drives: 2021 X5 40i MSport/2011 E93 M3
Great. Congrats!
Hey SaNGRia… I’m debating an NBT EVO retrofit. Would I still follow the procedure in this thread to retrofit a rear view camera to my 2011 E93 M3? Thanks for all you contribute!
Thanks,
Mike
Gone but not forgotten: 2005 X3 2.5 6spd, 2011 X5 50i, 2015 328d Wagon
      03-13-2024, 01:40 PM   #308
SaNGRia
SaNGRia's Avatar
986
Thanks,
Mike
Hey. Yes you can follow the same procedure. And Thank you!
, F85 ACC Retrofit
CTMike262.00
m3post
