BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
Mporium BMW
      02-16-2020, 10:02 AM   #23
///M3 Gusta
///M3 Gusta's Avatar
50
Drives: 2008 M3
I went back to stock, and did these steps in reverse order. Everything worked out fine. For some reason I did not have RECA in my VO, though.
      05-09-2020, 02:26 AM   #24
Tigamilla
Drives: BMW E92 M3
Thread resurrection! I have successfully done these steps and even copied the values across to CAS, FRM and NFRM as backups.
My question is... If using the stock seatbelt receptacles, why can't I have the contact and pretensioners activated? I have tried to set them to active and plug them in but they still throw errors.
Only unplugging them and setting them to not active seems to work...
      05-13-2020, 09:51 PM   #25
6ixSpd
Save the manuals!
6ixSpd's Avatar
6016
Drives: '16 M3, '23 718 Spyder
If you leave the following AKTIV:
GURTKONTAKT_BEIFAHRER_1 -Seat belt contract/connection (passenger)
GURTKONTAKT_FAHRER_1 -Seat belt contract/connection (driver)
GURTSTRAFFER_BEIFAHRER_1 -Seat belt tensioner, active restraint (passenger)
GURTSTRAFFER_FAHRER_1 -Seat belt tensioner, active restraint (driver)
You should have no problems. I have stock receptacles and didn't modify the above parameters. Zero issues in my Recaro setup.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      05-23-2020, 01:29 PM   #26
WhiteM3EMC
WhiteM3EMC's Avatar
116
Drives: 2011 White M3 DCT
I've tried using NCSExpert with the BMW Coding Tool, and NCSDummy.
I'm using the KDCan cable that I got when I ordered the DCT GTS tune from AlpineMSS, so I'm certain the cable works (at least did work)
Have no problem changing the required options in the BMW Coding Tool and NCSDummy, and am able to save the MAN file in either one.
My problem seems to be that NCSExpert is either not actually writing the MAN file to the car, or the cable isn't allowing it to do so. I've even viewed the TRC file in NCSExpert and the options that I want are checked appropriately, so it seems that the file that NCSExpert is using is the one that I want. But, I've probably hit "execute job" 20 times, and the airbag/seat belt lights will not go away. I'm stumped.
I've tried using the FSW PSW profile (with the manipulation box checked), the ExpertMode profile, and the NCSDummy profile. All of them allow me to "code" the car, execute the job, tell me that coding has ended, but the lights don't go away. I've cleared all codes using INPA after every attempt at coding, and I've cycled the key as well as started/stopped the car several times along the way.
Any help appreciated.
      05-23-2020, 09:30 PM   #27
6ixSpd
Save the manuals!
6ixSpd's Avatar
6016
Scan MRS5.PRG using Tool 32 and report what errors are being thrown.
If you're still having trouble, I can remote in with TeamViewer and take a look.
      05-24-2020, 06:34 AM   #28
WhiteM3EMC
WhiteM3EMC's Avatar
116
Will do, thank you very much
      05-24-2020, 10:46 PM   #29
WhiteM3EMC
WhiteM3EMC's Avatar
116
Well, that was so tedius, but I finally got it. My problem primarily stemmed from the fact that I'd also removed my side air bags, which means you need to deactivate a few more lines. Took me quite a while to figure that out.
      05-26-2020, 05:29 AM   #30
Expressivedrives
Expressivedrives's Avatar
249
Drives: BMW M3 E92 ZCP
Hi
I mounted Recaro Profi SPG XL-s instead of OEM sofas. These are the same seats as M3 GTS has, no airbags. So there is a solution. My mechanic coded it easily.
I have also seen resistor terminal solution, plugged in to under-seat airbag connector. Some seat suppliers sell them with the seat.
M3 E92 ZCP LCI
      05-26-2020, 09:15 AM   #31
Bartledoo
Driver
Bartledoo's Avatar
2692
Drives: 2011 E90 M3 6MT
Thanks for the info on this. Was very quick and easy. Added the +reca to both CAS and NFRM and the edited the ABG coding as in the OP.
E90M 6MT Slicktop Single Humper in need of a diet
      07-17-2020, 10:16 AM   #32
///Mobbin
///Mobbin's Avatar
1478
Drives: m3
Originally Posted by Bakerboy View Post
I'm left with only 2 errors now, can't seem to work it out.
All instructions are done including the VO change now.
My codes are:
0093C1 MRS: communication fault, seat occupancy detector passenger
00CF41 DKG: signal from drivers seat switch buckle
Obviously tried clearing codes a few times but no good.
Any help would be appreciated. Thanks
Originally Posted by christoepurrr View Post
Also curious of the solution as I cannot get rid of the 00CF41 error code
I also still have the CF41 error code which I believe is coming from the transmission module, curious if there is another value to code there.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
      07-19-2020, 09:58 PM   #33
6ixSpd
Save the manuals!
6ixSpd's Avatar
6016
Are you using an OEM seat belt buckle connected to the yellow underseat plug?
The DCT needs to see that connection to get rid of that error.
OC31 needs to be coded out on the passenger seat.
SAMM3Y3085.00
      07-21-2020, 12:46 PM   #34
wheezyF
Drives: e92 m3
I recently installed a driver side recaro pole position and used protool to code out the only two error codes I got.
93AC - side airbag, left
93AE - active head restraint, left
I'm using the OEM seat belt receptacle and its plugged into the yellow bulkhead connector.
Once I cleared those two codes, I've been getting no lights and seat belt works fine. I'm no expert when it comes to vehicle coding, but this seemed like a really simple 1 min job. Confused as to why everyone else is having to code out multiple items. If anyone can educate me and let me know if I've done anything wrong here I'd appreciate it.
      07-21-2020, 12:52 PM   #35
Bartledoo
Driver
Bartledoo's Avatar
2692
What do you mean "code out" the error codes? You just cleared them?
      07-21-2020, 01:01 PM   #36
wheezyF
Drives: e92 m3
Yes cleared the error codes
      07-21-2020, 01:04 PM   #37
Bartledoo
Driver
Bartledoo's Avatar
2692
Well those codes and airbag light should be coming back then. You have removed the airbags in the seats and their corresponding electronics, and haven't coded the remaining electronic modules of the vehicle to accept this.
      07-21-2020, 01:10 PM   #38
wheezyF
Drives: e92 m3
This is strange, since the codes/lights haven't returned. I'll check to see if the codes come up again but so far they haven't come back.
      08-04-2020, 09:56 AM   #39
Expressivedrives
249
Thanks, exactly how we did some time ago. Took a bit time to figure it out.
M3 E92 ZCP LCI
      12-04-2020, 05:27 PM   #40
SMS8386
Drives: E92 M3 Sold:2010 335d
Great thread! I have seats on the way so this will come in handy. I Haven’t tried any coding yet but I will have to learn I guess.
      12-10-2020, 03:43 AM   #41
ubehh
Spain
Drives: 335i n54
Originally Posted by rocket_science View Post
I know many of you run race seats and are using the OC3 emulator modules to remove the error codes generated by the removal of the factory seats (airbag and seatbelt/restraint errors). While these modules are an "easy" option, they are also incredibly expensive. Especially when you consider it can be done for free through coding.
The problem it there have been several posts about coding for race seats but these threads are all missing items to watch out for. As I am in the middle of installing some Racetech seats myself, I thought I would take the time to test all typical error causing settings and provide you with what I believe to be the full list of steps to ensure your E9x M3 is coded to remove the factory seats so you do not receive any lingering codes.
Note: I am not going to walk you through the coding process, just the items to update. If you need help learning to code, see here:
http://www.e90post.com/forums/showthread.php?t=451145
I used NCS to do the following:
1. Add +RECA to the car's VO -Recaro Seats
2. Ensure all the following are set to nicht_aktiv in ABG module:
SIDEBAG_LINKS_1 -Side Airbag (left)
SIDEBAG_RECHTS_1 -Side Airbag (right)
AKS_LINKS_1_CD -Active head restraint (left)
AKS_RECHTS_1_CD -Active head restraint (right)
OC3_1 -Seat occupancy mat
GK/OC3/POL -Not sure exactly but related to the occupancy mat
SPSBF_1 -Seat position sensor (passenger)
SPSF_1_CD -Seat position sensor (driver)
Clear all error codes codes with ISTA/P or software of your choice
That's it! So long as you are familiar with coding, this should not take longer than 10 minutes.
Thanks!! will try if it works on my 335i n54, my only doubth is if i need to clear errors before disconnecting seats/steeringwheel
Thanks in advance!
      05-30-2021, 04:07 PM   #42
gh0stE92M3
gh0stE92M3's Avatar
Drives: BMW E92 M3
Can this be done on BimmerCode or Carley?
      06-01-2021, 10:07 AM   #43
Silos
Silos's Avatar
556
Drives: M2 Comp
Just use ProTool - I was able to code out the light for my seats with it.
      06-02-2021, 08:19 PM   #44
mrvedit
Drives: 2013 M3
Wow ProTool sounds like a fantastic easy-to-use alternative to NCSExpert; too bad it is only for Android phones. I haven't used NCSExpert in 10 years; not looking forward to learning it again.
2017 M3 DTC * 2013 M3 Manual
2017 330i (Winter beater)
1981 Camaro Z28 - 427 LS3 - 10.94 @126mph
2006 Corvette (streetable track car)
1986 535i "24 Hours of Lemons" also streetable
m3post
