THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics M235i P3 Vent Gauge (VIDI)
      10-08-2014, 08:48 PM   #1
alz0rz
What goes here?
alz0rz's Avatar
452
Drives: 2019 G30 M550i
Post M235i P3 Vent Gauge (VIDI)
Hey all, I just want to share my experience with the P3 VIDI Gauge.
There are times when I would just like to see vital info, like oil and coolant temps, boost and ait on the fly. As you all know, we get none of that from BMW. I want to be able to see this information without having to install any unsightly boxes, have to perform modifications to my dash or invest a lot more money then I think it's worth.
In comes the P3 VIDI gauge to fill that gap. It fits right into the OEM driver side vent and still allows you to direct airflow up or down, left or right. It was important to me to maintain some airflow from the vent as opposed to sacrificing one entire vent (as competitors products might do) as this is my daily driver. I was also interested only in numerical values, so the small display of the P3 was sufficient.
It is a very easy installation. Simply undo plastic trim on the left of the dashboard, pop off the OEM vent, pop in the P3 gauge in it's place and tuck in the control box and all cables in behind it. Then just route the main connector down to the OBD2 port and plug in. Some initial config and you're good to go! P3 has solid videos showing all of this, exclusively on the M235i.
Very happy thus far. It looks and feels OEM and more importantly it gives me those important metrics on the fly that I was looking for. Apart from reading the standard OBD2 port info (air intake temp, battery voltage, egt, oil temp, coolant temp, etc.) it will also read/clear codes, has a shift light function and even has a built-in 0-60 timer mode.
Here are some pics and a few videos to give you a feel for the gauge.
View post on imgur.com
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      10-08-2014, 09:03 PM   #2
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
This is the V2 with oil temp?
I think a group buy its happening soon
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      10-08-2014, 09:07 PM   #3
alz0rz
What goes here?
alz0rz's Avatar
452
Yes, this version supports oil temperature readouts. See video.
2019 G30 M550i
GBNF:
      10-09-2014, 07:02 AM   #4
darcivic00si
Save the manuals!
darcivic00si's Avatar
Drives: Lotus Evora S
Nice! I have been waiting for this version with oil temp!
Thanks for the video, too!
      10-09-2014, 10:26 PM   #5
dt20011
dt20011's Avatar
262
Drives: 2014 M235i
Good stuff...thanks for sharing.
      10-10-2014, 06:36 PM   #6
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Does the shift light work if your in another mode?
I know the v2 for f30s does it
2006 325xi (Sold)
      10-10-2014, 08:05 PM   #7
alz0rz
What goes here?
alz0rz's Avatar
452
Yes, the shift indicator works regardless of the display you are currently in. I have it set at 5400 because by the time I see it and act I'm probably already at 5700'ish.
2019 G30 M550i
GBNF:
      10-15-2014, 06:20 PM   #8
Nuuze
Nuuze's Avatar
Drives: F80
Is there a amber led option to match?
      10-17-2014, 10:09 AM   #9
alz0rz
What goes here?
alz0rz's Avatar
452
No but it has a dimmer function that'll lower the brightness and that has a better color match. You can wire this (included) so it does it passively or you can hit the button and do it yourself on demand.
2019 G30 M550i
GBNF:
      10-18-2014, 12:28 PM   #10
abirmaher
abirmaher's Avatar
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
  [0.00]
2018 BMW M2  [10.00]
For anyone who is interested, there is a group buy in progress for this. Check the other threads in this category for the info.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      10-18-2014, 04:20 PM   #11
alz0rz
What goes here?
alz0rz's Avatar
452
Not quite as good as deal as I got but a good deal nonetheless!
No complaints on this unit at this time after a few weeks of use.
2019 G30 M550i
GBNF:
      10-23-2014, 12:15 AM   #12
G-Mann
G-Mann's Avatar
413
Drives: M4CX
That is very nice, thanks for sharing the info.
What's the max boost have you seen?
2022 M4 Comp X
2021 M440ix - Sold
2015 M235 - Sold
      10-29-2014, 01:13 PM   #13
alz0rz
What goes here?
alz0rz's Avatar
452
Stock, the highest I've seen is 10.0.
      10-30-2014, 01:47 PM   #14
zipphreak
Drives: m235xi
Hi guys, anyone know where I can tap the dimmer wire for this gauge to use the auto dim feature
Thanks,
Paul
      10-30-2014, 04:33 PM   #15
zipphreak
Drives: m235xi
Got the P3 kit today, which came pre-installed in a vent. So installation took about 30 minutes or less. I am going to hook up the dimmer wire, but I didn't have time to rip apart more stuff. I was told we can use the RED/GRAY wire at the trunk release in the kick panel. You will need one red inline t-tap connector that you can use the included 1/4" male spade connector!
      10-31-2014, 04:04 PM   #16
TTBear
TTBear's Avatar
417
Drives: '20 Huracán/'19 M2Comp/'23 X4M
Good to know - thanks!
I will be doing that, too - would be silly not to, I think.
Hahaha - just as I was typing this, I got the notification that my gauge has shipped
It'll be a great mod. It's funny - I'm more excited about seeing what I can do for mods on this car than my other car. Might have something to do with the cost of modding them comparatively, but nonetheless, it's fun as hell with the Bimmer
"Anima sana in corpore sano"
      10-31-2014, 05:26 PM   #17
zipphreak
Drives: m235xi
I just completed hooking up the dimmer wire. pretty easy. Just tight, I'm going to put up a separate post for people to refer to.
2addicts
