05-03-2020, 03:35 PM | #89 |
Rep 2,405
Were the tips you bought like clarkey's where the inlet pipe is smaller than the outlet? Or are the tips the same size on both ends?
2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
05-04-2020, 06:00 AM | #90 | |
Rep 180
05-04-2020, 06:01 AM | #91 |
Rep 180
Definitely the ones will have to be modded, as described on page 1 & 2
steinkda19840.00 |
05-04-2020, 09:44 PM | #92 |
Rep 2,405
Thanks mate, you have been very helpful. Last question...the ones you got do NOT look like the ones in my pic below....where the one inlet part of the exhaust tip is smaller than the outside part, correct?
05-05-2020, 11:34 AM | #93 |
Rep 66
The ones from BMS as picture, have a smaller section, and you screw some grub screw to lock it from falling off. The pipe that is the actual exit in the exhaust for the car widens at the end, so the sleeve slips over, and the screws prevent it from sliding over the thicker part.
No mods required, but I purchased some shorter grub screw as as the ones that came with it poke out a little too much (they are about 14mm long) but only a depth of 6mm is required, then the screw is flush when tightened, effectively using them. Then I added a little thread lock to prevent any rattling loose. Any more questions just ask. More than happy to post a little video of the fitting if it helps?? |
05-05-2020, 06:48 PM | #94 |
Rep 180
05-25-2020, 01:10 PM | #95 |
Rep 5
Drives: 2019 BMW M5 Competition
10-22-2020, 07:12 AM | #97 |
Rep 1,151
Drives: F90 M5 Comp (Evolve Tune)
08-29-2021, 07:22 PM | #98 |
Rep 764
Bring up this thread, any options available now for the F90 m5's? Seems its 75mm for the stock exhaust pipe. Really like these but doesn't list it being available for the F90's https://burgertuning.com/products/bi...=3180459753496
Spent a while looking on amazing and searches trying to find something that looks half way decent that will fit. Last edited by brad65ford; 08-30-2021 at 08:34 PM.. |
09-03-2021, 10:53 AM | #99 |
Rep 18
Just threw these on this morning. Only modification was to cut the metal pin on the pipe otherwise they were sticking out more than I cared for. Got them from Bimmer Plug. $600 for the set. Come in blue black or silver.
09-03-2021, 02:28 PM | #100 | |
Rep 172
Could you please post the dimensions of the tips, looking for something similar |
09-06-2021, 07:33 PM | #102 |
Rep 18
Specs are 76mm and length of 120mm. I have base M5 stock exhaust and they fit.. After looking at them over the weekend, I pushed the two outside tips further in. They were sitting flush with each other but I also thought the outside tip was sitting out too far and looked weird to me. They are staggered now. Looks better in my opinion but I have seen plenty of cars with both setups so just personal preference.
11-10-2023, 08:52 PM | #104 | |
Rep 6
11-11-2023, 10:24 AM | #106 |
@f90.kar
95
Rep 82
Anyone find carbon tips that fit on the LCI comp exhaust?
Found these and they say it’s a direct fit https://www.fjmotorwerkes.net/produc...f90-direct-fit
| M5C | Satin Black | Argon Brown | MAD Primary & Secondary Catless Downpipes | RC GTS Black |
02-29-2024, 11:59 PM | #107 | |
Rep 8
03-01-2024, 03:50 PM | #108 |
@f90.kar
95
Rep 82
Yes I did! They fit great, I had to cut off the alignment pin on the stock piping to make them work. It cuts off easily using a sawzall
