DIY: Centering the steering wheel after getting an alignment easily!
04-13-2018, 09:15 PM | #45 |
Rep 41
04-15-2018, 12:18 AM | #46 |
Save the manuals!
6028
Rep 6,754
Question: if my wheel tilts down to the left while tracking straight, which direction am I turning the driver's side tie rod (and thus the opposite for passenger side)?
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
04-15-2018, 03:39 AM | #47 |
Rep 32,881
That means your wheels are pointing to the right, so on your LHD car you would loosen the drivers side and tighten the passengers
05-16-2018, 04:32 AM | #48 | |
Rep 1,412
05-16-2018, 04:34 AM | #49 | ||
Rep 32,881
10-16-2018, 08:01 PM | #51 | |||
Rep 2,099
Well, probably gonna tackle this. Wanted to confirm a few things...
So drive up ramps or just drive into my driveway straight and leave the steering wheel crooked, and this process will correct the steering wheel while I'm working? So if my steering wheel is 6 degrees counterclockwise to go straight, I would extend the length of the (US) drivers (left) tierod and then shorten the length of the (US) passengers (right) side? And as suggested/estimated above, maybe two full turns? |
10-17-2018, 02:43 AM | #52 | |
Rep 32,881
bluewater328625.50 |
10-22-2018, 12:10 PM | #53 |
Rep 30
Nice DIY !
2011 335xi -JB4/MHD/Purestage 2 Turbo/BMS Intake/VRSF Charge Pipe/BMS Meth/Catless/Fuel It stage 2/VFRS 7inch FMIC/N20 Flex Fuel
Dyno'd at 475Awhp/473tq |
05-22-2019, 08:55 AM | #54 |
Rep 84
I'm in the UK and have a right hand drive. My steering wheel is also off centre 'slightly to the right a couple of degrees' so can I follow the OP original solution or do I need to do the opposite as his is LHD? Confused!
F10 LCI 530d - Full M Performance carbon fiber kit - Mineral Grey - H/K Stereo - Pro Nav - 20" 464M wheels
05-22-2019, 10:55 AM | #55 |
Rep 32,881
It's the same mate, just make sure however many turns you do on one side you do exactly the same amount in the opposite direction on the other side!
05-29-2019, 08:52 AM | #56 |
Rep 372
Nice DIY.
I loosened the locking bolt. But even after spraying copious amounts of liquid wrench, the tie rod just will not rotate and i didn't want to round the flat surfaces. Was using a 13mm wrench. Any tips?
X1 35i, H&R springs, Bilstein HD shocks, BMS JB4, BMS chargepipe, xHP trans flash
05-29-2019, 09:01 AM | #57 |
Rep 32,881
It's probably seized then and will need heat to loosen it.
09-24-2019, 08:05 AM | #59 |
Rep 257
Thanks for this. In the past I've found myself taking the car back multiple times asking them to centre the steering wheel. They often look at you like you've got two heads.
In fairness, when I've watched them centre the wheel and lock it in place with a holder tool before making adjustments, they have to lean into the car to do it with their head tilted (i.e. not sat in the seat). Presumably this is why they often get it a bit wrong. |
03-08-2021, 03:05 PM | #61 | |
Rep 693
I'm trying to apply this to my f30 and from what I can tell the rod ends are identical. The issue I am having is that I have loosened the locking bolt an now trying to turn the rod.... it is impossible! It must be seized I guess. Any tips?
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
03-08-2021, 08:39 PM | #62 | ||
Rep 6,196
gnolivos319.00 |
10-24-2021, 02:37 AM | #63 |
Rep 547
Hello, my locking nuts are a bit banged up and I’d like to replace them. Anything I should watch out for before removing the lock nut completely to replace it. The guide states to just loosen it so I don’t know if removing it completely causes any issues with the tie rod clamp. Thank you
11-19-2021, 07:04 AM | #64 |
Rep 15
nukezero if you still are over here, let me thank you because, today (9 years after you start this thread) you brought peace to my mind ... hahahaha
Yesterday I took my car to get an alignment and the steering wheel was on the left, today I took the car to the shop again and they re-adjusted the position steering wheel and I felt like still was on the left ... I started to think : I reached the point of madness where just me understand to me ??? and your thread come to say me a strong NO .... hahaha I will to adjust my POS by me own. |
gnolivos319.00 |
11-19-2021, 10:39 AM | #65 |
Rep 693
I just did this to my Honda CR-V and fixed it in 45 minutes after 2 adjustments. Wonderful.
12-12-2021, 12:42 AM | #66 |
Rep 556
nice DIY, thanks!
My steering wheel was off after alignment as well. I choose to go another route - went back to the shop and demanded to fix it. I got all kinds of excuses, but eventually owner realized that I am not going anywhere until it is fixed |
