10-19-2023, 03:50 PM | #1 |
Rep 221
aluminum valve cover
Mines a leakin. Iam goin to replace the gasket with a new valve cover as well. Does anyone know about the aluminum ones ive seen online? Supposed to be tougher than a new plastic ones. Anyone got any ideas.
Thanx in advance |
11-07-2023, 09:31 AM | #4 |
Rep 221
Ill let u guys know how the process goes. Cover looks flawless to me. New bolts as well
11-07-2023, 12:46 PM | #5 |
Rep 1,820
Not sure about the N55 but the N52 block was a magnesium alloy. The early valve covers needed special gaskets to prevent galvanic corrosion between the aluminum valve cover and magnesium block. This was the pre-LCI before they switched to plastic. Just a heads up in case it applies here as well.
Google says your block is aluminum so you're likely OK. I doubt they would make something that intricate for it to fail. |
zombem23515.50 |
12-07-2023, 02:12 PM | #6 |
Rep 221
Ive been doin sum google and forum searches on pricing this replacement. Sum shops or guys thinkin a couple hours sum say like six. I got a buddy who’s a decent mechanic. Never really done this on a bmw but he stats he will make great work of it. Iam thinkin 80/hr and maybe 4-5 hrs work. Only extra i want is plugs since most of those areas will be open during the valve cover process and an oil change. I am getting new pcv hose just in case and will be replacing the coils after the fact myself. What u all think about pay rate and anything else i need. Gettin the aluminum cover and aluminum oil filter cap powerdcoated to match. 2 different gaskets just in case. Anything suggestions wiuld be appreciated thanx in advance.
Ps i will probably be helping along the way. Out commission. Tore my shoulder up. |
01-23-2024, 10:39 PM | #9 |
Rep 221
Anyone know a secret to gettin these fuel rails off? Only one side has flare nuts. Every video i have seen have nuts on both sides of the smaller rails and r easy to disconnect?
Any help? Thanx guys |
01-24-2024, 11:04 AM | #10 |
Rep 81
https://youtu.be/PbPgSqXQ5eE?si=VNHbxb73SROY509L
Watch this video. It’ll help you through the process. |
zombem23515.50 |
01-24-2024, 03:27 PM | #11 | |
Rep 221
02-13-2024, 06:44 PM | #12 |
Rep 1
Any updates on how it went/how it's holding up? Need mine done soon and was debating the alu valve cover as well, would also love to see pics of the powder coated cover in place. thanks
02-13-2024, 07:17 PM | #13 |
Rep 221
Havnt fired her up yet but so far so good. It really has been fairly easy. Time but not complicated. Ill keep posting updates when she runnin. New plugs when u in there.
03-03-2024, 11:34 AM | #14 |
BM3 Tuner
316
Rep 291
Yeah the jobs not to hard, it took me 4 hours the first time and the second time 50 minutes. Just make sure you torque in the right pattern
2019 BMW X3M40I - VRSF Downpipe, XHP Stage 3, Nostrum Stage 1 Injectors, VTT PCV and Oil cap.
Paul Johnson Tunes Shop/Development Car |
04-26-2024, 08:17 PM | #16 | |
Rep 221
All the other little parts. Pcv hose. The eccentric valve gasket. I did use its own gaskets but i did buy a secondary just in case. I would also do plugs while u in there. I added new coils as well. Its timely but replace anything u can while u in there. My opion. Its got up and down reviews but i figured cant be worse than oem plastic one. Lol. Good luck. Keep us posted |
