European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      07-01-2022, 02:34 PM   #1
Magic M4
Magic M4's Avatar
48
Drives: F82
Stock turbo failure
Has anyone had stock turbos fail without having any of the symptoms of failure. Per my tuner we have ruled out all possible boost leaks and he believes the turbo might be bad. Only getting 16psi before wastgate completely maxout.
55k miles on the turbos.
IG: immigrant_racing_league
      07-02-2022, 07:47 AM   #2
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
If your turbos were "bad", you'd hear a loud whine and likely have oil consumption. I would look at the electronic wastegate actuators before deciding to replace turbos - your symptoms of low boost could be an indicator that one or both wastegates aren't closing completely.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
spidy512502.00
Jbonly211095.00
      07-02-2022, 03:44 PM   #3
Magic M4
Magic M4's Avatar
48
Drives: F82
The wastages pass calibration tests with ista, and they fully shut once I hit 16psi.
      07-02-2022, 11:37 PM   #4
papasmurf_m3
papasmurf_m3's Avatar
Drives: YMB F80 M3
how much oil does it consume between changes?
60-130 mph 6.72 secs
1/2 mile trap speed 158 mph
ecutek - bend calibration pro tune - flex fuel - mpe - stock turbos - oem+
      07-02-2022, 11:40 PM   #5
Magic M4
Magic M4's Avatar
48
Drives: F82
Less then 1qt over 5k miles. Oddly enough the wastgate max out and all possible tests were done and show no boost leaks, my next step is to replace the wastgates, the current ones pass all ista tests but I figure it's worth a shot.
      07-03-2022, 12:26 AM   #6
papasmurf_m3
Drives: YMB F80 M3
that's normal consumption.
Ive gotta set of perfect condition Wastegates if you need em.
      07-03-2022, 08:21 AM   #7
Magic M4
Magic M4's Avatar
48
Drives: F82
Pmed
      07-03-2022, 08:39 AM   #8
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
On the surface, what you're describing seems to indicate that the turbos are either not spinning up to full speed (which would normally be a bearing failure with accompanying noise) or some sort of exhaust or boost leak somewhere. There's also the possibility of false readings due to a bad sensor somewhere that is limiting boost. If you can check the wastegate positioning mechanically rather than depending on electronic readings, that would validate what's going on.
It could also be a sensor failure/inaccurate reading for intake air temp, oil temperature, coolant temp, exhaust gas temp, cylinder head temp, detonation, or any other reading that would cause the DME to pull back boost to prevent engine damage. I'd eliminate that as a factor before investing in replacing your turbos.
      07-18-2022, 10:20 AM   #9
Magic M4
Magic M4's Avatar
48
Drives: F82
Found the issue
Cylinder 1: 190psi
Cylinder 2: 190 psi
Cylinder 3: 180 psi
Cylinder 4: 195psi
Cylinder 5: 195 psi
Cylinder 6: 195 psi
Leak down results:
Cylinder 1: 10% leak down
Cylinder 2: 12% leak down
Cylinder 3: 25% leak down (Coming from exhaust)
Cylinder 4: 10% leak down
Cylinder 5: 15% leak down
Cylinder 6 10% leak down
sly1types431.50
      07-18-2022, 12:44 PM   #10
TopJimmy
TopJimmy's Avatar
Drives: 2023 M3 Comp xDrive
Found the issue
Cylinder 1: 190psi
Cylinder 2: 190 psi
Cylinder 3: 180 psi
Cylinder 4: 195psi
Cylinder 5: 195 psi
Cylinder 6: 195 psi
Leak down results:
Friggin owwwwwch!
Bad valve?
If yes, Headgames in NJ is the best.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
      04-25-2024, 01:45 PM   #11
trininav
Drives: Man
55k miles isn't low, but it's not super high either. Sometimes stock turbos just give out without much warning. If you need to replace it, there are plenty of options. A quick browse through https://goldfarbinc.com/ might give you some leads on quality replacement parts.
f80post
