      09-28-2025, 02:21 PM   #111
lotmo7
Drives: 2015 bmw 7 series
Nothin popped more than my Imola Red with beige interior & BBS wheels but the chrome style 5’s were nice also.
      10-19-2025, 07:19 PM   #112
Detailers Domain
Detailers Domain's Avatar
3002
Drives: 20 M2C, 22 X3M, 25 M2, 01 740
audio updates with Jack at Allboros Customs.
The components to the stereo upgrades were great, however some items were missing to make the system sound great. After speaking with Jack we were able to obtain our objective of getting a solid system running lossless.
Components
Helix V TWELVE DSP MK2
The Conductor / by Helix
Remove the system and start fresh, new wiring and making sure the components are fitting correctly in the doors etc.
The Bav Audio 5 inch woofers were all disconnected as they were the weak link in the system.
BMW 740i stereo upgrade by Detailers Domain, on Flickr
Untitled by Detailers Domain, on Flickr
BMW 740i audio upgrade by Detailers Domain, on Flickr
      10-19-2025, 07:47 PM   #113
tracer bullet
tracer bullet's Avatar
Drives: '25 Z4, '15 X3 35i (135i sold)
Nice! I haven't see the "sub in the footwell" thing in a long time. I bet that sounds spectacular.
      10-19-2025, 07:53 PM   #114
Detailers Domain
3002
Oil Change and filter change @98k ... leaky lower gaskets, tie rods and more suspension repairs coming.
Power steering was acting up, power steering fluid flush and filter removed
BMW e38 engine bay by Detailers Domain, on Flickr
BMW 740i maintenance by Detailers Domain, on Flickr
Piaa Aero Vogue Wiper Blades for the 7 a more period correct set up - as good as the Icon's were they just didn't look right and the passenger side end didn't get the coverage during the sweeps. Very happy with the Piaa's. I had to trim the wiper blade a bit back as it was hitting the window seal.
Bosch Icon
BMW e38 740 / Piaa Aero Vogue Wiper Blades by Detailers Domain, on Flickr
Piaa Aero Vogue Wiper Blades on
Piaa Aero Vogue Wiper Blades e38 BMW by Detailers Domain, on Flickr
BMW E38 740 I WITH Piaa Aero Vogue Wiper Blades by Detailers Domain, on Flickr
Nextzett Krystal Klar - Windshield Wash Fluid Top Off
Liquid Molly Jectron Fuel Injection Cleaner
      10-19-2025, 08:04 PM   #115
Detailers Domain
3002
sound is incredible! I'm gonna try to get a better head unit solution this is really now the only weak link to the system the head unit.
also we may put some mids in the a pillars to complete the system.
      10-20-2025, 04:25 PM   #116
RichTea123
Scotland
Drives: F54 & F56 Minis
That shine is exceptional, youve done this to a fantastic standard!
      10-21-2025, 06:50 AM   #117
Detailers Domain
3002
Front Suspension Maintenance and Upgrades continue
BMW Tie Rod Kit With Link - Meyle E38TIERODKIT-MY
OEM Part Number Associated with the Kit
3160404349, 1014578, 3160204351
Comes with center drag link and outer tie rod ends, the ideal solution for restoring your BMW's steering to factory condition
As your car's mileage increases, it is best to check the steering and suspension for excessive play due to wear. Additionally, if you are experiencing abnormal tire wear, or steering wheel vibration at speed you should also check these components for possible replacement.
Steering Tie Rod Assembly
The tie rods of your vehicle play a critical role as they're the link between the power steering rack and pinion and the wheel spindle. Tie rod ends contain ball joints that tend to wear out over time due to constant wear and tear. When the ball joints within the tie rod wear out, it allows for play within the wheels which can throw off your alignment and cause uneven tire wear. Its always encouraged to check your tie rod ends for play as well as tires for uneven wear at every service interval. When replacing worn tie rod ends its always recommend to replace them in pairs as well as to perform an alignment.
Steering Tie Rod Assembly Failure Symptoms
Uneven tire wear
Play in wheels
Pulling condition when driving
Sloppy steering
Turner Mono-ball Control Arm Upgrade Kit - Pre-installed - E38
Turner Motorsport
T#: 402092 | Part#: 022015TMS09KT
Product Details
BMW’s are known to have failure prone front thrust arm bushings. The flexible rubber bushings, even those found in M performance models, allow significant movement of the front wheels to maximize daily driving comfort, but also allow considerable alignment change. This results in a disconnected and numb road feel, standing between you and a confidence inspiring driving experience. Eventually the fluid filled rubber bushings fatigue and crack due to continual deflection and ozone degradation, and eventually the damping fluid leaks out resulting in complete failure.
For the enthusiast looking for superior performance and longevity with a crisp, confidence-inspiring driving experience, our sealed ball joint monoballs are the best solution available! Our experience with spherical front control arm ball joints goes back to those we designed and used in our IMSA E90 328i and E92 M3 race cars (GS class Champions in 2011). We wanted to offer as many BMW owners possible a similar level of handling, precision, and control for the track and street.
Utilizing a sealed OEM BMW ball joint for exceptional quality and durability, making them completely at home on both the street and track with no compromise. We have done extensive street, autocross, and track testing to ensure the ball joint used in this bushing design excels in each setting. The advantage of a sealed ball joint is that it eliminates all unwanted deflection while still allowing complete bind-free movement throughout suspension travel, resulting in exceptional control of wheel alignment. What you get is superior steering precision, turn-in response, direct braking feedback, and better handling.
In short, if you're seeking the ultimate in precise, predictable handling and control, with crisp braking response and a long service life that’s equally at home on the street or track - look no further. We have you covered.
We offer these control arms with the monoball bearings pre-installed for your convenience. Since BMW recommends the control arms be replaced for every other bushing change, we prefer to sell these as a pre-assembled set. The bushings are also available separately if you wish to source your own control arms.
Features:
Control Arm Bearing
CNC machined corrosion resistant 304 Stainless steel shell, bolt sleeves, & snap rings
Sealed spherical ball joint for long service life & maintained OE fitment
Suspension pre-load is no longer required when torquing the control arm hardware
Performance
Nearly instantaneous, crisp steering and braking response.
Maintenance free, long lasting performance.
Improved road feel without undesirable NVH.
Also the car has been leaking oil -
BMW Timing Cover Seal Strip - Genuine BMW 11141741127
BMW Timing Cover Seal Strip - Genuine BMW 11141741128
Once the parts get in we will be getting on this repair.
Add 10/24/25
Common problem: Rear View Mirrors failed - Ordered some Euro Spec BMW E38 Auto Dim Glass Mirror Heated and Dimming Aspheric Mirrors Set
(pre owned / crossing my fingers they looked good on photos)
Genuine BMW - 51168165112 (need to confirm)
