E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > 17" Square setup.. What offset?
Reply
      08-19-2008, 02:26 PM   #1
Ramos
Ramos's Avatar
Drives: G20 2020 M340
Hey guys,
ABout to pull the trigger on the Kosei's 17x8.5 from Tirerack
for a square track setup when I saw these D-Force LTW5 that I think look way better... They are 16 Lbs each and not that much more expensive than the Kosei.. They come in 17x8.5 ET 40 and I think 17x9 ET 41 ..
Which is the best size and the correct offset for my E90 335
for a SQUARE setup with no spacers and no rubbing.. (Stock suspension not lowered)
Thanks
      08-19-2008, 02:32 PM   #2
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
others have confirmed that 17x8.5 ET40 and 255 width tires don't rub expect during full lock parking lot maneuvers
i have no personal experience
      08-19-2008, 02:37 PM   #3
nj335i
Modaholic
nj335i's Avatar
Drives: with 3 pedals
I remember reading that not all 17" wheels will clear the 335i front brakes... just make sure you do your research before buying.
Euro Delivery - April 2007
      08-19-2008, 02:40 PM   #4
Ramos
Ramos's Avatar
I am doing my research by asking you guys !! ha ha
      08-19-2008, 03:05 PM   #5
leftcoastman
Drives: 335i
Test fit one at your next autox/track day.
If you look at the Koseis, the inside of the rims have this indentation that PERFECTLY fits the 335i brakes. It's so close that I always get rubber-booger marks on the inside of my rims.
If the LTW5 doesn't have that, you're screwed.
      08-19-2008, 03:59 PM   #6
satakal
satakal's Avatar
95
Drives: e46
Dude, Ramos, you don't need Kosei's... I'll sell you a beautiful set of 162s for the same price as you'd pick up a set of Kosei.
________
Web shows
      08-19-2008, 04:26 PM   #7
longodj
longodj's Avatar
Drives: 135i
2007 335xi  [0.00]
1974 VW Beetle  [0.00]
Just get the Koseis you can't ask for a better fit
      08-19-2008, 05:14 PM   #8
Ramos
Ramos's Avatar
WAAY to heavy.. Plus isn't that what I already have?
      08-19-2008, 05:15 PM   #9
Ramos
Ramos's Avatar
I know but they're sooo ugly
      08-19-2008, 05:21 PM   #10
satakal
satakal's Avatar
95
Drives: e46
uh yeah. But, you can run whatever rubber you want on your non-leased set of wheels.
I don't believe in that whole unsprung mass thing anymore. If I can't feel it, it isn't real!
________
Avandia death
      08-19-2008, 05:23 PM   #11
leftcoastman
Drives: 335i
Show or Go? Aren't these your track wheels? Have you seen a set of track wheels after a few rounds of brake dust being baked on them?
If you want show, get some Chrome 20s.
      08-19-2008, 05:27 PM   #12
Ramos
Ramos's Avatar
I want go.. But if you can get good looking wheels that weight just as little actually a little less then the Kosei for just a little extra cash, then why not?
      08-19-2008, 05:28 PM   #13
Ramos
Ramos's Avatar
Please people... Can someone just tell me what would work better
17X8.5 ET 40 or 17X9 ET 41 ??
      08-19-2008, 06:03 PM   #14
satakal
satakal's Avatar
95
Drives: e46
I don't think anyone can give you an answer they are willing to stand behind on the 9in wide wheels.
The Kosei is a 17 that fits. The SSR 17 that the guy who won 6cyl stock at the autocross was trying to sell doesn't fit.
the only rule of thumb to follow sounds like... "if the shoe fits, buy it."
________
Buy vapir vaporizer
      08-19-2008, 06:52 PM   #15
Ramos
Ramos's Avatar
Here is a link to these wheels in case anyone wants to see what they look like..
http://store.bimmerworld.com/shared/...t=products.asp
They were also featured on the blue 135 in August edition of Roundel magazine
      08-19-2008, 07:10 PM   #16
blipblip
Drives: e90 335i, 2008 M6
Talk to these guys:
http://www.vorshlag.com/index.php?cPath=1_79_90
*Ultimate* mod for the car: a better driver...
      08-19-2008, 09:19 PM   #17
longodj
longodj's Avatar
Drives: 135i
2007 335xi  [0.00]
There's no chance in hell that 17x9 ET41 wheel will fit without spacers or rubbing. I just put KW V3s on and my Kosei K1 17x8.5 ET40 (245/45/ZR17, -2.6 camber) is rubbing under full lock with the drop. Without the drop I think it was leftcoastman that mentioned there's a like...6mm space between the strut and the wheel, you'll lose that with the 17x9 ET41. In that case you'll need spacers which have a host of downsides over time.
I see no reason not to get the K1s especially since they're cheap as hell (IIRC $100 cheaper than the LTW5) and look one hell of a lot better in person than online. Leftcoastman is right, it's a question of go or show. The LTW5 and K1 look almost identical... I think the LTW5 is uglier but the fact is it doesn't matter. After one lap they'll be covered in dust and look like shit anyway.
      08-19-2008, 09:21 PM   #18
longodj
longodj's Avatar
Drives: 135i
2007 335xi  [0.00]
Yes and the magical track fairies carry my car around, that's why when I close my eyes and make believe my car only weighs 1800lbs. In reality it's 3800 but who cares right?
Unsprung mass makes a huge difference and if you look for it you'll notice. The car gets much more responsive moving from the craptastic stock wheels to aftermarket lightweights.
      08-20-2008, 09:21 AM   #19
satakal
satakal's Avatar
95
Drives: e46
:-) Its all good.
I'm not gonna argue with a Newtonian equation. I don't need the bloody nose. I'm just saying that I saved 10lbs per corner with a new wheel/tire combo and my driving spidey senses aren't sufficiently sensitive to feel a difference.
Ramos: those wheels are ugly. IMO. But, I've been wrong before. I think the C30 is hawt.
________
Live Sex Webshows
      08-20-2008, 09:21 AM   #20
sg335
Drives: 335i
The 17x9ET41 will need 5mm spacers in front to work. Unless you plan on running larager than 245's, the 8.5" width is fine.
      08-20-2008, 10:08 AM   #21
leftcoastman
Drives: 335i
Yeah, like I said, I'll rub in the parking lot with Koseis and 255s. I have yet to experience full lock on track at speed, so no rubbing on track, lol.
THE BIG UNKNOWN WITH THE LTW WHEELS IS BRAKE CLEARANCE. It barely, barely fits with the Koseis. If the LTW doesn't have the same schpanky stepped design, there is no way it will fit.
IF the brakes fit, a LTW5 17x9 ET41 with 5mm spacer will probably still work, even with 255. On the Koseis, the issue was that the wheel was getting close to strut - lowered or not doesn't make a difference there. The tires were fine. Deflection under cornering load generally occurs on the bottom half of the tire anyways and I never got "rubber" on my strut tube.
With the Kosei, I had 6mm between strut tube and wheel. The 17x9 would protrude inwards an additional 6.35mm (1/4 inch) from the wheel width change and 1mm from the offset. That gets you 7.35mm inwards, which would NOT work without a spacer. With the 5mm spacer, you would be 2.35mm inwards compared to the Kosei, basically cutting half your clearance. That's too close for comfort in my mind.
      08-20-2008, 10:13 AM   #22
leftcoastman
Drives: 335i
Because you will be adding weight via spacers, add more wear to your bearings via spacers and risk snapping your bolts off via spacers.
But girls risk a lot when they wear high heels, right?
Reply
e90post
