Closed Thread
      01-14-2012, 03:01 PM   #5963
The1
Drives: white 135
Originally Posted by dcstep View Post
Good focus, exposure and about the right shutter speed. I wouldn't pan that one, focus on the hand holding the food up and, use around f/8 or f/11 to get some DOF, and try to move around where you have the bird coming toward you and then shoot. This is where shooting 8-fps is a huge help. You might keep both eyes open so that you can see the bird approaching.
Dave
I learned this while shooting horse jumping. when only looking through view finder, you often find yourself taking a wild guess at what's about to happen. Or you find yourself watching and waiting till last minute to lift your camera to your eye to get the shot.
keeping both eyes open pretty much allows one eye to see the subject approaching, and just as they leave sight of one eye, they enter the sight of the other eye.
and you don't look goofy with half your face all scrunched up while shooting.
great advice dave.
      01-14-2012, 03:27 PM   #5964
The1
Drives: white 135
just goofing about.
Any advice on black and white PP?
watch-1 by Reed Jackson, on Flickr
      01-14-2012, 07:03 PM   #5965
The1
Drives: white 135
just for fun, you can tell it's a cold night by the smoke stacks.
why my lightroom exports photos, they seem to get darker after being made into jpegs, anyone else experience this?
      01-14-2012, 07:57 PM   #5966
dcstep
Drives: '09 Cpe Silverstone FR 6MT
2009 M3  [8.40]
What do your default settings look like? I don't use LR, but with DxO I've got preset set to apply an S-curve, add Contrast and add Vibrance. All those will make a finished image look darker. I sometimes add a little brightness to offset when I didn't expose enough "to the right" in my initial image.
I would guess that it's easy to develop your own preset. For the image you show I'd like more Contrast and a little pull down in the RGB curve, if I were doing it myself. Those sliders and curves are all there for your usage. Don't be afraid to push and pull on them, just don't get carried away. (The Saturation slider is where too many people go astray).
Dave
      01-14-2012, 08:24 PM   #5967
The1
Drives: white 135
Dave
no presets, just simple settings, i like going through my pictures 1 by 1 unless i know there's a grouping like if i do a photoshoot with friends, then i can do a mass edit, then small tweaks, but i start from 0 on everything.
Light room shows you the finished picture, but i'm assuming that somewhere in my transformation from RAW to JPEG somethings going a bit wrong, and i'm losing brightness or exposure, or something. Maybe i've got my quality set too low, and this is the result.
      01-14-2012, 08:45 PM   #5968
dcstep
2009 M3  [8.40]
I set my jpeg quality at 100%. Why wouldn't you???
I think that you should try to find a preset that suits you. The whole point of LR, to me, is to establish your "look" and show your images like you'd like them to look. I like contrast and detail. Many people like an S-curve in their RGB or a pull-down in the middle of the RGB. If your jpegs look like they came out of the camera, what's the point?
Those setting in the camera, like "Scenic", "Portrait", etc. are applying RGB and Contrast adjustments to the in-camera jpeg. You should figure out what you like and use it. Yes, you'll still need to look image by image and tweak, but you'll start from a baseline that you like.
Dave
      01-14-2012, 08:51 PM   #5969
The1
Drives: white 135
turns out my quality was at 100% afterall
I don't actually change many of my photos over to JPG, so i don't have a need for high quality as most of the jpgs will just become online files viewed on computers.
if i do a shoot for someone, I change all the settings and sizes to suit the need, and put the quality at 100% And if i know pictures will be printed I put the resolution up to 320ppi or in and around that area, so there's the option of size.
I've only been noticing this problem since i installed version 3.7 as well, so i'll have to look into it a bit more and see what's what i guess.
      01-15-2012, 09:27 AM   #5970
MATT0404
Drives: 2015 M3
Dave
Thanks, Dave. I guess I really wasn't panning in this particular shot. I was actually focused on the hand and waited for the bird to swoop down for the worm and started firing. I guess this is where you run into the limitations on the 5d2. I probably should have thought about using the 40D. Great advice to keep both eyes open to track the subject. I really hadn't thought of that before.
Here's another shot from inside. The Steller's Sea Eagle. A very impressive bird:
Steller's Sea Eagle by mkrepp, on Flickr
      01-15-2012, 09:28 AM   #5971
The1
Drives: white 135
great detail
      01-15-2012, 09:30 AM   #5972
Chewy734
Drives: 2006 BMW 330i ZPP, ZSP
awesome shot Matt!
      01-15-2012, 09:33 AM   #5973
MATT0404
Drives: 2015 M3
Thank you, both!
      01-15-2012, 09:49 AM   #5974
dcstep
2009 M3  [8.40]
Super portrait of the sea eagle. It looks like it's snowing which makes a really special captive shot.
If you owned a 7D, I might agree about using a crop-sensor vs. the 5D2. The 40D's processor and pixels aren't up to competing with the IQ of the 5D2, even when the image is cropped down to the same subject size as the 40D.
The 7D has a smaller pixel-pitch, slightly better AF and 8-fps vs. the 5D2, but, except for the 8-fps, all that stuff is very close, making which one to use pretty much a toss up for things that aren't moving fast.
Dave
      01-15-2012, 11:55 AM   #5975
M_Six's Avatar
Nap Time
"There is no shame in dropping fruit in your glass."
      01-15-2012, 12:33 PM   #5976
The1
Drives: white 135
still working with the 135?
      01-15-2012, 12:59 PM   #5977
M_Six's Avatar
Yep. Lovin' this lens.
      01-15-2012, 01:00 PM   #5978
The1
Drives: white 135
so you're putting it on the "to sneek past my wife" list?
      01-15-2012, 01:08 PM   #5979
M_Six's Avatar
Not for a while yet. I'll own one eventually, but first comes the 7D and then a 70-200mm F4L IS. Then some more MF lenses. If a 135 in good shape shows up on CL with a decent price, I may find a way to grab it. Otherwise it will have to wait. It'd be more of a luxury lens for me.
      01-15-2012, 02:28 PM   #5980
bosstones
Drives: o_0
Cool B&W image, Jeff. Where is that?
Hey, Mark. Thanks. That is the Ferry Arch in San Francisco. It's up in the wharf area. Sorry for the delay in responding. Rarely been on the forum since last spring.
      01-15-2012, 04:08 PM   #5981
dcstep
2009 M3  [8.40]
Mule-deer buck lounges in morning sun:
Big mule deer buck lays down by dcstep, on Flickr
Instead of the 7D, this one's with the 5D MkII and the 500mm.
      01-15-2012, 04:27 PM   #5982
M_Six's Avatar
Nice rack! Great pic, too.
      01-15-2012, 04:44 PM   #5983
gary88
Ikea enthusiast
gary88's Avatar
Drives: '07 E92 335i
2007 E92 335i  [7.96]
Mixing board by garyhebding, on Flickr
      01-15-2012, 08:00 PM   #5984
Seminole
Seminole's Avatar
Drives: Red Flyer
2008 E90 328i  [7.00]
Bellagio Roof by Seminole, on Flickr
Closed Thread
