ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Engine, Exhaust, Drivetrain Modifications
  TireRack
      11-05-2017, 05:53 PM   #1
apexhittinbull
Drives: E85 M
S54 Possible cam bolts failure sound? or normal
Car has 22,000 miles
Started up today found the noise bit too much or concerning.
Are my cam bolts shearing and failing?
S52 on E36 I had long ago never sounded this loud
Here is a video link to cold idle
And Hot idle after trip to lunch and back
Is it time for Valve adjustment/Vanos rebuild/Cam bolts replacement already?
Your opinions are greatly appreciated.
The car was inspected for pre-purchase at BMW retailer, notes Vanos operates well.
Car build date is May 30th, 2006
The engine built in Munich, of course, can be earlier.
NickyC17679.00
      11-05-2017, 07:07 PM   #2
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
That certainly sounds like the noise I was getting. Mine started out a light knock that would go away once the car was warmed up. It quickly got worse. It was loose bolts on the VANOS intake side sprocket. It means the bolts have worked themselves about half-way out. Mine has a build date of March 2006, so very close to yours. It's a little early for the valve adjustment, but while you are doing the VANOS, the valve cover will already be off.
Beisan Systems offers some great kits. I feel like my VANOS is now rock-solid.
Here is the sound I was getting:
Salty
2006 BMW Z4M Interlagos Blue/Black
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete
NickyC17679.00
      11-05-2017, 09:25 PM   #3
NickyC
NickyC's Avatar
17679
Wow thanks for posting those videos, they sound almost identical. Certainly not a rod knock obviously, so this must be the tell tale sound of loose VANOS bolts. I'll definitely keep an eye out for this noise, and if it ever occurs I'll get my car towed to the shop pronto. Thanks again!
SaltyNC369.50
      11-05-2017, 11:44 PM   #4
apexhittinbull
Drives: E85 M
Thanks so much for sharing, Salty NC.
Confirmed the loosening cam bolts now.
your compartment removal is very well written as well.
But wow, the pre-purchase inspection cost was $149..
I wonder how dealers check for vanos operations and if this mechanic had any knowledge or experience I could have saved money.
SaltyNC369.50
      11-06-2017, 07:40 AM   #5
SaltyNC
SaltyNC's Avatar
370
Glad to be of assistance. If the car was warm when the tech did the PPI, it would be tough for them to identify the VANOS by listening to it. They would have to remove the valve cover, and I don't think that is normally done on a PPI. It seems like VANOS work is required eventually on most of the S54's, so it more than likely would have eventually had to have been addressed regardless.
When we did the VANOS on my S54, we did everything. We replaced all seals, we replaced the oil pump disk with the smaller holes, replaced the bolts and used Loctite, installed anti-rattle kit, and used the "springs" from the S65 engine, and swapped the VANOS solenoid with one that Beisan epoxies to reduce solder failures. Now, I don't worry about the VANOS at all, and the car was much smoother and more powerful after the upgrade. I had an RPM dip when I would crank it in the morning so much that I learned to give it a little extra throttle to keep the RPMs up. That went away completely after the VANOS upgrade.
Good luck with your VANOS repair.
Salty
Finnegan707.00
      11-08-2017, 03:54 PM   #6
mattfwalters
mattfwalters's Avatar
Drives: 06 Z4MC (Sepang/Sepang/insane)
Salty
+1 to everything Salty said here - bottom line is that a VANOS refresh along these lines, as well as a valve lash adjustment, is just a good thing to do with a new-to-you S54.
It's also not that difficult if you're not pulling the cams, just time-consuming.
      12-06-2017, 07:44 PM   #7
apexhittinbull
Drives: E85 M
Opened it up, finished Beisan seals, oil pump, sealing plate kit.
Purchased Beisan Anti-Rattle Kit as well, but decided against installing it, my spline shafts have no axial play at all.
Exhaust spline shaft has ever so slight axial play with a hard pull.
at 23,000 Miles Bolts can be loose as much.
StickMon636.00
SaltyNC369.50
Vanne1623.50
      12-07-2017, 09:45 PM   #8
SaltyNC
SaltyNC's Avatar
370
Exactly how my bolts looked. Glad you got it early.
Salty
      12-08-2017, 08:15 AM   #9
Beedub
Drives: 2007 Z4 M roadster vt2-500
some really silly little mistakes on this engine that are really costly....
OP how difficult was the install..... ???
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com
      12-08-2017, 10:18 AM   #10
ZAR4MC
South Africa
93
Drives: '07 Z4 M Coupe
Good save!
07 Z4 ///M Coupe - Sapphire Black / Imola Red
My S54 Journal
      12-08-2017, 11:03 AM   #11
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6226
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
I did the same, didn’t feel like I needed to install the rattle kit and sold it here for a few bucks instead.
beisan, can’t recommend them enough
she’s home! '22 M4 Comp xDrive
      12-08-2017, 05:41 PM   #12
apexhittinbull
Drives: E85 M
I just finished and she starts up normal if took a bit longer cranking and idles normally.
I let it reach 170F~ish and there is no "you're doomed" light on.
-I was overwhelmed mainly because of timing might get bit loose, and made an appointment with the indy shop before I found a great deal on the whole timing toolkit over the Thanksgiving and decided to tackle it myself.
-I would say it is not too hard if you take it slow and go bit OCD, for each of the 24 vanos bolts to be tightened with it open I swiped my hand every time with a shop towel, and marked the hub, chain, tooth, splines, carefully with multiple shots.
-Biggest O S moment was when I dropped a Wally shim doing the valve adjustment and couldn't find its where about. Found it by the door to the crankcase and shop towel, managed to put a magnet on it and pulled it.
-And I dropped a bolt only after she started up, I dropped a bolt for the strut brace, guess seeing she starts well sorta put me attention off.
Need a shower and a cold lager, and a back massage uh
SaltyNC369.50
StickMon636.00
      07-19-2018, 05:13 PM   #13
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
Glad I found this thread. This verifies to me that I should check out my VANOS while I have my '06 Z4MR opened up for the Inspection II valve adjustment. Currently, I don't hear any unusual noises but I'd rather be proactive.
2006 Z4 ///M, Interlagos Blue/Beige
2006 Z4M Interlagos Blue/Beige
      07-31-2018, 01:03 PM   #14
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1624
Drives: 2007 Z4MC
yup wow, those were pretty darn loose, good catch mate
2007 EuroSpec Z4///MC - Building/Developing Z4 GT3
Powered by
      08-01-2023, 02:05 PM   #15
bkM3
Drives: 06 M3 Vert 6MT Carbon/Black
hate to bring this thread back from the dead but i believe im experiencing the same sound on my e46 m3.
thoughts?
https://www.youtube.com/shorts/jZ00RraEBos
https://www.youtube.com/shorts/pvU4xaUe6Dw
https://www.youtube.com/shorts/7-_E1BErJHE
      08-01-2023, 04:51 PM   #16
grannyknot
grannyknot's Avatar
953
Drives: 2008 Z4M coupe
thoughts?
Hey, if the thread is relevant to your situation, bring it back.
It certainly sound similar, don't keep driving it, order the bolt kit and swap them out, it's BMW expensive to have them break.
2008 E86 M coupe
      08-01-2023, 04:59 PM   #17
bkM3
thank you, i appreciate it
      08-10-2023, 09:24 AM   #18
bkM3
it turns out the knock/rattling sound was loose vanos bolts as well as one that completely broke. looks like we caught it before it did any damage,
this thread was a lifesaver. thanks guys
here is a video
      08-10-2023, 03:31 PM   #19
grannyknot
grannyknot's Avatar
953
Well done.
2008 E86 M coupe
Tags
cam bolts, rattle, s54, vanos
zpost
