2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning In-Depth Guide to Tuning your M235i
      06-24-2017, 02:31 PM   #45
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
Originally Posted by Hasser View Post
just read this - had a 235i for a month now - I already had the JB stage 1 from my N55 on my previous 5 series.
question is can I run the JB stage 1 with a 200 cell DP?
don't want to waste the JB stage 1 and have to spend on JB 4
I think the harness from your 5 series is different. If it's the same, no harm in running it with DP.
FBO M235i r
F80 M3
      06-24-2017, 02:51 PM   #46
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
I confirmed it's the Same
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      05-15-2019, 08:13 AM   #47
js0228
Drives: M235i Xdrive and M2
Originally Posted by ocN55 View Post
I thought I would make this thread to try to help folks new to the M235i platform and that want to know how to make it faster. I've learned some useful information through some personal experience and communicating with Terry of BMS both online and in person. Many of the info here would have been helpful to me 6 months ago. I'll try my best to improve the post as well.This thread will only be about the piggy back tunes.
The first decision I suggest you to make is whether or not you are getting or plan to get a downpipe down the line.
Path #1: "No Downpipe!"
You may want to consider this path over the other for the following reasons:
  • Best HP/dollar value or "Bang-for-Buck"
  • Very easy to install or uninstall mods for dealer visits
  • Don't have to touch the Catalytic Converter
  • Lower chance of getting codes or lights on the dash
  • No need to update or tweak your tune
What you need:
  • A Stage 1 tune
Dyno charts show 323whp and a whopping 365wtq! This will be about 30 more whp and about 35whp over stock, not bad for a few hundred bucks.
This is a very comfortable setup as the car will be making power well within its capabilities. Just choose a plug and play tune such as the BMS Stage 1 or the aFe Scorcher, both popular and very similar products with similar results. The Dinan Stage 1 may also be something to consider if you value your warranty as Dinan offers a factory-matching warranty, but expect to pay an extremely large premium for this.
You can pair one of these tunes with its respective intake for power and a lot of sound. I've personally had the BMS Stage 1, the more popular of the two, with the BMS F30 intake. Additionally a catback or axelback exhaust of your choice could be added for pleasure but not power gains.
Stage 1 Tune Options
BMS N55 Stage 1: http://burgertuning.com/N55_Jb_BMW_P...nce_Tuner.html
aFe Scorcher: http://afepower.com/shop/details_new...rtno=77-46304&
Dinan Stage 1: http://www.dinancars.com/product/d44...ries&mid=1183/
RaceChip: https://www.racechip-usa.com/chiptun.../M-235i-240kw/
Even more STG1 choices: http://www.2addicts.com/forums/showthread.php?t=1110399
Intake Options
BMS Intake: http://burgertuning.com/F30_335_F32_...ke_filter.html
aFe Intake: http://afepower.com/shop/details_new...rtno=51-12202&
Dinan Intake: http://www.dinancars.com/product/d76...ries&mid=1183/
Injen: http://www.x-ph.com/injen-short-ram-...-335i-435-n55/
Path #2: "I want a Downpipe!"
Why you would want to take this path?
  • Even more power
  • The effective use of E85 Mixes and Race Gas
  • Awesome spooling sounds from being catless
What you need:
  • EWG N55 F series BMS JB4
  • Your choice of a downpipe
  • An Intercooler (Recommended)
  • A Chargepipe (Recommended)
Now this is where things can get more expensive and risky as you can push the car closer to it's limits. With addition of a downpipe, the car will no longer have a "bottleneck" effect going on due the elimination of the restrictive factory cat. The turbo will be able to run higher boost and spool much quicker for a gain of 40-80whp and 50-90wtq more over stock depending on tuning and fuel.
Pick up a downpipe such as the Evolution Racewerks 4in Catless DP, fitment was spot on for me. I've heard that Shifteck isn't bad either and also made in the USA; VRSF is made overseas. The new PDU downpipe looks to have a fantastic design. I would *personally* advise against catted downpipes. Save your money here because chances are you won't pass smog anyways, and if you do then the downpipe isn't very effective.
You will also need a BMS EWG JB4 for F series in addition to the downpipe. The M235i is equipped with an Electronic Wastegate that is also found in 2014+ 335i and 435i, therefore the "EWG Specific Board" should be used. And to my knowledge, the JB4 is the only tune that will allow for EWG control. The JB4 will tune the car to be able to take advantage of the downpipe as well as automatically clear the light that will occur from being catless. Additionally, the JB4 will allow you to run different "Maps" and fuel for different power applications. Such is the reason why I advise against spending the extra money on a JB4 unless you go with a downpipe, you would only be using Map 1 which has practically the same gains as the BMS Stage 1 (or other Stage 1 tunes I mentioned) but you add the complications of user adjustments and firmware updates.
Do not pass on the USB datacable as you MUST datalog your car with this setup to make sure that your car is running optimally, and yes you will want a USB extension cable. Also purchase the $35 "EWG Harness Adapter", this is currently under upgrades but should be considered necessary because it lets you consistently hit target boost. Without this, you will be only able to effectively run Map 1 or 2 on the JB4. You will also need the recently released "F Series OBDII CANBus Interface" upgrade because all updates now will be using an OBDII Firmware. FlexFuel wires are standard now on JB4's currently sold.
Some nice upgrades to have are an intercooler and chargepipe upgrade from ER. I suggest going with ER as their chargepipe best fits their own intercooler. Map 7 in the JB4 is the most aggressive tune for the car and pretty much warrants these two upgrades. The intercooler helps makes a little power, cooling, endurance for turbos + engine, and just all around beneficial. The chargepipe (CP) will not give you gains but under Map 7, the stock plastic CP will eventually see failure. There have been instances of stock N55 cars with failed CP. The way I look at it, being able to run Map 7 should be the reward of doing these upgrades. Familiarize yourself with the difference Maps here.
Lastly, taking this path will require you to be a more active and knowledgable than the the other path. The JB4 firmware for our cars I still consider as beta since there is much more room for improvement, N55 F series cars are running very lean. You will need to be in touch with what's going on on N54tech and be prepared to run into codes. If you've made it this far in the post, then you can see how much more involved and nuanced this path is. Isn't it crazy how one downpipe warrants so many more upgrades? Though I can say that it is a very rewarding experience
Tune
BMS JB4 (Choose EWG option to get the EWG Specific Board): http://burgertuning.com/N55_JB4_F_ch...BMW_tuner.html
http://www.burgertuning.com/N55_JB4_upgrades.html
Catless Downpipes
Evolution Racewerks:http://www.evolutionracewerks.com/node/213
PDU: http://www.performancedesignunlimite...tless-downpipe
Shifteck: http://www.ebay.com/itm/Shifteck-N55...1fd94c&vxp=mtr
Fabspeed: http://www.fabspeed.com/bmw-m235i-f2...pass-downpipe/
VRSF: http://www.vr-speed.com/vrsf-ceramic...0-f32-f33.html
Intercooler and Chargepipe
ER IC and CP: http://www.evolutionracewerks.com/catalog/212
Now that you know what it takes, hit up the vendors
Hey ocN55 nice info! But one question. Terry wrote Map7 requires straight unleaded race gas. So you were using straight race gas with Map7? Do you think I'll be able to use E30 or E40 mix for Map7? Since I cant run full E85
      05-24-2019, 06:11 PM   #48
MLJR235
MLJR235's Avatar
117
Drives: M235I
Holy thread revive lol ...Simple answer is, I believe, 100oct or higher is required in Map7 (plus FBO).
IF your current vehicle can handle whatever ethanol mix is needed to achieve said octane(e50/e60), then you're all set. From what I have read, some good mods to support this are JB4+backend flash, LP fuel pump upgrade, "in-line booster" Fuel-IT mod i think it is.
There may be more but maxed out trims is our first hurdle from running anything too far up north of E30. This is the same reason I am just about to get the e85 BEF from BMS/MHD
N54, 2addicts, and some other forums have a gold mine of info man. We are blessed in that aspect of things
      10-10-2019, 09:34 AM   #49
BavarianMotorWorkz
Drives: 16 M235ix
What you need:
  • A Stage 1 tune
Intake Options
  • Even more power
What you need:
Tune
Catless Downpipes
Any reason why you'd pick JB over BM3 other than personal pref?
      10-16-2019, 07:40 PM   #50
ocN55
ocN55's Avatar
[SIZE="4"]Path #1: "No Downpipe!"[/SIZE]
[IMG]http://burgertuning.com/images/dynos...tage1_dyno.jpg[/IMG]
What you need:
  • A Stage 1 tune
aFe Scorcher: http://afepower.com/shop/details_new...=77-46304&
Dinan Stage 1: http://www.dinancars.com/product/d44...&mid=1183/
RaceChip: https://www.racechip-usa.com/chiptun.../2-Series/2er-(F22)/M-235i-240kw/
Intake Options
aFe Intake: http://afepower.com/shop/details_new...=51-12202&
Dinan Intake: http://www.dinancars.com/product/d76...&mid=1183/
[SIZE="4"]Path #2: "I want a Downpipe!"[/SIZE]
[IMG]
View post on imgur.com
[/IMG]
  • Even more power
What you need:
Tune
Catless Downpipes
Shifteck: http://www.ebay.com/itm/Shifteck-N55...4c&vxp=mtr
This thread was created before these cars were anywhere close to being flashed
FBO M235i r
F80 M3
      11-25-2019, 03:21 PM   #51
KennyFSU
KennyFSU's Avatar
1104
Drives: Lexus RC F
Great write-up, thanks.
Is the Burger JB Plus tuner equivalent to a "stage 1 tune?"
      12-31-2019, 09:08 PM   #52
MBlaster
Drives: 2015 M235i red 8sp
Great post, still relevant after four years. I'm curious if there are any packaged tuners for my M235i similar to the Cobb AP I used with my WRX years ago. In addition, would they be as flexible as my AP. I used the AP from Stage 1, Stage 2 OTS map than through two stages of custom builds. My 235 is still under the CPO extended warranty and will be for a little over a year so, I might consider a Stage 1 tune until out of warranty. Maybe a few years down the road, Stage 2 and probably stop there. Is there a mod I can get that would allow me to run Stage 1 and later Stage 2 with the addition of an aftermarket DP, intercooler, CAI without having to scrap the hardware used for Stage 1?
      07-28-2020, 09:53 PM   #53
TACP
Drives: 2015 M235I xDrive
Well I am glad is was brought back. Currently have a stock 2015 M235i with Xdrive. I'm planning on VRSF downpipe, Charge pipe, and intercooler. With Stage 2 Bootmod3. Also CAI and Dinan axle back exhaust. I can only get 91 octane here in Kansas. Will this be a concern other than I won't get as good performance as possible, or will 91 actually hurt/damage stuff?
Also, with all the stuff listed above which VRSF intercooler is right for me? I'm new to tuning so go easy.
      08-04-2020, 01:44 PM   #54
Texan2er
Drives: 2015 M235i
In regards to intercooler, unless you are doing track days with longer sessions, VRSF's 5" race intercooler should be more than sufficient for your Stage 2 power on the street.
      03-05-2021, 10:35 AM   #55
Captain Blood
Drives: Audi S3....don't judge me
2016 Audi S3  [9.50]
2012 135  [6.83]
Another thread revive!
I will be getting a 2015 m235 in the next 10 days. I will also be getting a Racechip stage 1. Is this plug and play? Can I disconnect without a trace if I get an extended warranty and need service? Also, how hard is it to replace the chargepipe compared to a 135? I have a garage down the street that charged me $75 to install one I ordered online.....
      03-14-2021, 08:40 AM   #56
SeanE
Drives: '16 m235i
Hey all,
Anyone who is running a stage 1 tune from Burger for example, still running the original charge pipe? I have a '15 that still has the original pipe and have gathered from several threads on here that if you're running stock, to leave the pipe alone, but any 'tune' or added power and you should change it out pre-emptively. Is this true for just stage 1 and not really intending to track or autox the car anytime soon?
thx
      03-14-2021, 05:37 PM   #57
4Hockey4
Drives: Pinto
Originally Posted by SeanE View Post
Hey all,
thx
Chargepipe has been blowing stock, lesser chance than when tuned. I'd be surprised if anyone said to leave it, stock or not.
      03-16-2021, 08:36 PM   #58
SeanE
Drives: '16 m235i
I've also read some opinions online that unless running more power, leave it alone. IOW don't change it out 'pre-emptively' which differs somewhat from certain threads on this forum.
2addicts
