08-21-2024, 04:11 AM | #1 |
Rep 4
hey, I’m Siddhant from India my X1 had stalled in water and it has happened before but that time engine flushing and changing oil solved it but this the service centre said there’s less compression in engine and the engine is starting but there was water coming out from exhausts and white smoke which was probably vaporised water tho they say it needs engine replacement is it really not fixable? As last time my car was in a lot more water and I even tried to start the car 3 times, this time I didn’t start it and turned off the engine so it doesn’t do further damage, so can it really cos this much damage to my car or are they just trying to rip my pockets
Would really be helpful to know your thoughts |
08-21-2024, 08:24 AM | #2 |
![]() ![]() 1545
Rep 1,486
What if any damage the engine suffered can't be known at a distance. Someone has to get his hands dirty.
One way to approach this would be to drain the oil and change it along with the filter. Ensure the air filter is not water logged and there is no water anywhere in the intake system. Remove the plugs and crank the engine. Then perform a cylinder compression check. If compression is down in any or some cylinders the engine is (probably) toast. Probably. Depending upon the damage the engine might be repairable but you would be facing a complete engine tear down and relying upon the mechanic to be able to correctly identify the damage, and if repairable correctly perform the necessary repairs. If the compression tests ok then new plugs and run the engine. But whatever you possibly do one thing you must do is avoid water crossings. |
08-21-2024, 08:50 AM | #3 |
![]() ![]() 1194
Rep 362
The above info is perfect. I would add that if you sucked in enough water through the intake to stop the motor, it may not matter that you did not try to start it again. Water doesn't compress, it can do a lot of damage to running engine: pistons, rods, etc. A turbo may push even more water in.
Carbon Black - Debadged|Mocha Nappa|DHP|DAP|Executive|Luxury Seating|M668 w/ DSW06+
Sid28072.50 |
08-21-2024, 11:41 AM | #4 |
Rep 4
Thank you so much, btw is there any chance that only the gasket had blown which is causing less compression and they gave me the repair costs of 10lac Indian rupees or $11000
08-21-2024, 11:56 AM | #5 |
![]() ![]() ![]() ![]() 277
Rep 615
Doubtful if anyone here can answer that question - take it to a different shop for second opinion. How did the water get in - is that something covered by your insurance?
08-21-2024, 12:21 PM | #6 |
Rep 4
The water got In as I was driving in heavy rain and there was water filled on road the water level was below front license plate - they say they dont cover mechanical and electrical wear and tear parts so I’m shocked what does it even cover then
08-21-2024, 12:34 PM | #7 |
![]() ![]() ![]() 11397
Rep 7,125
Posts Drives: 2018 M2 AW DCT Join Date: Aug 2012
You need to read this thread: https://f87.bimmerpost.com/forums/sh....php?t=2109349
BMWCCA member Puget Sound Chapter
Sid28072.50 |
08-21-2024, 01:37 PM | #8 | |
Rep 615
Partly, it's also on BMW that their cars cannot handle driving through urban water logging. Lastly, now you know - you own a BMW therefore you should not be driving through water ![]() |
Sid28072.50 |
08-21-2024, 01:45 PM | #9 |
![]() ![]() 1194
Rep 362
Reading that linked thread, it comes to mind to know where your air intake is located on any given model. I just looked at my M550 and it appears to be about centered in the grill openings FWIW.
My concern would be hitting an isolated deep puddle without knowing it was there. That has happened to me a few times when commuting years ago, but in an SUV.
08-21-2024, 02:30 PM | #10 | |
Rep 615
![]() Also wondering how would Hybrids fare especially if the battery has a chance to be exposed to water... Last edited by starlights; 08-21-2024 at 02:50 PM.. |
Sid28072.50 |
08-22-2024, 07:40 AM | #12 |
Rep 615
08-22-2024, 08:32 AM | #13 |
![]() 1726
Rep 1,545
Hybrid batteries are typically VERY well sealed.
08-22-2024, 08:41 AM | #14 |
![]() 5505
Rep 3,309
For typical splashing and such, yes. Being submerged in water....not so much.
