04-05-2024, 08:16 AM | #45 |
Rep 650
I’ve fitted it while waiting for coding session later.
Is this message normal? My only concern is there was no slack on the video cable so it was tricky to connect and seat the purple connection |
04-05-2024, 08:20 AM | #46 | |
Rep 419
Could you post some pictures of the fitment, especially where the display meets the driver's side dash? Thanks!
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive |
04-05-2024, 08:27 AM | #47 |
Rep 650
Fit is superb. Can’t fault it. Really looks factory. All told it’s €300 for adaptor plus €85 tax on import to Germany.
Screen was €180 off eBay. Coding circa €90. Amazing value as it’s such a refresh to the car And considering I came from G30 530d I really have the best of both worlds!!! |
04-05-2024, 08:30 AM | #48 |
Rep 650
My only concern would be the obstruction of what is a key part of the vision from windscreen as I have my seat set way back.
That photo is my view and as per red highlighted section it’s spot on |
04-05-2024, 08:59 AM | #49 | |
Rep 419
jaylazy2020267.00 |
04-05-2024, 09:03 AM | #50 | |
Rep 419
Let us know how the display looks post-coding!
04-05-2024, 09:53 AM | #51 |
Rep 650
Shockingly good! Resoltuon. Size and as I discovered driving from Paris to Stuttgart last weekend. Original screen is too far away to use touch
Can’t wait to try it Thanks so much to all here. Superb info and advice. |
04-05-2024, 10:26 AM | #52 |
Rep 419
Looks excellent! Glad you got the coding done so quickly and that our advice was helpful to you. Cheers!
jaylazy2020267.00 |
04-05-2024, 12:00 PM | #53 |
Rep 650
During coding which was super quick it still read no signal so Kubax said cable
Was seated right(which I had feared as the was no slack at all on the cable) So I took out two screws. Lifted the screen firmed up the purple connection and it worked inefficiently. Strangely I noticed while out driving that screen was a touch upright. So low and behold there is a gap at the back which wasn’t there on first install. It all sits perfectly until I get to the last few turns on the right screw If I tighten it fully I feel it pushing the back of the adaptor up. Tried to re seat it twice but it’s the same. All I can think of it a few washers in front of right hand side screw so that it doesn’t foul or push on the trim Anyone else seen this ? Overall I’m thrilled with it. Just went out for food. Google maps, CarPlay. SoundCloud. All look superb. |
kubax861800.50 |
04-05-2024, 02:00 PM | #54 |
sahil
32
Rep 324
can we use the kyocera screen or just the one made by LG?
04-05-2024, 02:23 PM | #55 |
Rep 419
The Kyocera display is the one BimmerTech uses in its promotional video for its adapter. Look closely at around the 1:55 to 2:00 mark in the video. So the Kyocera should work just fine.
satinf82_32.00 |
04-06-2024, 12:34 AM | #56 |
Rep 346
I have a 2016 M4 with I believe the NBT iD4 with an 8.8 inch screen would i be able to upgrade to this? So I need to pay roughly $300 for the screen + $200 for coding + $300 for adapter to make this work?
04-06-2024, 01:22 AM | #57 | |
Rep 650
Amazing value for money Also you can sell your 8 inch screen as they seem to sell for $300 You have to do it. It feels like I’ve got a new car. I’ve 60k miles on mine. I’m going to keep it and put another 60k on it! |
04-06-2024, 08:15 AM | #59 | |
Rep 419
The main benefit of using the MGU display is that the BMW OEM maps display at the higher 1920x720 resolution. All other menu content and apps seem to display at 1440x540. The NBTevo head unit was never designed to operate at 1920x720, so to make the MGU unit work requires more extensive/expensive coding. But the result is awesome if you are a fan of higher resolution displays (like on a computer). If you also prefer lower resolution (larger content) maps, Apple Maps, Google Maps and Waze all appear to operate at 1440x540 on the MGU display. So the MGU is kind of the best of both worlds. The SCALER unit is the easiest and most cost-effective solution, however. Coding is easier and cheaper, and the 1440x540 looks amazing as well. To source either unit, I recommend looking at Straight Six Auto Parts' eBay store: https://www.ebay.com/str/straightsixautoparts Let us know if you have any further questions!
jaylazy2020267.00 |
04-06-2024, 08:17 AM | #60 |
Rep 419
Wow, that looks really amazing! Well done, sir!
jaylazy2020267.00 |
04-07-2024, 12:01 PM | #61 | |
Rep 419
04-28-2024, 04:53 PM | #62 |
Rep 80
I'm disappointed that this adapter isn't compatible with the 10.25 X5/X6 screen, which I already have retrofitted in my car. It'd be nice to move the screen a little closer.
04-28-2024, 07:33 PM | #63 |
Rep 419
I think the panel in the G30/F90 10.25” display is better than the older F15 10.25” display, so you might like to upgrade. That, and the display is closer which helps with using the touchscreen.
05-11-2024, 06:44 AM | #64 |
Rep 894
Drives: OG M2
How does CarPlay look on the MGU screen? Is it any different than how it looks on the Scaler/EVO screen? Not sure which screen to pick. Hopefully CarPlay will run at the full 720p… Are the g30 screens still 60hz?
OG M2 with the OEM M mirror retrofit
05-11-2024, 11:42 AM | #65 |
BimmerPost Supporting Vendor
1801
Rep 3,070
Easier to get normal EVO screen
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
05-11-2024, 03:14 PM | #66 |
Rep 894
Drives: OG M2
It is easier to run the EVO screen but honestly, I’d be down to deal with more coding so long as CarPlay actually runs in a higher resolution on the MGU screen
