01-16-2013, 08:25 PM | #1 |
Rep 327
Drives: 2017 Tesla Model X P100D
2013 BMW M5 - RPI, Gruppe M - Dyno Results
Went to Goodspeed Performance today
They have a Maha dyno, gas was only 91 octane. Run was in gear 4, car in manual mode. Settings were in efficient and comfort (Said Sport mode doesnt effect HP) Results: To the wheel: 459HP, 446TQ To the crank: 556HP, 510TQ Wheel Dyno: Crank Dyno: No before runs in stock format, so no way to tell what these modifications did as far as "gains". This just shows what my car is at. Sorry to disappoint on that front. Also, this dyno is supposed to be highly accurate and doesn't have massaging of the numbers available through a manual process of inputting in a "Corrected" skew. There is a dip in the curve, which is directly related to the 91 octane opposed to 93. Let me know your thoughts. Thanks. |
01-17-2013, 12:08 AM | #3 |
Rep 327
01-17-2013, 12:41 AM | #4 | |
Rep 426
http://www.bmwusa.com/Standard/Conte...fications.aspx |
01-17-2013, 09:54 AM | #5 | |
Rep 327
They said they run it in whatever gear is closest to 1:1. I assumed they were going to look it up and use the correct one. When I showed up yesterday, I forgot to ask again, and just remembered to ask after all the dyno runs were complete after I already left. I appreciate the link. I emailed the shop the information so that they would have it for the next M5 owner, and can see it wasnt just "something I heard". |
01-17-2013, 10:39 AM | #6 | |
Rep 426
you should ask them for another dyno run...
01-27-2013, 07:09 PM | #7 |
Rep 327
Goodspeed said it doesnt matter on the Maha Dyno: "When we run in crank mode on the MaHa gear doesn’t matter. Fifth gear on the M5 is simply overkill as speeds would get out of hand quickly. That’s why we choose to do them in 4th gear!"
01-28-2013, 03:44 PM | #9 |
Rep 327
They are saying their dyno is an extremely accurate dyno. A $250,000 dyno that is of the same type BMW itself uses. That the car on 91 would be around 525 HP ( 550 HP on 93 as BMW rated), and with mods my mods on 91, I'm at 556. Hence an approximate 30HP improvement. Thus the results are just as expected.
They've mentioned other subaru's make 420 elsewhere and put 360 down here. Anyway, that's the story. Obviously with no stock runs, there is no exact measurement of mod increases. |
02-03-2013, 10:50 AM | #10 |
Rep 1,758
Drives: 30Jahre M5 plus a few more M's
Garage List 2022 BMW M5 CS [0.00]
2020 BMW M340i Xdrive [0.00] 2019 BMW M2 Competi ... [0.00] 2003 BMW DINAN S3 M5 [0.00] 2017 BMW 30 Jahre M3 [0.00] 2016 BMW M4 GTS [0.00] 2015 BMW 30 Jahre M5 [0.00] 1995 BMW M3 [0.00] |
My car hit the limiter in 5th so had to use 4th too.
Current non-BMW's
20 Jeep Grand Cherokee 03 Cooper S (Maxi Tuned 50bhp) 60 Impala (43k orig mi) 15 Turbo S (Kobb tune and Kline exhaust) |
02-05-2013, 08:52 AM | #11 |
Curve Thrasher
624
Rep 3,773
That is the gear that everyone uses for the reason you just stated B.
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run |
02-05-2013, 08:54 AM | #12 | |
Curve Thrasher
624
Rep 3,773
Country run |
02-05-2013, 05:36 PM | #13 |
Rep 785
Thanks for sharing. But without a before, claiming 30HP gain from intakes is just not fair to others shopping for intakes. That's a random guess.
I recall the Gruppe M CSL carbon intake for the E46 M3 losing power on the dyno, so the jury is out on them.
991 Turbo
993 GT2 Outlaw |
02-11-2013, 12:47 PM | #14 | |
Rep 327
I stated that theoretically, the full catback RPI GTS Exhaust system coupled with the Gruppe M intake could produce approximately 30WHP (and showed the reasoning behind that assumption). I also clearly stated that without before dyno's that this was just speculation. Furthermore, reading information about the E46 M3 intake has absolutely nothing to do with this car or intake design and is irrelevant. Studie Japan (a thrid party) did an actual before and after run and showed results of an increase to the wheel. Granted, they were working with Gruppe M, so it could be bias. However, IND did before and after dyno runs with the M5 Gruppe M intake and showed actual wheel horespower increase as well. So someone shopping for an intake would look at that data before purchasing. Someone wanting to know what their Gruppe M intake and RPI Exhaust M5 would put down on a Maha dyno would look at this thread. Hope that clarifies things. Last edited by ImpetuousRacer; 02-11-2013 at 12:54 PM.. |
02-11-2013, 12:53 PM | #15 |
Rep 327
Here is the Dyno Before and After and what HP to expect.
http://f10.m5post.com/forums/showpos...4&postcount=42 The increase is very minimal. It's more for looks, sound, etc. Last edited by ImpetuousRacer; 02-11-2013 at 01:00 PM.. |
02-11-2013, 03:46 PM | #16 |
Rep 4,117
The bad thing amongst all these internet dyno horsepower wars is that people dont do enough research. Back in the day turbo imports became dyno queens and Euro cars wanting to follow that trend started using wrong dynoes (Dynojets) in order to make a fake impression of a higher hp gain. Back then most Euro cars were naturally aspirated and for the part companies it made sense to test their product on dynojets. The true wheel hp that is being put down to the black is displayed by dynoes like Maha or Mustang dyno. The OP's numbers are most likely as close to reality as it will get.
Current: 21 M5 Comp, 23 M3 6spd, 23 i4, 20 Tundra TRD PRO
