06-03-2023, 05:53 PM | #1 |
Rep 2
b58 e30 project
So I have a 2018 M140i with roughly 75,000km on it. Catless downpipes, masata charge pipe, intake and a remap. What would I (more like the shop I’m gonna pay) need to remove to make swapping it into a e30 coupe chassis? Ideally I want to use as much as possible, including the Zf8hp box that it came with. I am already in the process of buying a f82 m4comp diff, so the open diff can stay in the f20. Besides engine mounts and fab work on the e30, what exactly do I need to take off and keep from the f20?
•I would like to keep the same key fob and wireless start •is the I-drive essential? •is there something glaringly obvious that I’m missing that wouldn’t make this project possible? |
06-04-2023, 03:33 PM | #3 |
Rep 5,357
Modern cars are basically computers on wheels. I imagine you would need to swap the entire electrical system and modules as the electronics of modern cars are so intertwined. Unless you're just making a track car, and then all you would probably need is the engine, trans and their associated computers.
B58gushesh2.00 HondaRC51251.00 |
06-05-2023, 07:10 AM | #4 |
Rep 1,480
Posts Drives: 2022 M440xi GC Join Date: Feb 2019
The "easiest" way would be to use a standalone ECU and not have to integrate everything from the donor into the e30.
CTinline-six6825.00 |
06-05-2023, 01:30 PM | #5 |
Rep 2
Would the factory ECU not work best with the engine and box it’s already programmed for? I don’t mean to sound like an idiot but if I used the original ECU, wouldn’t it think it’s still in the same car? Like it’s already mapped to run that exact b58 and ZF combo.
06-05-2023, 01:31 PM | #6 |
Hoonigan
6825
Rep 3,000
Posts Drives: '09 328i, '98 Wrangler Join Date: Dec 2016
Honestly your best bet would be to find a much simpler engine to swap with less computer control and modules for the E30 chassis. There have been a lot of S52/S54 swaps into those cars which is a significant bump in power, more aftermarket support, and less complexity.
It's one thing if you can do all the programming yourself, but if you expect a shop to do it, finding one willing to commit to that type of project will be difficult, especially if you expect them to provide an estimate that doesn't include a blank check.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
CamasM3e933149.00 |
06-05-2023, 01:39 PM | #7 | |
Rep 1,480
A good tuner would be able to make it sing with any ECU, I would reason that the engine/trans management is the least of your worries compared to the 15 or so other computers that rely on inputs to make everything work on a modern car. |
