E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > E9x Coding for track
      05-29-2019, 08:14 AM   #1
Synectic
Drives: 2010 e92 335i mtech
Hey there, i never actually did any coding for track use and was wondering what need to be done exactly? Most likely going to do it myself this weekend just can't find a thread on exactly what options need to be changed
      05-29-2019, 12:07 PM   #2
minaret
Drives: 2008 E91 ZSP
Find thread from paradoxical3 from 1-18-2016 titled Guide to BMW's electronic nannies (coding off e-diff and much more).
2008 E91, ARC-8, 255/40/17 NT01, ER sport cooler, TCK camber plates, coil-overs 400# front 700# rear, Koni SA shocks. M3 Subframe bushings, front + rear control arms, tension struts, strut brace. Quaife, Carbotech, Schroth.
      05-30-2019, 03:24 PM   #3
Volasko
Volasko's Avatar
705
Drives: 06 330i E90, 18 530xe G30
Found it!
https://www.e90post.com/forums/showthread.php?t=1216639
      08-06-2022, 04:39 PM   #4
mfran615
Drives: 2011 335is 6MT
Bringing this one back from the dead. The file links don't work for me. Does anyone know how to code these off? I've been searching for an hour.
      08-07-2022, 08:39 PM   #5
edycol
Drives: 2011 328i xDrive
If you have ProTool, easy peasy.
INPA is more complicated.
http://dreamingin302ci.blogspot.com/...ve-handle.html
      08-08-2022, 03:11 PM   #6
mfran615
I don't have x drive. Does RWD have the same DSC nannies as X drive?
      08-10-2022, 07:19 PM   #7
edycol
Go through list on ProTool once you connect it and see what you have.
      08-10-2022, 11:40 PM   #8
mfran615
No protool here. Just NCS expert
      08-11-2022, 08:58 AM   #9
edycol
I can't help you with that. You have INPA right?
      08-12-2022, 09:26 PM   #10
feuer
feuer's Avatar
Drives: wife crazy!
How do you do this is with inpa?
      08-13-2022, 04:02 AM   #11
edycol
I was referring that he might downloaded whole package. I supposed to be more detailed.
      08-15-2022, 09:12 AM   #12
mfran615
Yes I do have INPA
      08-15-2022, 12:02 PM   #13
edycol
Yes I do have INPA
NSC should be part of that download.
      08-15-2022, 08:36 PM   #14
Miska
Drives: 2006 300i Sport 6MT
I never knew there were so many nannies hidden in the car. I always thought the 5 second traction button press disabled most everything, but it looks like alot of these are still active even so.
      08-16-2022, 09:14 AM   #15
edycol
In another post you indicated you are doing HPDE's?
You need to code out everything but e.diff. DME might lower power especially if you have 330 and not upgraded 328 LCI. Pre LCI are known to be more aggressive in limiting performance due to brake overheat function. Pressing DSC for 5sec won't do anything to override that.
      09-19-2022, 01:38 PM   #16
Maxmax73
Drives: 2011 328i
Kind of related to this, or I probably should start a new thread, but is there a knowledge database or any kind of list/guide to traction control values? Because coding out basic options that everyone does, is just barely enough. Because if one goes through the list, there are values assigned to undesteer, oversteer, power reduction etc, and I'm assuming those define how your car is when traction/stability module tries to "help" you while on track.
      10-17-2022, 07:59 AM   #17
maryjane
Drives: 2011 335d Msport 3 Snail.
Id like to know where the power reduction is as well.....when at track and trying to launch from 2nd gear it wont let me go over 2000rpm without cutting power. Any ideas?
e90post
