Go Back   BMW E39 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos
      09-28-2019, 03:57 AM   #1
hokiedood
Drives: 2016 BMW 340i
2016 BMW 340i  [0.00]
What is the definition of "cell" in relation to downpipes?
Can anyone explain?
      09-28-2019, 04:28 AM   #2
Delta0311
Drives: 2011 BMW 335xi E92 2016 228xi
In scientific terms...
The cell count of a catalytic substrate refers to the number of holes per square inch and is a direct indication of the flow capabilities of that substrate. The lower the count of holes the bigger the hole need to be to fill one square inch, a bigger hole subsequently flows more exhaust gasses.
      09-28-2019, 07:09 AM   #3
GtiGyver
GtiGyver's Avatar
Drives: 2009 Space Grey E90 328i MT
Might also refer to CEL or check engine light. A normal occurrence when swapping in catless downpipes. Performance chips typically clear that problem.
c1pher4671.50
eluded3044.50
      09-28-2019, 07:22 AM   #4
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
I believe what’s going on is the higher cell count means more holes yes, but also more material to react with exhaust gasses to reduce emissions.
      09-28-2019, 08:37 AM   #5
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
CELLS - Literally the little connected boxes inside the converter.
CEL - Check Engine Light
The factory converter has 750 cells, and is therefore more restrictive than the after-market converters, which usually have 200 cells.
A 300 cell converter will not usually cause a check engine light, but all but 1 (Fabspeed) 200 cell converters will cause a check engine light.
